October 18th, 2013, 09:50 AM | #1 |
[visordown.com] - New: handlebar power socket
IF you've got half a dozen electric accessories wired to your battery, and you’re fed up with using wire crimpers, this power socket could make life easier. The 12-volt socket is handlebar-mounting and includes a USB adapter, so you can plug in your heated vest, sat nav, mobile phone or whatever else you want with minimal messing around. It costs £49.32. Makers SW-Motech say: ‘This Universal Electric Kit provides a power supply for electric accessories through a cigarette lighter type outlet. ‘The Kit includes two brackets, so that the outlet can be mounted to either 22 mm or 28 mm diameter handlebars and it is also possible to screw the outlet directly onto the fairing on many motorcycles. A USB Adapter, supplied with the kit, plugs into the outlet so that electronic devices can be charged on the move without requiring special chargers. ‘The cigarette lighter outlet is rated at 12V/15A and comes with a cable that can be connected direct to the motorcycle battery. The USB Adapter is rated at 5V.’ Price: £49.32 Contact: www.motohaus.com Related Content Amputee biker turns false finger into USB drive Fag sponsorship back on bikes. Sort of. Triumph considers electric future Hybrid magnetic motorbike reaches 93MPH (Video) Electric motorbikes available at Solstis in London Click here for full story...
WTB Headlight Socket | mholme | Items Wanted | 4 | December 31st, 2014 10:34 AM |
[visordown.com] - New: handlebar-mounted hard case for iPhones | Ninjette Newsbot | Motorcycling News | 0 | October 4th, 2013 11:10 AM |
Help! Dropped socket into engine... | CmichRider | 1986 - 2007 Ninja 250R Tech Talk | 3 | July 19th, 2011 03:55 PM |
No power going to headlight socket | alexxx | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 3rd, 2011 11:19 PM |
12V Socket - Max power output? | AgentX | 2008 - 2012 Ninja 250R Farkles | 15 | September 12th, 2010 07:55 PM |
