November 2nd, 2014, 11:58 PM | #1 |
cadd cadd cadd
MOTM - May '15
Directional tires; reverse tread patterns?
With directional tires (like the Rosso 2s), have you guys ever noticed that the tread pattern is reversed in the front? With this reverse tread, it looks like water will be channeled to the center of the front tire?
Any idea why they do that? Perhaps when leaning over, water will be pushed to the outside of the corner? But if that's the case, with the "correct" tread in the rear, water would be pushed to the inside of the corner??? I'm just confused. |
November 3rd, 2014, 05:40 AM | #2 |
November 3rd, 2014, 06:14 AM | #3 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
you want the water to go away from the center, so as the tire rolls forward, the water is going sideways. If the tread pointed the other way, it would be pushed into the center, not away
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
November 3rd, 2014, 07:45 AM | #4 |
that front tire on the right looks backwards. theres an arrow onthe side of the tire
November 3rd, 2014, 08:01 AM | #5 |
cadd cadd cadd
MOTM - May '15
November 3rd, 2014, 08:06 AM | #6 | |
cadd cadd cadd
MOTM - May '15
It had nothing to do with water channeling. Lol |
November 3rd, 2014, 08:16 AM | #7 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Even the michelin street pilots have the same pattern with both front and rear opposed, i thought i screwed up when i mounted mine but the direction is correct from the factory. If the manufacturer had made the direction the way it is, than i feel they know what is best as they have had many years of testing under their belt to know which way would be best way to mount them.
November 3rd, 2014, 09:42 AM | #8 |
cadd cadd cadd
MOTM - May '15
I just ordered the pilot streets. The only thing weird about them is they don't have that red (sometimes yellow) dot that tells you where to line up to the valve stem.
Directional bulbs | lizard1043 | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 6th, 2014 10:51 AM |
Curiosities about the history of shifting patterns | Motofool | General Motorcycling Discussion | 5 | April 13th, 2013 07:57 AM |
[superbikeplanet.com] - Dunlop Announces New Bi-Directional Multi-Compound Race Tires | Ninjette Newsbot | Motorcycling News | 0 | September 13th, 2012 10:50 AM |
[motorcyclistonline] - Pirelli Adds New Mid Hard 554, Updated Tread Patterns and an A | Ninjette Newsbot | Motorcycling News | 0 | September 13th, 2011 01:50 AM |
[superbikeplanet.com] - Roadblock Canceled; Normal Traffic Patterns Return | Ninjette Newsbot | Motorcycling News | 0 | May 30th, 2010 06:40 PM |
