Old October 11th, 2009, 03:09 PM   #1
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Carb is draining... and draining... and draining....
Riddle me this, Batman...
I put my bike away for the winter today. After filling the tank to the brim with stabilized fuel and changing the oil, I went to drain the carbs.
Those float bowls aren't that big, so I just stuffed a big wad of paper towels in there to soak up the few ounces of fuel that ought to come out. Well, the towels saturated, so I shut the tap off.
Hm. More than I thought.
I hunted around in the garage and found an 18-inch long piece of clear plastic tubing about 1/2" in diameter with a cap on one end. Way too big to fit snugly on the float bowl nipple, but it served well to catch fuel.
So I opened the tap and filled my catch tube, which holds maybe a couple of ounces or so. I popped the gas cap open and poured the fuel back in the tank. I repeated this procedure.
Six, seven, maybe eight times. Gas continued to flow. I didn't measure, but I must have drained 10 to 12 ounces out of one carb, and there was no end in sight. At that point I figured I'd better just stop and button the bike up before the sun went down. Worst case is that I store it with stabilized fuel in the carbs.
WTF? The bike runs flawlessly, so I don't think there's anything wrong. I checked the main valve and it is switched to ON, not PRI.
The only thing I can figure that could cause this is a double failure... faulty petcock AND faulty float valve in the carb. But not only is that very unlikely, wouldn't it cause some other symptom?
Anyone got any ideas here?
Old October 11th, 2009, 03:15 PM   #2
g21-30
g21-30's Avatar
If the valve is not on PRI, gas is only "supposed" to flow when there is a vacuum present. Disconnect the vacuum line from the valve and try it again.
Old October 11th, 2009, 04:35 PM   #3
adouglas
adouglas's Avatar
Wait a minute... isn't the vacuum at the petcock caused by engine operation? Are you suggesting that there is vacuum in that line after the engine stops?
If there isn't vacuum in that line (don't see how there could be), if I simply disconnect the vacuum line, how will that change anything?
At this point I'm not going to have any opportunity to work on the bike at all for two weeks, and even then it'll be a challenge to find the time. Chances are it'll have to stay as it is until spring.
I'd still like to find out what's going on, though.
Old October 11th, 2009, 05:27 PM   #4
g21-30
g21-30's Avatar
That's my point! Disconnect the vacuum line and you will know for sure there isn't a vacuum present. If you search, you will see that at least one person has had a failed valve, i.e. gas flowed without a vacuum present and the valve NOT set to PRI! Bottom line....you may have discovered that you have a bad valve.
You might do as Sailariel does and pinch shut the fuel line leading into the valve, prior to draining the bowls!
Old October 11th, 2009, 05:29 PM   #5
HKr1
IC2(SW)
HKr1's Avatar
I wouldnt store any carb empty, Unless its bran new in the box. Why dont you just put in the stabil, give her a good baby shaking(mixing it a bit), and run the motor for a few. < So that mix is in the carbs.
Old October 11th, 2009, 05:42 PM   #6
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Andrew - 2 good fall new england days this weekend for riding. Sure you want to shut her down already? I
Old October 11th, 2009, 06:36 PM   #7
adouglas
adouglas's Avatar
Can't do the storage thing during the week, and can't deal with the bike at all next weekend... my band has a gig Saturday (if you're anywhere near southwestern CT come see us! The Lumberyard in Georgetown, just off US 7), then Sunday I have to hit the road for Missouri.
Anyway, I did some more thinking. My earlier thought about a double failure was based on backwards thinking... the float valve shuts when the bowl is full, so it makes sense that it'd just flow as long as the supply is there.
The obvious answer is a faulty petcock. If the petcock were not faulty there would have to somehow be a vacuum held on it without the bike running... and I don't see how that could happen.
So... what symptoms are there if you've got a faulty petcock? Shouldn't it manifest itself in some way in normal operation?
Old October 11th, 2009, 06:38 PM   #8
adouglas
adouglas's Avatar
I just stabilized the last tank as well as the storage tank. That way the whole system definitely has marine stabil-treated fuel in it.
Old October 12th, 2009, 07:13 AM   #9
g21-30
g21-30's Avatar
Normal operation...vacuum (ON position) opens the valve (petcock). If the valve is faulty and stays open (possibly your problem) when no vacuum is present, you still have normal operation, i.e. the engine starts and runs!
If you have the valve set in the PRI position and drain the bowls, then you will have gas flowing until the TANK is drained! Is this perhaps your problem?
Old October 12th, 2009, 08:08 AM   #10
adouglas
adouglas's Avatar
Nope. Definitely set to ON, not PRI.
I've read somewhere about fuel overflowing and dripping out of the carbs if the vacuum valve is faulty. Is this correct?
If not, and the bike operates perfectly normally with a bad vacuum valve -- no adverse effect other than the inability to easily take the tank off and drain the carbs -- then why the heck is there a vacuum valve in the first place? A simple ON-OFF petcock would be cheaper, simpler and more reliable!
Old October 12th, 2009, 08:52 AM   #11
g21-30
g21-30's Avatar
The float needle-valve controls the flow of fuel into the bowl.
Old October 12th, 2009, 10:11 AM   #12
adouglas
adouglas's Avatar
Yeah... so zero symptoms other than the inability to drain the carbs without also draining the tank? Is that correct?
Fortunately rebuild of the petcock appears to be fairly simple and straightforward if it turns out to be needed. Just a few gaskets and an o-ring. But there is that whole tank-draining hassle, plus concern over introducing leaks.
Old October 29th, 2009, 04:43 PM   #13
g21-30
g21-30's Avatar
Any update?
Old October 29th, 2009, 08:25 PM   #14
adouglas
adouglas's Avatar
No, I just decided to leave the carbs as they are, with stabilized gas in them. The bike has been put up for the winter.
Draining fuel tank - gpx250 Woolley7325 1986 - 2007 Ninja 250R Tech Talk 4 March 29th, 2014 05:49 PM
draining the carbs caineroad 2008 - 2012 Ninja 250R Tech Talk 1 November 11th, 2013 08:35 PM
Problem with draining the carburetor! Please help! htsang07 2008 - 2012 Ninja 250R Tech Talk 14 September 5th, 2012 09:43 PM
What position to have the fuel valve on when draining carbs? pucktoplay1 2008 - 2012 Ninja 250R Tech Talk 9 December 29th, 2010 09:06 PM
Opinions on draining carbs please :) joyinc 2008 - 2012 Ninja 250R Tech Talk 18 September 19th, 2010 08:19 PM
