Old September 4th, 2017, 10:13 PM   #1
MakoMoto
Ninja 250r Noob
MakoMoto's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250r
Turn Signals?
Hey everyone!
My left turn signal is broken, and I am in need of a new set. Anybody know where to get some that can just be plugged in and ready? I am not looking to doing major wiring and such. My N-250 was purchased used and had flush mounts installed. I found OEM ones on Amazon but they are $40 a piece and I cannot afford that at this time. Thanks!
"Kawasaki Ninjas Rule!" - 1997 Power Wheels Commercial
MakoMoto is offline   Reply With Quote
Old September 5th, 2017, 02:52 AM   #2
Ram Jet
Ram Jet's Avatar
Originally Posted by MakoMoto View Post
Hey everyone!
If you're on a budget and want O.E.M. my first stop would be eBay.
Bill
Old September 5th, 2017, 07:33 AM   #3
highvoltj
highvoltj's Avatar
Motorcycle(s): 2008 Ninja 250R, 1986 Ninja 250R (x2) '06 ZX6R 636
OEM turn signals
I have a couple sets of OEM turn signals...one set from my '08 250r with only 400 miles...I removed them for installing smoked flush-mounts.
I'd sell for $20 plus shipping
highvoltj is offline   Reply With Quote
Old September 5th, 2017, 06:38 PM   #4
MakoMoto
Ninja 250r Noob
MakoMoto's Avatar
Awesome! They work properly and such? Paypal payment?
Old September 5th, 2017, 06:43 PM   #5
MakoMoto
Ninja 250r Noob
MakoMoto's Avatar
That would be wayyyyy super appreciated thank you! Just let me know ! Thank you!
Old September 5th, 2017, 08:56 PM   #6
highvoltj
highvoltj's Avatar
Turn signals
OEM turn signals a pair for $20.00 + $7.95 to ship them.
PM me if you are interested
Jon
Old September 5th, 2017, 09:14 PM   #7
Hey everyone!
Hi,
have you done any testing to see if its just the left turn-signal that's broken?
- does the rear turn-signal work?
- is there fuse blown?
- is wiring OK, power at left-turn signal bulb (wiring ok)?
- bulb burnt out?
Old September 6th, 2017, 07:53 AM   #8
MakoMoto
Ninja 250r Noob
MakoMoto's Avatar
Here is the skinny:
During the move to my newly purchased home, something broke the cover and bulb of the left turn signal (flush mount) . I have been unable to find the same set of turn signals so I have decided to go back to OEM since I dont know of any GOOD trusty flush mounts. I am unsure if the connectors are still OEM but I will include pictures on hopes somebody can relay that info to me. The right one works just fine.
Old September 6th, 2017, 08:10 AM   #9
MakoMoto
Ninja 250r Noob
MakoMoto's Avatar
Male piece
Not sure if it helps, but the male piece (the connector from the signal on the fairing) looks like this:
Old September 6th, 2017, 09:02 AM   #10
Ah, looks like OEM connectors are OK. So if light is busted and bulb broke, but wiring on inside is still OK, then yeah, replacing just the light is all you need.
Kinda annoying that they made a deep well into the fairing to mount the turn-signal. All that so they can use same light front & rear. Makes removing OEM light and using flush-mounts much more difficult.
Old September 6th, 2017, 09:36 AM   #11
highvoltj
highvoltj's Avatar
Turn signals
Hello Making, I found that I had removed the connector ends from my OEM turn signals for use on my smoke flush mount blinkers...have you considered this? Way cleaner look! On Amazon for $6.99. :-)
Old September 6th, 2017, 09:50 AM   #12
Hey! How did you cover up that giant hole used for OEM turn-signals?
Old September 6th, 2017, 10:12 AM   #13
highvoltj
highvoltj's Avatar
OEM turn signals
These come with a round disc base that I reformed into an oval to fit in the turn signal cavity...in my opinion, best bang for the buck and they look pretty fresh! ;-)
Old September 6th, 2017, 10:15 AM   #14
highvoltj
highvoltj's Avatar
Aftermarket turn signals
Actually, I have entertained the idea of buying a bunch of these and re-fabricating and selling to other ninjettes!
Old September 6th, 2017, 11:09 AM   #15
MakoMoto
Ninja 250r Noob
MakoMoto's Avatar
So there are no OEMs for sale?
Are the $6.99 bright enough?
Os the wiring to OEM connectors easy? (No exp with that)
Old September 6th, 2017, 11:22 AM   #16
I got a couple cheap LED smoke turn signals like that, to see what they looked like. I could hardly see them lit in sunshine, so I put them in the scrap bin.
