Old August 30th, 2016, 05:02 PM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Broken Valve Cover Bolt -- Where Can I Buy Better Bolts?
Sorry, I feel like I've been posting left and right recently, but I'm deep into working on my bike
Anyway, I was putting the valve cover back on and tightening down the bolts when I heard a crack. One of the valve cover bolts broke off and the threaded part remained in the screw hole, but I think I can get it out with some vice grips.
And no, I wasn't tightening it down too much--it was barely getting snug when it snapped.
In any case, anyone know where I can get some sturdier bolts? I heard someone say that they got titanium ones?
Cra1g is offline   Reply With Quote
Old August 30th, 2016, 05:31 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
These bolts go into aluminium threads. The bolts don't need to be very strong.
You're lucky you didn't strip the threads in the head!
Old August 30th, 2016, 05:32 PM   #3
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Yeah, those are hardened heat-treated bolts, something else happened to make them fail. Normally the bolt would likely pull the threads out of the head before it broke.
Old August 30th, 2016, 05:36 PM   #4
Cra1g
Cra1g's Avatar
So what do you think happened? I definitely want to make sure it doesn't happen again
Old August 30th, 2016, 05:39 PM   #5
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
You tightened it too much. It doesn't take very much torque for those. I think a torque wrench is in your future. Inch pound range.
Goin' fast on slow bikes!
Old August 30th, 2016, 05:47 PM   #6
Cra1g
Cra1g's Avatar
It's 14.5 lbs. right? I was using a torque wrench set at 14 lbs. just so I wouldn't over-torque, and I know it works properly because I just used it beforehand on some other bolts. The bolt that broke was barely getting snug.
In any case, the broken part is too far down the screw hole to get it out with pliers or vice grips, so I guess I'll have to look into getting some kind of extraction kit.
Old August 30th, 2016, 05:55 PM   #7
VaFish
VaFish's Avatar
MOTM - Jan '16
IIRC the valve tappets are 14.5 ft lbs, the valve cover bolts are 87 inch pounds or about 7 ft lbs.
I don't think 14 ft lbs should have broken them though.
Old August 30th, 2016, 06:25 PM   #8
Cra1g
Cra1g's Avatar
Well ****. That must've done it then..
Old August 30th, 2016, 06:35 PM   #9
.........In any case, the broken part is too far down the screw hole to get it out with pliers or vice grips, so I guess I'll have to look into getting some kind of extraction kit.
http://www.harborfreight.com/screw-e...-pc-61981.html
........In any case, anyone know where I can get some sturdier bolts? I heard someone say that they got titanium ones?
http://www.ronayers.com/oemparts/a/k...der-head-cover
Old August 30th, 2016, 06:43 PM   #10
Cra1g
Cra1g's Avatar
Originally Posted by Motofool View Post
Thanks! Looks pretty easy to use. Hopefully it doesn't end up being a bitch to do..
Old August 30th, 2016, 06:48 PM   #11
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Forget the torque wrench. Use the stock bolts. When you tighten them up just tighten them enough to compress the rubber gasket.
14 ft lb is to much torque. Spec is 9.8nm or 87 inch lb.
Worlds fastest 250 ninja
Old August 31st, 2016, 10:25 AM   #12
Cra1g
Cra1g's Avatar
So I ended up getting the broken bolt out. It was actually still pretty loose in the threads--still not sure how it broke when I barely put any torque on it, but whatevs.
EDIT: Should I be putting a gasket sealant on before I install the gasket itself?
Last futzed with by Cra1g; August 31st, 2016 at 11:32 AM.
Old August 31st, 2016, 01:55 PM   #13
Racer x
Racer x's Avatar
Two little dabs in the corners of the half moons part of the gasket will do it.
Where do you buy your Valve Shims? The Seldom One 2008 - 2012 Ninja 250R Tech Talk 17 August 29th, 2016 12:01 PM
Over torqued valve cover bolts, snapped in half Jahjahwarrior 1986 - 2007 Ninja 250R Tech Talk 18 October 7th, 2015 07:55 PM
Fixed valve cover bolt leak & valve clearances Linkin Videos 3 June 24th, 2015 03:49 PM
Where to buy broken part from? Flawed Items Wanted 13 May 10th, 2013 03:25 PM
Broke Off Valve Cover Bolt off any advice cuz 2008 - 2012 Ninja 250R Tech Talk 19 September 22nd, 2012 08:48 AM
