#1 |
Turn Signal Fell Off !!
Anyone know how to re-attach this turn signal? Thanks!!
#2 |
Join Date: Oct 2013 Motorcycle(s): Ninja 250R, Tiger 800 XRT Posts: 828
There's a single screw on the light, unscrew it so you can open it up, this will allow you to push the wires back on the leads to the light. It's obvious which wire goes to which lead due to the length of the wires. You'll probably need to use a pair of small needle nose pliers to get the wires on since there's not much room.
Then you simply screw the light back together and push it on the stalk. You'll probably need glue or electrical tape to secure it though. Not sure how they're secured at the factory, but it doesn't work after it comes off. |
#3 |
Take the light apart, reattach the wires to the lamp base, put the black housing on the stalk, put the lamp reflector back in (the U shaped part on the reflector will slide onto the stalk and hold the two together) If you want, you can use a dot of rubber cement on the stalk if the there is some looseness (you may want to be able to take it apart later). Put the lens back on.
#4 |
/moved to new-gen tech
#5 |
thanks
thanks ninjette community! quick fix :]
Bike fell over (again lmao) and won't turn over | BoKing | 1986 - 2007 Ninja 250R Tech Talk | 5 | January 19th, 2015 05:27 AM |
[crash.net - MotoGP] - Crutchlow 'fell at turn one, nearly landed at turn two' | Ninjette Newsbot | Motorcycling News | 0 | November 12th, 2014 11:40 AM |
Right turn, but fell on left side??? | AlanDog | !%@*#$%!)@#&!%@ I crashed! | 9 | November 9th, 2013 09:37 AM |
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
turn signal help | akcalhoun | 2008 - 2012 Ninja 250R Tech Talk | 24 | February 25th, 2013 06:09 PM |
