View Poll Results: Which option do you prefer? | |||
Option 1: Delay version | 5 | 100.00% | |
Option 2: Intelligent version | 0 | 0% | |
Voters: 5. You may not vote on this poll |
Thread Tools |
May 6th, 2012, 10:14 PM | #1 |
ModMy250.com
New type of Brake light Modulator
Hey Everyone,
Since the 3rdbrakeflasher.com people stopped selling their modulators, I've been on the hunt for a new modulator that we could use. Some were either really too expensive, or didn't have the desired features that I think are good for us. Here's what I've found. There's a company called http://kahtec.com/ that build modulators, mainly for cars, but they can be adapted for bikes. They are NOT programmable like the 3rdbrakeflasher modulators I had been selling, but they do have the delay feature. Both products work with either candescent or LED bulbs. Option 1: Blinking Smart Stop Delay Version Same our standard version but when the brakes are applied for the first time causing your third brake light to flash 6 times in Appx.2.2 Seconds and then turn solid. Touching your brakes again within 8 seconds will cause your third brake light to turn on normally without flashing. Product rated at 6amps Option 2: Blinking Smart Stop Intelligent Version This unique product lets you maximize your Brake Light effectiveness when you apply your brakes. It causes your center high mounted brake light to automatically emit a visual alerting signal of 6 light flashes in Appx.2.2 Seconds before entering into a steady Brake Light ON condition. then your center high mounted brake light will automatically flash 3 times then a flashing sequence of 3 flashes every 3 seconds. This sequence will continue all the time the brakes are applied Product rated at 6amps The reason I bring up the second option, even though I don't like it for a commuter bike is that it is weatherized. The first option is not. Not that it would be a big deal. I could just spray it in plasti-dip which would seal the components. Unfortunately, the price goes up because their products are much more expensive. Right now, I'm leaning towards their standard + delay version. It just makes more sense, and it's only an 8 second delay, so you could reflash your lights if you're at a stop light or something. So I put it up to you guys and gals to vote and let me know which you would prefer. The new pricing for the modulators as a plug and play kit for the 250 will be $45 shipped for option 1. Most likely, it would be $48 for option 2. I'm not sure about carrying both versions at this point, maybe in the future.
The www.ModMy250.com guy |
HOW-TO: Install Brake Light Modulator | Rekognize | 2013 - 2017 Ninja 300 Farkles | 26 | June 10th, 2015 07:11 PM |
Brake light modulator | ai4px | General Motorcycling Discussion | 4 | July 15th, 2012 08:23 PM |
Brake light modulator with LED light? | pilotgeorge747 | 2008 - 2012 Ninja 250R Farkles | 5 | January 20th, 2012 07:25 AM |
headlight modulator + brake light flasher | quanttrom | 2008 - 2012 Ninja 250R Farkles | 16 | September 7th, 2011 04:31 PM |
Brake Light Modulator Help | noche_caliente | 2008 - 2012 Ninja 250R Tech Talk | 21 | May 4th, 2010 06:37 PM |
