May 6th, 2013, 02:10 PM | #1 |
Join Date: Mar 2012 Motorcycle(s): 2008 Ninja 250R Posts: 257
Chain/Sprocket Questions
As the title states, I have a few questions about a chain/sprocket combo. Mostly because my chain is almost 6 years old and before i joined here last year i didn't do much upkeep on it. Since i joined last year i maintained it to the best that i could of but because of my previous lack of maintenance, it shows. I bought a JT 15T to replace and i read on here that if you're going to replace the sprocket(s), best to do the chain at the same time so it'll wear even. For the rear sprocket i'm still deciding whether a 43T or 44T. I'm leaning more towards the 44T tho. Input on that?
Second question. Been looking around on here for advice on chains. From my understanding, the X-Ring chain is better than the O-Ring chain. Since its what drives my bike, I'll go a step better. Been looking at the D.I.D. 520 Pro-Street VX2 X-Ring. I know its 106 links but that chain comes with the clip link master. What type is better? Clip or rivet? Or are they the same as long as they're both installed properly? Or can i use a master rivet type on that chain if i buy it separately? Side note off main topic, I just had my bike inspected. The guy told me I'll need new rear pads soon. Since i was told on here, for lack of better terminology, to not use my rear brakes, I haven't used them since I joined here. Just the fronts. But the fronts are fine. Every time i searched for an answer, I couldn't quite find a straight one. But for the '08 ninjas, are the front and rear pads the same part number? Everywhere i looked they didn't have a drop down menu to select front/rear. If that's the case, I was just going to buy EBC Organic brake pads. They're ~$27 and I know I've searched and have seen that other people have used them as well. The fronts still have plenty of life left in them but when I replace them I plan on using those HH Sintered kind along with a Galfer SS line. |
May 6th, 2013, 03:47 PM | #2 |
MOTM - Sep '18, Feb '16
OK
Definitely change the chain with the sprockets. X ring is a very good chain. The link does not matter as long as it is installed properly. I like the clip type. But if you have the tool. Go with the rivet type. Yes 106 link 15/44 is good for a stock bike. If you are on flat ground or want better top end crushing the 43 is also good. If you have modified the bike a lot then try the 43. Now who ever told you not to use the rear break was wrong. Period. The best stopping is done with both breaks. You need to practice panic stopping in a controlled environment. Like a parking lot or track. Be careful. But practice breaking will save your life. The pads are not the same front to rear. At least I don't think they are. I could be wrong about that. The racing I do is one mile and 1/4 mile straight line stuff. I don't have front breaks. I don't really need any except for 10 mph in the pit. But I can tell you that stopping from over 100 mph with rear breaks is no problem. The rear break is very effective.
May 6th, 2013, 04:11 PM | #3 |
I guess I'll get the X-Ring chain, 106 links, clip type. No biggie. I believe i'll go with the 43T rear then since the mods list is growing.
And i'm wrong. i pretty much only use the rear brake when i have to stop quickly. But i use the front brake at the same and slowly pull it harder so that i don't use the rear brake so much that it locks up. I guess i shouldn't say that i don't use it. Mostly I time it right so that when i come up to a stop light/sign that i downshift to an almost complete stop before i use the brakes. |
May 6th, 2013, 04:11 PM | #4 |
Pads are identical front/rear on the new-gen. But many people run the sintered HH+ ones on the front, and the organic versions on the rear. Same exact size/shape pads, but just different compounds. If the front pads still have some life on them and you want to upgrade them, some people move the front pads to the back, and put the new ones on the front.
Racer X is right. It's not about never using the rear brakes in any circumstance, it's more about knowing how not to misuse them and cause more harm than otherwise.
May 6th, 2013, 04:15 PM | #5 | |
May 6th, 2013, 07:33 PM | #6 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Mid corner is about the only place to use the rear brake. Kevin Schwantz said he never touched the rear in his 500gp days. The rear wheel can be off the ground if you have good enough tires and brakes in a panic stop.
May 7th, 2013, 01:00 PM | #7 |
Join Date: Apr 2013 Motorcycle(s): Daytona 675, Ninja 250R Posts: 6
I hope no one minds I highjack the tread for a moment, I'm looking for a decent o ring chain but on a budget. Does anyone have any suggestions? I found a couple on eBay that look pretty good but not quite confident enough to pull the trigger.
Thanks and sorry for the tread jacking. |
May 7th, 2013, 01:37 PM | #8 | |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
I believe the one we have is a D.I.D. PM me to remind me so I can ask her.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
May 7th, 2013, 03:36 PM | #9 |
What about type of rear sprocket? Like aluminum or steel? JT or Vortex? Pros/Cons?
May 7th, 2013, 03:47 PM | #10 |
Fast-Guy wannabe
MOTM - Jan '13
Steel everywhere so with proper maintenance it will last you for ever.
May 7th, 2013, 03:48 PM | #11 |
Id go steel unless your racing and need a little extra...... I like my Sunstar so far. It was made in japan and everything.
May 7th, 2013, 04:01 PM | #12 |
Anyone know where I can find a steel red rear sprocket then? Lol I can only find them in aluminum
Chain for Sprocket Configurations | Maddawg | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 25th, 2014 07:13 PM |
Chain and Sprocket Question | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 25th, 2014 01:44 AM |
Getting a new chain and sprocket | kittyslasher | 2008 - 2012 Ninja 250R Tech Talk | 10 | December 9th, 2013 12:55 AM |
54-60t sprocket and chain | ninja250 | Items Wanted | 2 | July 26th, 2011 07:29 PM |
Sprocket questions | scotty | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 25th, 2010 02:28 PM |
