Old October 15th, 2012, 02:52 PM   #1
front end suspension setup
ok guise. im curious about your front end setups. i ordered .75 sonic springs. a bit heavy for a stripped ninjette but i'm a fatass so it should make up for it. i have 10w and 20w oil but i'm not sure how thick i want to go with it yet so i haven't mixed it... no emulators or special valving. stock rear height with front forks set at 22mm above the triple. was running 003s but i got some rosso 2 on the cheap... so here's the question... what combo are you guys running? what tire/damping rate combos did you like/dislike? how fat is your ass and what springs are you running? how much weight have you stripped off your baby?
Old October 15th, 2012, 03:02 PM   #2
Dmented
CVMA#747 Ⓓⓜⓔⓝⓣⓔⓓ ⓡⓐⓒⓘⓝⓖ
Dmented's Avatar
Motorcycle(s): 09 250R * 09 Yamaha R6 * 08 CBR 1000RR * 04 NSR 50 * 02 KX 250
i weigh 195 lbs.
i run 15w oil in the front.
i ran stock before getting .8 springs and crashing.
i need emulators to get rid of nasty chatter.
I'm on bridgestone slicks ran around 30 psi.
bikes seems WAY stiff before but at least i'm not doing a pogo move around the WHOLE track. now i just chatter...
**CVMA#747**AFM#747R**M1GP#77**LeoVince*RaceTech*Hotbodies*Cyclemall*Bridgestone *
Motorad*Dainese*PolyMoto*Woodcraft**Visit The Dmented Racing Youtube Channel*
Dmented is offline   Reply With Quote
Old October 15th, 2012, 03:13 PM   #3
hey darren where are you getting chatter with your setup?
Old October 15th, 2012, 03:17 PM   #4
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
There are at least 2 dozen things that can effect your suspension...
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old October 15th, 2012, 03:45 PM   #5
spring rates and how much a pound weighs should be the same across bikes. though different brands of oil makers do define their weights differently (15w might be 17w or 13w depending on manufacturer) however the biggest difference is in how the rider puts input into the bike. most people quantify their suspension settings for springs in terms of static/dynamic sags as well as bottom out locations for the springs/preload and for a similarly weighted bike/rider combo, sags and bottom out compression weight should be very similar. damping however is pretty much completely magic numbers, however its pretty useful to know what kind of damping adjustments people have made based on the tire compound/carcass type they use... example being very sticky tires requiring higher damping to put more load on the tire carcass instead of the dampers
Old October 15th, 2012, 04:47 PM   #6
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
----> My Youtube! <----
Old October 15th, 2012, 04:54 PM   #7
tooblekain
tooblekain's Avatar
Originally Posted by Kevin2109 View Post
And with regards to your signature on the bottom...
Old October 15th, 2012, 05:01 PM   #8
i think its a [ you ] tag actually
Old October 15th, 2012, 05:09 PM   #9
Kevin2109
KThanksBye
Kevin2109's Avatar
Old October 15th, 2012, 05:11 PM   #10
this thread is suffering from socalmoto disorder...
come on e'rrybobby, meme fight!
Old October 15th, 2012, 05:15 PM   #11
9lives
Motorcycle(s): Daytona 675
I was expecting a reply like that nicely played.
9lives is offline   Reply With Quote
Old October 15th, 2012, 10:35 PM   #12
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
Back on topic. Not gonna lie, what probably improved my front chatter the most was raising up the rear end of the bike. I went from running wide every corner exit to being able to hold any line I like now, with chatter only happening when I run too deep on the brakes or the pavement isn't perfect.
But the forks are set with .7 springs (I'm 160 lbs), 12wt oil, racetech emulators, 20mm tube showing above triple, and my dogbones in back. Also don't weigh the handlebars
Rexbo is offline   Reply With Quote
Old October 16th, 2012, 06:28 AM   #13
Dmented
Dmented's Avatar
I experience slight to moderate chatter in 8 or more of the 17 turns...
then again, I weight the FUUUGG out of my bars because,
A: I'm heavier in my chest region
2: I have broad shoulders
III: I make up excuses why I can't stop weighting the bars.
Last futzed with by Dmented; October 16th, 2012 at 06:34 AM. Reason: 8 or more of
Old October 16th, 2012, 06:33 AM   #14
Dmented
Dmented's Avatar
Dmented's Chatter map
2 (entry)
5 (exit)
7 (exit)
10(entry)+(exit)
11(entry)
13 (exit)
14 (entry)
16 (mid)
Old October 16th, 2012, 08:08 AM   #15
psych0hans
psych0hans's Avatar
I'm currently running a stock setup but I haven't really hit the track yet, so I don't know where I'm lacking. I'll be tracking my bike in the first weekend of November, so I'll have a better Idea then. I already have a suspension upgrade planned though.