Old September 6th, 2017, 11:23 AM   #17
highvoltj
highvoltj's Avatar
Turn signals
My OEM units have the connectors cut off for my flush mount blinkers. The housings are like new if you still want them...I just prefer flush mount. I have dark smoke on mine and they are still visible. Also have sets of light smoke flush mounts
Old September 6th, 2017, 09:04 PM   #18
Ralgha
Ralgha's Avatar
I've seen a number of aftermarket flush mounts on various bikes around town and not one, not a single one, was very visible. Could you see them lit? Sure, but they didn't stand out at all and were extremely easy to overlook.
I got some Traf-X LED signals for my bike (they're not flush mounts) and boy are they intense. Nobody's going to miss those suckers burning a hole in their retina.
Ride like you're invisible, but don't actively try to make yourself MORE invisible. Don't make any changes that reduce your visibility. Be honest with yourself, are those flush mounts really as visible as the stockers? Really?
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old September 7th, 2017, 06:38 AM   #19
highvoltj
highvoltj's Avatar
turn signals
I changed out my OEM turn signals for flush-mount units mostly for aesthetic value , not so much for visibility to other motorist's as when I jump on my motorcycle, I assume that I "Become Invisible" to other's, and act accordingly.
For the most part, they just don't look for you or see you coming when you are riding on two wheels!
Old September 7th, 2017, 06:56 AM   #20
Thanks for that, I'm going to take a look at those. If I'm stopped at a stop sign and want to turn left, I want cars going the other way to have no doubt about what I want to do.
Old September 7th, 2017, 06:57 AM   #21
Ralgha
Ralgha's Avatar
Like I said, you should ride that way regardless. There's a difference between riding like they can't see you, and actually helping them not see you. I was surprised by a turning motorcyclist not far from home awhile back. I saw him the entire time, but I didn't see his tiny aftermarket flush mount blinking feebly away.
I used to want flush mounts, that incident changed my mind in a heartbeat.
Old September 7th, 2017, 07:04 AM   #22
Ralgha
Ralgha's Avatar
They're a little hard to find now that PJ's Parts is done. I found some on Fleabay, but also http://www.carpimoto.com/en-US/ I got the 02 model. They're not cheap, but they're intense and well made. I'm pleased with them.
Old September 7th, 2017, 07:49 AM   #23
Thanks, I did find them at carpimoto. I'd really like to see a comparison between the two types. The 02 model seems to have one bright LED, where the 01 has a row of LEDs, but it's hard to know which is more visible. Quality looks very good, from their description.
Old September 7th, 2017, 09:44 AM   #24
Ram Jet
Ram Jet's Avatar
I'm doing all I can to preserve my 07's O.E.M. signals. I like them. I cringe to think of the time I removed my turn signals completely on my new 1973 Kaw 500 triple.
Bill
Old September 14th, 2017, 06:32 PM   #25
highvoltj
highvoltj's Avatar
OEM turn signals
So, if you still want the nice, like new turn signals, I may have a set with the connector still intact, or I can splice and reconnect plug...I just know I will never use them again on one of my bikes
Old June 16th, 2018, 05:12 AM   #26
TorontoNinja
Motorcycle(s): 2009 Kawasaki Ninja 250, 1975 Kawasaki G3SSE
Do you have the link to those flush mount turn signals? Was any cutting necessary?
TorontoNinja is offline   Reply With Quote
Old June 16th, 2018, 05:59 AM   #27
Ram Jet
Ram Jet's Avatar
I was driving behind two bikes the other day. Both tuned left in front of me and they had their turn signals mounted inside their rear stop/running lamp. 1/2 of their tail light lite-up (left side) indicating they were turning left. I thought about using the two empty light sockets in the tail light housing of my 07' Ninja and turning them into turn signals. I thought "Naw, that would just confuse a driver behind me." So I added two stop light bulbs back there. I have to admit that it was very clear that the two bikes were turning left in front of me. Now I would turn those empty sockets into turn signals. It would clean-up the tail section of your bike and be very easy to do. You'll find sockets at your local auto pats store that fit nicely. I JB Welded my sockets in place.
Give it some thought.
Bill
Old June 16th, 2018, 06:13 AM   #28
highvoltj
highvoltj's Avatar
turn signals
I went with these ones next.
Old June 16th, 2018, 06:32 AM   #29
Ram Jet
Ram Jet's Avatar
Neat and clean! What did you do for the rear signals?
Bill
Old June 16th, 2018, 06:38 AM   #30
TorontoNinja
Bill
Thanks for the info but I was referring to the front ones as posted in the picture above. I have an integrated taillight that did indeed clean up the back.
Old June 16th, 2018, 07:16 AM   #31
highvoltj
highvoltj's Avatar
signals
Bill
I have black smoked intregal tailight
LED's! (footpeg turn signals, brake light strips, front signals oh my!) VeX 2008 - 2012 Ninja 250R Farkles 16 June 29th, 2012 12:03 AM
Rear turn signals don't blink, front turn signals don't turn on andyuc88 2008 - 2012 Ninja 250R Tech Talk 3 March 23rd, 2012 02:47 PM
