Old May 9th, 2009, 09:10 AM   #1
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
Front Axle Nut
Ahhh yes....tires....god bless them. Anyway, I have attempted and seemingly succeeded in changing the front tire on my ninja....with only one tire lever no less.
My question is: how much am I supposed to tighten that front axle nut (the one with the cotter pin in it)? I tried tightening it to a reasonable amount, but that made the front wheel hard to spin. Ninja250.org says that this may be attributed to the speedo drive not being aligned properly with the nubs on the fork, but I quickly double checked just now and I seemed to have gotten that part right.
Right now the nut is on, but its pretty loose. I've put the cotter pin in but I have reservations about how loose that nut is. The torque values for that nut are supposedly 88 N-m....there's no way that nut is anywhere near that value right now. Help?
Old May 9th, 2009, 12:41 PM   #2
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
james, just did my front tire couple of weeks ago...torque calls for 88 N-m just like you said. (i have an 03)
i'd suggest removing and replacing the wheel on the forks from scratch.
(yeah, do it again...) JUST to make sure, then try specific torque.
i was taught to tighten to torque then back off to align to nearest cotter pin hole.
good luck.
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old May 9th, 2009, 02:17 PM   #3
Flashmonkey
Hey Steve. Yea there was a lull in the storm here (it was pouring pretty hard all morning) and I managed to sneak outside and redo the whole thing. Turns out that the speedo gear wasn't fully aligned with the teeth on the wheel....close but no cigar. This is what I get for working at night with no flashlights
Thanks for responding! And thanks Kelly for the PM.
Old May 9th, 2009, 03:06 PM   #4
lol... for you SO's sake, please have sex with the lights on!
Old May 9th, 2009, 09:03 PM   #5
Flashmonkey
Ya but what do I do about the blindfold?
Old May 9th, 2009, 09:32 PM   #6
komohana
komohana's Avatar
right on
Old May 9th, 2009, 10:57 PM   #7
Definitely take it off when you work on the bike.
Front Axle Castle Nut JLinde1339 1986 - 2007 Ninja 250R Tech Talk 8 December 9th, 2011 01:23 PM
Stock Rear Axle Nut Wrench + Extension indr 2008 - 2012 Ninja 250R Tech Talk 8 January 23rd, 2011 02:57 PM
Hitch Pin for rear Axle nut? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 3 July 6th, 2009 08:30 AM
axle nut torque? nate-bama 1986 - 2007 Ninja 250R Tech Talk 10 July 3rd, 2009 08:22 AM
Rear Axle Nut Rawr 2008 - 2012 Ninja 250R Tech Talk 16 May 22nd, 2009 08:40 AM