.70/75 fork springs (racetech/sonic)
15w fork oil
Racetech emulators
GSXR rear shock
Not sure if I'll change the rear spring, but I'll find out eventually...
I'll do my first track weekend on stock suspension/tires and then upgrade before my second track weekend sometime in feb. CSS here I come!!!
Old October 16th, 2012, 08:18 AM   #16
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
What year and model GSXR shocks are you guys using I'm assuming their stock shocks. Are you using the stock spring or changing it, also does anyone know if a r-1/r-6 stock would fit(I can get these all day long)
Old October 16th, 2012, 09:01 AM   #17
dino74
dino74's Avatar
J,
I think this thread http://www.ninjette.org/forums/showthread.php?t=59486 has alot on the GXSR rear shock.
CVMA #55
Old October 16th, 2012, 09:14 AM   #18
did you notice much difference running with emulators?
also how much did your bike weigh out to? 280? i weighed mine without the bellypan with 2 gallons of gas at 285... trying to figure out what else to remove :-X
Old October 16th, 2012, 09:20 AM   #19
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Mr. Fancy Pants I used to ride the **** out of Yamahas so I get all kinds of free parts..
Wait....
I have a crashed r6 that I need parts for.. HELPPPPPPPPPP
Trailerboy531 is offline   Reply With Quote
Old October 16th, 2012, 11:06 AM   #20
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Wait....
Invest half a million $ in racing over several years and maybe Yamaha will hook you up to
I gave everything I had to Jay when I retired so I'm sure he has a shock or two laying around. What do you need and ill check on it for you.
Old October 16th, 2012, 11:09 AM   #21
he needs the entire bike... lol
Old October 16th, 2012, 11:37 AM   #22
Dmented
Dmented's Avatar
whops...
I didn't see this... BRB
Old October 16th, 2012, 01:20 PM   #23
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
You're welcome.
Old October 16th, 2012, 01:57 PM   #24
Originally Posted by Nemesis View Post
You're welcome.
what were you running jon?
i know you had a fancy schmancy ohlins rear...
Old November 3rd, 2012, 02:49 AM   #25
psych0hans
psych0hans's Avatar
How much of a difference will a change in the weight of the fork oil make? I'm 155lbs and Race Tech has recommended I use 15w with .70 springs. I've ordered .70 springs, but I only have access to 20w oil... What shall I do? I MAY be able to get 10w... Is it a good idea to mix the two?
Old November 3rd, 2012, 04:03 AM   #26
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Yes mixing is ok
Old November 12th, 2012, 06:10 PM   #27
you can mix... for example 50%/50% of 10 and 20 will make 15. 75% 20 and 25% 10 makes 17.5
Old November 12th, 2012, 07:26 PM   #28
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@psych0hans - Hans one tipp if you're mixing the oil maybe best to go is 12.5 like alex said but only use 75% 10W and 25% 20W, i went with 15W but had to set the oil level from standard 108mm to 115mm so it's not to stiff. Or maybe, because of your low weight, better go with 10W and set the oil level at 100mm.
The second for your fegv's maybe it's a good idea to use the blue springs with 2 or 2.5 turns, i'm using yellow with 1.5 turns. But at least that's a personally setup.
@alex.s - Alex maybe this chart about Fork oil can give you some informations.
Old November 24th, 2012, 09:29 PM   #29
1ER6F
#41 Noriyuki Haga
1ER6F's Avatar
Motorcycle(s): '10 250r Track Bike
285 lbs!!???
I seriously need to research how and where I can shed some weight!
I wanted to get an ideal of my bike weight before I ordered my springs so I went down to the local dump/landfill yesterday and weighed in. The scale indicated 520 lbs with me on the bike. That's 158 lbs for myself, 12 lbs for my gear, and 350 lbs for the bike. And that was with a little over 1/4 tank of gas. Granted, the bike is stock and it's a California emissions model, that is quite a difference!
I ended up ordering the .75 springs from SonicSprings based on a mixture of what I've researched here on the forum and my weight calculated from Racetech's website.
My first track day is going to be in a couple weeks. My plan is to swap out the springs, use the existing stock fork oil and see how it feels from there. I imagine I'll probably have to convert to a thicker weight oil though...
