#1 |
Join Date: Jan 2013 Motorcycle(s): 2007 Ninja 250 Posts: 22
Bike fell over (again lmao) and won't turn over
About a month ago I posted about my bike falling kickstand-side in, in the mud. You guys have been my go-to advice people for a few years now regarding this bike and your advice helped me get it back up and going so thank you.
Just arrived at my girlfriend's house and my normal guest parking spot was taken, so I parked it in some loose gravel around a corner. Girl suggested I go back out and move it closer yadda yadda, so when I went back out it had fallen over the opposite side of the kickstand (onto its right side). I don't think anyone pushed it or anything, it had been out there for less than 2 mins before I went back out. Anyways, I wasn't able to start it. All the electronics seemed to work, and it would attempt to turn over, but it didn't actually turn over when I cranked it. What are the first things I should look at? It spilled a bit of gas out when it tipped, as I could smell it, and there was a small puddle, and bit got on my hands. Not sure if that helps at all but it's more information. I appreciate your guys' advice! |
#2 | |
![]() Quote:
In order to save the battery, you could apply mouth vacuum to the proper port of the petcock until the bowls get refilled. If you see fuel overflowing, then the floats are out of position and not keeping the proper level. In that case some tapping with the handle of a screwdriver may help resetting those to close the valve.
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#3 | |
MOTM - July '15
http://www.wikihow.com/Help-Someone-...lowed-Gasoline |
#4 | |
![]() The vacuum nipple is just there to operate the valve inside your Petcock. |
#5 | |
MOTM - July '15
![]() I originally read that and interpreted it as him saying to suck on the main fuel line of the petcock but that wouldn't make sense because it wouldn't fill the bowls of the carbs because you'd need to disconnect it from the carbs in order to do that. |
#6 |
Join Date: Apr 2014 Motorcycle(s): 1978 Z1R, 1999 EX250 Posts: A lot.
MOTY - 2018, MOTM - Oct '16
Sounds like it hydrauliced (filled the cylinder with gas), pull the spark plugs and try turning it over. If it's sat for a while by now, it may have leaked the gas in the cylinder past the rings (into the oil) and will turn over (time to change the oil). Don't try to push start as it could bend the connecting rod if it's still hydrauliced, best to pull the spark plugs.
Parked bike fell in mud and now idles low/won't start. | BoKing | 1986 - 2007 Ninja 250R Tech Talk | 9 | December 15th, 2014 03:28 PM |
bike won't turn over | SMW-Vikings | 1986 - 2007 Ninja 250R Tech Talk | 10 | May 4th, 2014 05:54 AM |
bike wants to start just won't turn over | toomanyproblems | 1986 - 2007 Ninja 250R Tech Talk | 6 | January 16th, 2013 09:06 PM |
crashed bike and won't turn on? | kuntryman001 | General Motorcycling Discussion | 34 | November 24th, 2012 11:09 AM |
Dirtbike fell over, won't start now. | krolinked | General Motorcycling Discussion | 3 | November 17th, 2012 08:49 PM |
