November 12th, 2011, 12:02 PM | #1 |
Jigglin' your Jiglets
MOTM - Apr '13
My Bike's Battery Died, What Should I Do?
So I accidentally left my grip heaters on all night and it killed my battery. I got it started by rolling it down the driveway and then I rode it for about 10 minutes and took it up a hill. Turned the bike off and tried to start it but the battery didnt have a charge. So I rolled down the hill and started it again and now I have the bike idling in the driveway at about 2.5k rpms in an attempt to charge the battery. Is there anything I should do?
November 12th, 2011, 12:12 PM | #2 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
Unless you keep the bike running for good 15-30 minutes, at 3-4000 rpm; the bettery is not getting much juice back into it from the stator.
If the battery is less than 2 yrs old, and have never been drained, likelyhood that you can charge it back to life with a battery charge hooked onto it for a good amount of time. If the battery is older, rarely been hooked to a chager and have been drained a few times, likely that it's not going back to full life.. time for a replacement. |
November 12th, 2011, 12:13 PM | #3 |
MOTM - Apr '13
Battery is new, I'll go idle at 3k then
November 12th, 2011, 12:17 PM | #4 |
vampire
November 12th, 2011, 12:19 PM | #5 |
Winging It In Life
Join Date: Aug 2011 Motorcycle(s): 2010 250R; 2011 250R (sold) Posts: A lot.
Similar thing happened to me early last month. I ended up using a battery recharger (or is it called a battery tender? Idk) to recharge the battery.
Good luck, man. I suggest that if you've got the bike on, ride around for a few miles and then turn the bike off and back on to see if it's good. If not, try the process again.
2011 Kawasaki Ninja 250R (Bought - Apr 22, 2011; Sold - Feb 17, 2015) 2010 Kawasaki Ninja 250R (Bought - May 01, 2017; Current) |
November 12th, 2011, 12:33 PM | #6 |
MOTM - Apr '13
So I had it idling at 2.5k for about 20mins (I know its bad ) and I took back up the hill to try it again and it started! Woohoo!
I don't have a battery charger but at least I know that the inefficient process of turning gas into electricity works.
November 12th, 2011, 02:35 PM | #7 |
vampire
Idling for 20 minutes probably gets your battery back to 40% of its capacity, if it is a new battery that has been drained to empty...
If you do not recharge the battery to its full capacity, the battery life will be shorten and future capacity of the battery will be reduced. Time to invest in a battery charge. |
November 12th, 2011, 03:08 PM | #8 |
IC2(SW)
November 12th, 2011, 03:26 PM | #9 |
Next time just go for a ride for 20+ minutes. Idling it isn't recharging it nearly fast enough, and the cooling system of these bikes isn't intended for long-term idling at even normal idle speed, let alone bumping it up to 3k (I assume with the choke/enrichener).
November 12th, 2011, 03:27 PM | #10 |
Always.
Join Date: Mar 2011 Motorcycle(s): '08 Ninja 250, '05 GSX-R600 Posts: A lot.
Well seeing as no alternator is present, go for a long ride then when you get back let it idle and don't use your lights/turning signals much.
Or charge it...moto shops will usually charge it for free overnight
blink-182 |
November 12th, 2011, 03:39 PM | #11 |
So, where's the reverse?
The way I see it, if you own a car or bike, a battery charger should be considered as part of your "tool-set".
November 12th, 2011, 06:28 PM | #12 | |
MOTM - Apr '13
I couldn't ride for very long because I had to finish laundry before I went to work however the ride to work is 40mins each way so that should charge the battery some more. this morning 2 of my 3 vehicles were out of commission due to dead batteries. I'll take this as a sign that I need to buy my next bike juuuuuuuust to be safe
November 12th, 2011, 06:49 PM | #13 |
I'd take it as a sign you need a battery charger.
November 13th, 2011, 02:44 AM | #14 |
Join Date: Oct 2011 Motorcycle(s): 2007 EX250F Posts: 70
November 13th, 2011, 06:21 AM | #15 |
User Title Free Since '12
Join Date: Dec 2010 Motorcycle(s): '10 Ninja 250R Special Edition Green Posts: A lot.
MOTM - Feb '12
I see two choices. My vote is PANIC!
Or, you could get a battery charger.
"Improvement makes straight roads, but the crooked roads without improvement, are roads of genius." — William Blake |
November 13th, 2011, 12:27 PM | #17 | |
Join Date: Dec 2010 Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125 Posts: 812
Good one! Just don't rely on it lasting over 24 hours and follow "A's" advice to ride. I have a trickle charger and clips on battery screws for easy hook up but still ride both bikes for 30-40 minutes in one clip weekly, on top of city usage et al. Good luck. |
November 15th, 2011, 08:35 PM | #18 |
Battery Tenderizer
http://www.harborfreight.com/automat...ger-42292.html Usually they go on sale for about $4. They also have solar ones you can use during the day. If you need a new battery, consider lithium. Mine's still going like a champ and has an extra amp of power too.
November 15th, 2011, 08:43 PM | #19 |
Internet Slut
Join Date: Sep 2010 Motorcycle(s): 04 FZ1, 07 FZ6 Posts: A lot.
just go for a ride for about 30 or 40 mins
November 15th, 2011, 09:50 PM | #21 |
MOTM - Apr '13
Ok battery is charged but now my bike is on fire... What should I do?
November 16th, 2011, 07:09 AM | #23 | |
Best to just go for a nice ride. Or use the battery tenderizer.
November 16th, 2011, 06:33 PM | #24 |
MOTM - Apr '13
I did it again....
November 17th, 2011, 12:08 PM | #26 |
MOTM - Apr '13
Yea, this time I just rolled it down the driveway and took off to work haha
November 17th, 2011, 02:56 PM | #27 |
November 17th, 2011, 04:43 PM | #28 | |
MOTM - Apr '13
It came a few hours after I had installed the grip heaters though
November 18th, 2011, 03:04 AM | #29 |
my bike died | joshuafrench | !%@*#$%!)@#&!%@ I crashed! | 4 | June 19th, 2014 12:38 AM |
Ok, so my bike just died on me. | arnoldc6 | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 16th, 2013 04:35 PM |
On my way to work my bike died!!!!!! | Stingray1000 | 1986 - 2007 Ninja 250R Tech Talk | 23 | June 15th, 2012 02:32 PM |
Bike died while riding | zem | 1986 - 2007 Ninja 250R Tech Talk | 44 | June 1st, 2011 02:09 AM |
Battery died, won't hold full charge? | ASecretNinja | General Motorcycling Discussion | 10 | August 20th, 2009 06:26 PM |
