September 30th, 2010, 04:59 PM | #1 |
Join Date: Jul 2010 Motorcycle(s): Black '11 ZX-6R Posts: 209
shinto clipons
Piece that goes on forrk is one piece so rmoving triple tree is necessary
My 250 is mine and mine alone, you may see better you'll definitely see worse but mine, she's one of a kind!!!!btw, SHE'S SEXY!!! |
September 30th, 2010, 11:18 PM | #2 |
I'm not sure if this is in the right place, Ryan; did you mean to put it at the end of another thread?
October 1st, 2010, 12:36 AM | #3 |
Join Date: Jul 2010 Motorcycle(s): 09 Ninja 250r Posts: 215
I think he was just wanting to inform people who are buying/installing them that they will need to do a bit more work to put the shinto's on over the WC since the shintos require the removal of the triple tree while WC just bolt around it.
October 1st, 2010, 05:31 AM | #4 |
REALLY?I took mine off to put them on and i also dropped fork for better clearance as per Kkim...I didn't think i could open up the clip on enough to fit around fork but either way i prefer to keep the integrity of the clip on and just remove triple tree it really isnt that much of a process
October 1st, 2010, 05:50 AM | #5 |
ninjee two-fiddie
Join Date: Oct 2009 Motorcycle(s): 2008 Ninja 250r Posts: 61
Yes, the upper triple clamp must be removed in order to install the clip-ons. I installed mine last night, but everything is not quite done yet. I am having some serious clearance issues around the gauge cluster and the black dash plastic on either side of the bars. No matter how I position the clip-ons, something still rubs. Anyone else have a similar problem?
October 1st, 2010, 06:09 AM | #6 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
paul has these installed on his bike, everything should clear no problem, but may take some time to properly adjust. i have asked him to do an install video similar to his rearsets install video.
many people had clearance issues with the woodcrafts, but after spending some time to properly adjust, had no issues. this should help: Clip-ons (note this is for woodcraft, but Shinto clip-ons install in basically the same manner): http://www.ninjette.org/forums/showp...38&postcount=2, and http://www.ninjette.org/forums/showp...39&postcount=3 |
October 1st, 2010, 06:36 AM | #7 | |
Lower your fork....keep your triple tree on but loosen up the side screws on triple tree where the fork comes through the triple tree....keep cente bolt in...loosen the two fork screws and then start to loosen teh middle bolt which will cause the fork to lower and lower until the fork protrudes out of the triple tree minimally and the tighten up the fork screws...that will afford you clearance but will speed up your turnin as per Kkim
October 1st, 2010, 06:37 AM | #8 | |
October 1st, 2010, 06:41 AM | #9 |
the shintos dont quite offer the clearance past the triple tree that teh woodcrafts offer
October 1st, 2010, 08:50 AM | #10 |
self wrencher
has anyone tried to install it on TOP of the tripple tree instead of from the bottom?
October 1st, 2010, 07:14 PM | #11 | |
ninjee two-fiddie
Oh well... more tinkering tomorrow! |
October 1st, 2010, 07:36 PM | #12 |
wait... you mean to say these things don't come with any sort of installation instructions?
October 1st, 2010, 08:38 PM | #13 |
ninjee two-fiddie
October 2nd, 2010, 04:04 AM | #14 |
self wrencher
Paul said they can be mounted both on top or bottom. If mounted on bottom it WILL rub or hit at full turn. You will lose 10% of your full turn.
If mounted on top, you'll have no clearance issue but have to raise the fork 5mm or so for mounting. |
October 2nd, 2010, 06:09 AM | #15 |
self wrencher
Looking at the clipon it appears that you can put a few washers between to move the base out away from the triple tree for clearance a bit
October 2nd, 2010, 02:34 PM | #16 |
im disappointed
I've been tinkering for two days and i dont see how its going to work, i guess im out a 120 or so dollars...clearance is major issue n for it to go above would be major change in ergos of bike
My 250 is mine and mine alone, you may see better you'll definitely see worse but mine, she's one of a kind!!!!btw, SHE'S SEXY!!! Last futzed with by illrational; October 6th, 2010 at 05:31 PM. |
October 2nd, 2010, 02:46 PM | #17 |
self wrencher
Try it on top and see if you like how it drive. Can always put it back
October 2nd, 2010, 02:48 PM | #18 |
WHERE did you put yours?
October 2nd, 2010, 04:10 PM | #19 |
Ninjette CPT
ryan,
maybe.....you should email paul for some install tips as he has them on his bike with no problems. i have asked him to do an install video for the clip-ons similar to the video he did for the rearsets. until he gets a chance to put one together, i'm sure he'd be happy to offer some insight on installation..... |
October 2nd, 2010, 04:13 PM | #20 |
self wrencher
October 2nd, 2010, 04:18 PM | #21 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
Just a thought, try to lower you front end, so you have part of the shock sticking up so you can put the clip ons on top. Like this!