1ER6F is offline   Reply With Quote
Old November 25th, 2012, 01:53 AM   #30
psych0hans
psych0hans's Avatar
When you guys go about reducing the weight of your bike by throwing things out, do you guys pay any attention to how this affects the weight distribution and in turn the handling characteristics? I believe the ideal weight distribution is 50/50, but lets say you remove the exhaust, that will definitely make it heavier in the front than the back... Same goes for passenger foot pegs, etc...
Old November 25th, 2012, 10:40 AM   #31
Dmented
Dmented's Avatar
maybe you WANT it heavier in the front for more "bite" and "feel"... or you could change geometry OR body positioning. there are SOOOOO many factors.
Old November 25th, 2012, 11:12 AM   #32
psych0hans
psych0hans's Avatar
I'm just thinking out loud, I honestly don't know diddly squat about suspensions and handling etc... except what I've gathered over various sites. I remember on twist of the throttle, Keith Code says that most bikes are setup with a 50/50 weight distribution. So what you're saying is, if some more weight is concentrated on the front, it might actually be better? Thanks in advance.
Old November 25th, 2012, 11:24 AM   #33
Dmented
Dmented's Avatar
I also just say things out loud...
tourettes maybe?
I'm decently paced but only know a little bit about the mechanics of it all. I'd say ask shane or steven more about suspension setup. I can give you all the advice i know but you still gotta get out there and toss her around.
Old November 25th, 2012, 11:33 AM   #34
psych0hans
psych0hans's Avatar
Truer words have never been said... It just seems that right now the track is eluding me with all its might... lol I'll persist though and get there eventually... Thanks again!!!
Old November 26th, 2012, 10:14 AM   #35
you honestly can do 95% with a stock bike. if skill is limiting you to only 50%, you dont need the extra 5%, you know what i mean? sure is fun to tinker with though
Old November 27th, 2012, 07:20 AM   #36
zx6racer
Motorcycle(s): 2008 ZX2.5R, 2005 ZX6R, 2002 and 2005 CRF450R, 1986 GS650 Cafe (building)
i weigh 195 lbs.
Darren, your rear is set too stiff. i was doing the same thing, chatter everywhere. ed sorbo and i did some tweaking, cranked the high speed damping all the way down, softened the compression and rebound. he said the rear was loading the front because it was not "moving" evenly. Im still not even completely, the front is still a bit too soft but went out after the adjustment and ran 2:01.1 with no chatter at all. AND KEEP YOUR FAST ASS MEAT HOOKS LOOSE ON THE BARS!!!!!!!!!
zx6racer is offline   Reply With Quote
Old November 27th, 2012, 07:49 AM   #37
Dmented
Dmented's Avatar
Originally Posted by zx6racer View Post
Darren, your rear is set too stiff. AND KEEP YOUR FAST ASS MEAT HOOKS LOOSE ON THE BARS!!!!!!!!!
I'm not sure about the rear being too stiff. bike actually FEELS planted. but DAYUM you hit it on the money about weighting the bars! some day's i got a fairy girl touch on 'em but normally I'm going O.J. simpson on it's neck! I can't seen to ride loose. I feel like i gotta beat 'em up everywhere. that's why i stopped going to the gym so i can loose my monkey grip.
anyone got pointers. besides BREATH and JUST LOOSEN UP.
Old November 27th, 2012, 07:56 AM   #38
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Maybe you could try a medical aid
Old November 27th, 2012, 08:08 AM   #39
Dmented
Dmented's Avatar
see, that's the thing, i could, ummm, if we, wait... what were we talking about?
Old November 27th, 2012, 08:55 AM   #40
Zombiphone
CVMA/AFM #72
Zombiphone's Avatar
Motorcycle(s): 2009 Ninja 250r (Racebike), 2015 FZ-07(Tourer), 2001 KX65(LOL bike)
Sounds to me like..... D needs some practice
When I took Pridmore's school, he suggested a pretty cool and simple drill that consisted of consciously inhaling from entrance to apex, then exhaling through the exit of each turn. Really hard to remember to do, and I need to work on that one myself quite a bit, but maybe a good exercise to try?
Zombiphone is offline   Reply With Quote
Rojoracing53 front suspension setup for racing rojoracing53 General Motorcycling Discussion 55 January 27th, 2016 12:57 PM
Suspension Setup Dave Moss accumack Ninjettes At Speed 6 December 6th, 2014 04:08 AM
Upgraded front suspension, front end tuck Ginganinja 1986 - 2007 Ninja 250R Tech Talk 12 October 30th, 2014 10:27 AM
so who would like to setup my suspension? Old Lemon 2008 - 2012 Ninja 250R Tech Talk 13 May 27th, 2014 05:02 PM
suspension setup alex.s General Motorcycling Discussion 6 April 23rd, 2012 04:52 PM
