October 6th, 2016, 06:00 PM | #1 |
[motorcycle.com] - 2017 Kawasaki Ninja 1000 Preview
At Intermot 2016, Kawasaki announced the Ninja 1000 sport tourer would receive a host of upgrades to enhance both the sport and touring sides of its dual personalities. While there are obvious design changes to make the bodywork fresh, chief among those updates is the addition of a six-axis IMU from Bosch. With it, the 2017 Ninja 1000 electronics suite is now able to offer much more sophisticated levels of control. Both the Kawasaki Traction Control (KTRC) and Kawasaki Intelligent anti-lock Brake System (KIBS) utilize the IMU to get a real time picture of the motorcycle’s chassis orientation, which it can then use to intervene if needed, and the level at which intervention is applied. Specifically, the IMU enables the KTRC system to offer more precise wheelie control, while KIBS now offers rear lift mitigation and minimal lever kickback during operation. The ECU also takes into account feedback*from the IMU, throttle position sensor, clutch actuation, and gear position to account for back torque while using the rear brake and downshifting. This little device, the six-axis IMU from Bosch, brings a new level of capability to the Ninja 1000’s electronics suite. Maybe the biggest benefit of the IMU, though, is the ability to offer what Kawasaki calls corner braking control, a.k.a. lean-angle sensitive ABS. Says Kawasaki, “Should riders use the brakes beyond the entrance to a turn (i.e. trail braking) or mid-corner (e.g. to avoid an obstacle), brake force is modulated to counter the tendency of the bike to stand up under braking. This assists riders in tracing their intended line through the corner instead of running wide.” Other changes include revised ECU settings for smoother power delivery and exhaust canister revisions to meet Euro 4 regulations (though those changes don’t apply to U.S.-bound Ninja 1000s). On the chassis side, there’s a revised shock linkage Kawasaki says offers suppler suspension action while also lowering seat height slightly from 32.3 inches to 32.1 inches. Rear brake pad material has also been revised. The Ninja 1000’s saddlebags now mount without interfering with the passenger grab handles. The list of touring-oriented updates for the Ninja 1000 is impressive as well, with a new double-bubble windscreen that’s 15mm taller in the center than before. It’s still adjustable to three different positions, without tools, to suit rider preference. The two-piece fairings are 28mm wider on each side to deflect more wind from the rider’s legs and cover a portion of the frame to help keep engine heat away. Headlights are now brighter and cast their light farther forward, using LED bulbs that draw 50% less power. In accordance with Euro 4 regulations, an LED position light has also been added. From the ergonomic side, the updated Ninja 1000 gets a five-way adjustable clutch lever and mirrors that are spaced 20mm farther outward, with a greater range of movement. The rider’s seat is broader, while the passenger seat is longer and features thicker padding for more comfort. The pillion seat’s shape is also bulged at the front to help prevent the passenger from sliding forward into the rider. The redesigned tail section of the Ninja 1000 sees the passenger grab handles separated from the pannier mounting location, so now the clean-mount luggage can simply slide into their slots without the need for an accessory passenger grab handle like on the current model. Whether you’re sitting in the front or the back, both saddles have been revised for greater comfort. Lastly, a new instrument panel is dominated by*a large analog tachometer, but is now joined by a gear position indicator and programmable shift lights. Among the Ninja 1000’s accessories, a few things stand out. They are:
2017 Kawasaki Ninja 1000 Preview appeared first on Motorcycle.com. Click here for full story...
[motorcycle.com] - 2017 Kawasaki Ninja H2, and Ninja H2R Preview | Ninjette Newsbot | Motorcycling News | 0 | October 6th, 2016 04:00 PM |
[motorcycle.com] - 2017 Kawasaki Z650 Pre-Preview | Ninjette Newsbot | Motorcycling News | 0 | October 5th, 2016 02:21 PM |
[motorcycle.com] - 2017 Kawasaki Ninja 650 Preview | Ninjette Newsbot | Motorcycling News | 0 | October 4th, 2016 05:15 AM |
[motorcycle.com] - 2017 Kawasaki Ninja ZX-10RR Preview | Ninjette Newsbot | Motorcycling News | 0 | October 4th, 2016 03:10 AM |
[motorcycle.com] - 2014 Kawasaki Ninja 1000 ABS Preview | Ninjette Newsbot | Motorcycling News | 0 | September 6th, 2013 07:10 PM |