October 2nd, 2010, 04:43 PM | #22 |
then my bike will be really low past that 1" mark that kKim said we shouldnt past
October 2nd, 2010, 04:45 PM | #23 | |
Ok i feel stupid i didnt realize that i put the brake on the wrong side but i still have clearance issue
October 2nd, 2010, 04:50 PM | #24 | |
okay, just went outside to measure my bike. I have 1.75" of fork tube sticking up above the upper surface of the triple clamps and have no problems with my fender touching the bottom of my front undercowl. use this measurement at your own risk. |
October 2nd, 2010, 05:00 PM | #25 |
Also, I just looked at my bike, and with the oem handle bars off, I have about 1/2" sticking up. So really you would have to drop it like anther 1/2inch.
October 2nd, 2010, 05:05 PM | #26 |
Here a vid about them, not sure if it will help.
http://www.youtube.com/watch?v=IjnL1LJisTI |
October 2nd, 2010, 05:11 PM | #27 |
self wrencher
I have difficulty understanding how lowering the front end (or rise the fork tube helps with clearance when mounting the clipon below the triple tree..
October 2nd, 2010, 05:20 PM | #28 |
I was thinking you could instail them on top of the triple tree, but looking at the video, it seems they are made to go under. Can you adjust the bars upward to give more distance between them and the body?
October 2nd, 2010, 07:51 PM | #29 |
super ninja
Join Date: Feb 2010 Motorcycle(s): 2009 kawasaki 250r Posts: 127
took about 4 hours and alot of adjusting and patience but i finally got them where i like them i can turn full lock and it gets soooooo close to touching on both sides haha but just keep adjusting them and make sure that they are as far up as they can go on the fork. anyways if you guys want any other angles of it just let me know and i'll go out and take some.
2009 Ninja 250r aftermarket parts *HotBodies double bubble* *Swing Arm Sliders* *Sylvania Sliverstar Ultra* *Akrapovic Slip-on* *Shinto Clip-Ons/Grips/Bar Ends* |
October 2nd, 2010, 09:30 PM | #30 |
dunno... my response was directed to illrational's comment about me saying to lower no more than 1", which is why I quoted him.
October 4th, 2010, 02:46 PM | #31 |
self wrencher
Okay so I installed on top and have to lower front 1" to fit. No clearance issue. Then I mounted underneath, after adjusted to my fitment there is a slight or barely rub at the fairing at full clock. What we can do is find an 1" aluminum tube, cut into 2.5" or so segment then cut the tube in half. This then can be used as a spacer between the clipon base and the handlebar. This prob will give enough clearance to solve rubbing issue.
October 4th, 2010, 03:33 PM | #32 |
self wrencher
couple pics of Shinto clip-on installed under the triple tree.
October 4th, 2010, 03:59 PM | #33 |
Ninjette CPT
looks good john, thanks for posting
October 5th, 2010, 12:16 AM | #34 |
Hey John, got a couple of questions for you if you'd be so kind.
Where did you get those things to cover your fork tubes? And what's that thingamajig on top of your triple tree? Wanna trade bikes |
October 5th, 2010, 12:57 AM | #35 |
self wrencher
they are SSR preload adjustor. The other one is Scott steering damper.
Which bike do you want to trade? 08 ninja 250 or 07 600rr? |
October 5th, 2010, 01:24 AM | #36 |
Wow, damper for the 250?? Both? Are you my long lost twin? Now I have to ask where you got your mirrors and flush mounts...
October 5th, 2010, 01:33 AM | #37 |
K.D.I.T of ninjette.org
Join Date: May 2010 Motorcycle(s): 08' ninja 250r Posts: 44
If you dont mind me asking. Where did you buy your damper and preload adjusters?
"Cover it up while your on the bike, and it'll look the same when you get off of it." |
October 5th, 2010, 01:38 AM | #38 |
self wrencher
damper = hardracing.com
preload = slingshotracing.com |
October 5th, 2010, 01:52 AM | #39 |
sweet thanks. prices aren't to bad.
nice bikes btw. The 250 looks really good in white.
October 5th, 2010, 06:04 AM | #40 |
Gearhead
Join Date: Jun 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 242
Hey John, did that non-locking gas cap solve the tank vent noise issue? Just curious. I have thought about trying one of those. Mine has always sounded like a cat in heat!
Shinto Clipons package F/S | dyeforever | Motorcycle-related | 11 | February 14th, 2012 03:00 PM |
Shinto: Still never got my parts | currentsea | Motorcycle-related | 10 | April 28th, 2011 11:22 PM |
Shinto-Racing.com COMING SOON | ThaiNinjaRR | Motorcycle-related | 26 | September 6th, 2010 07:39 PM |
Question about Shinto racing... | Kitdog | Motorcycle-related | 5 | June 29th, 2010 09:57 AM |
Weekend Mods from Shinto | keeyu | 2008 - 2012 Ninja 250R Farkles | 4 | June 23rd, 2010 06:13 PM |
