December 25th, 2012, 01:38 PM | #1 |
Join Date: Dec 2012 Motorcycle(s): 1992 Kawasaki Ninja 250 Posts: 4
Replaced Tranny, now it won't shift?
I need some advice. Last year I bought a 1992 ex250 from a friend because he had completely destroyed the tranny. We took apart the engine, replaced all damaged components within the case from the pieces of metal from the shredded tranny, and put in another one from a parted out bike (fully functioning).
My ex put the bike back together and the engine starts up and sounds great, only problem is when you hold in the clutch you cannot shift at ALL. The shifter wont even move, it feels like there is resistance or something. I'm thinking that something wasn't put back in right, considering my ex was working on two ex250's and they both have similar problems and won't shift now. Any opinions are highly valued, I can't find a mechanic that will crack it open for less that $500, and that's what I paid for the bike. Bike only has about 19K miles on it, if that is of any relevance. Does it sound like a clutch issue or shift forks or something totally different? OLD TRANNY LOL |
December 25th, 2012, 01:46 PM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
FS: ninja 250 mint condition
The bike no longer shifts because it's so fast it only needs 1 gear. $2700 OBO
December 25th, 2012, 03:57 PM | #3 |
December 25th, 2012, 04:17 PM | #4 |
Welcome to the site, Kara !!!
Yours is a difficult case: you need to decide whether or not investing more into this old bike. Even if the problem is a simple assembly mistake, new gaskets and more than a few hours of labor will be needed. Same happens if you rotate the rear tire by hand with the engine off?
December 25th, 2012, 04:35 PM | #5 | |
I just want to know what the most likely culprit is, like maybe when the clutch was out he put the plates in wrong? or something? The bike can be rolled around, that's the only positive thing. |
December 25th, 2012, 04:44 PM | #6 |
I'm curious how it got into that shape in the first place. I'm guessing excessive clutchless shifting.
But as to the current problem, your shift change shaft is either not installed correctly or is binding. Could also be that your shift drum forks are not seated properly. When reassembling the transmission, it doesn't just drop in place and there are a few tricks to get it in correctly. Its not that difficult, but your ex should have tested it prior to reassembly. Whereabouts in Florida are you? Anywhere near Palm Beach? I might be able to help out.
December 25th, 2012, 04:57 PM | #7 | |
The previous owner was a show-off, he downshifted at too high of rpms and the gears locked together and the back tired locked up and it threw him hmm, I'm pretty sure he just put it in, idk he did it when I was at work. I know they reassembled my bike's twin (same bike, newer year) a few times because they kept messing up stuff (like putting the shift forks in wrong), which is funny because the person helping him actually graduated from that motorcycle school in Orlando and supposedly did a lot of work on ninjas. I'm actually about two hours north of you, in Brevard County. |
December 25th, 2012, 05:05 PM | #8 | |
Bike won't shift | Jiggles | 2013 - 2017 Ninja 300 Tech Talk | 6 | August 2nd, 2013 06:46 PM |
Dropped Bike Won't Shift | KnockoutJ | 2008 - 2012 Ninja 250R Tech Talk | 10 | March 23rd, 2013 08:57 PM |
Won't shift into neutral. Why? | puma22 | 2008 - 2012 Ninja 250R Tech Talk | 5 | February 17th, 2013 10:39 AM |
Shifter won't shift! Help please. | lastcyclone | 2008 - 2012 Ninja 250R Tech Talk | 6 | January 27th, 2013 07:15 PM |
[crash.net - WSBK] - Hopkins out for season, won't be replaced | Ninjette Newsbot | Motorcycling News | 0 | September 12th, 2009 02:21 AM |
