Old August 31st, 2009, 05:31 PM   #1
NoobNinja
WTFBBQ?!
NoobNinja's Avatar
bigger rims
i searched and found alot on wider tires for our bikes and tires that you guys like what i couldnt find was something on actually getting a slightly wider rear rim for the bike for the wider tire to seat properly. any links or info is greatly appreciated.
im looking for an asthetic reason to do this. if i lose a tiny bit of power for having to turn a heavier rim i'll make adjustments with sprockets in the future but for now just lookin to do the proper way of upgrading rear tires. without squeezing them onto the stock rim.
i was thinking along the lines of a ninja 500 or 600 rear rim. two differetn rimes doesnt bother me seeing that i like cars with two different sets of rims on them why not the bike lol
Done-Aluminum Two bros slip on, Pro grip tank pad, Vortex swingarm spools.
Still in the works-Jet Kit, snorkel removal/K&N filter, Fender eliminator, L.E.D blinkers, Red wheel stripes,
NoobNinja is offline   Reply With Quote
Old August 31st, 2009, 07:38 PM   #2
Greg_E
Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R
Need to measure and see if there is room between the sides of the swingarm, I doubt you'll get 250 or 300 mm wide tire to clear the swingarm. Same goes for the front as you need wider fork spacing to fit the wider front tires.
Greg_E is offline   Reply With Quote
Old August 31st, 2009, 08:37 PM   #3
NJD022588
NJD022588's Avatar
Motorcycle(s): '09 Ninja 250R
I think the widest tire you can fit on the stock swingarm is a 150 - only 2 cm wider than stock.
NJD022588 is offline   Reply With Quote
Old August 31st, 2009, 09:51 PM   #4
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
I've only seen anything like that done if you replace the swingarm. There's a thread around here somewhere about a 2fiddy with an R6 swingarm and rear wheel. You might look into that.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old September 1st, 2009, 01:41 PM   #5
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Tim did a swingarm mod and put I think a 180 on it - you might check with him
Posted via Mobile Device
Old September 1st, 2009, 05:32 PM   #6
Sailariel
Sailariel's Avatar
The problem with going wider is that you add weight and lose the "Flickability" that makes this bike such a terror in the twisties.
Old September 2nd, 2009, 01:04 AM   #7
Sound Wave
Ramen Rider
Sound Wave's Avatar
someone put on a ninja 650r rear rim.... he was on another forum. i will see if i can find it. iirc, there was a bunch of fabricating he had to do.
Old September 2nd, 2009, 01:08 AM   #8
Sound Wave
Ramen Rider
Sound Wave's Avatar
here it is. he only went up to a 150 tire. the cool thing is that the design is basically the same, so it will look stock.
http://www.newninja.com/modification...-rim-and-tire/
Old September 2nd, 2009, 07:23 AM   #9
Greg_E
Nice but that break mount is scary, think I would find another way. I would also go with two new bearings with the proper ID and OD to fit, the bushing is probably fine but I think I would rather have the new bearings.
Old September 2nd, 2009, 07:59 AM   #10
Tims250R
Hppowdercoating
Tims250R's Avatar
Motorcycle(s): 09-250R
Ive done a few swap's and changes on my Bike...
FYI Biggest Tire you can fit on the stock 250R wheel & stock swingarm is a 160/60/17.. Its a Tight fit but will work...
I currently have a modded stock swingarm(made it 1'' wider) and 650R rear wheel.. its a 4.5" wide wheel .. Im running a 180/55/17 tire. But im changing to a 5" wide 05-636 wheel in the Next couple weeks to better fit the 180 tire..
Pm me if you need any info.. Btw the 08-09 250R, 650R,636 & zx10 have the same wheel Look/design for a couple years..
HP-POWDERCOATINGS.COM
http://i52.photobucket.com/albums/g2...100_3312-1.jpg
Tims250R is offline   Reply With Quote
Aftermarket rims? NikkitaNinja 2008 - 2012 Ninja 250R Tech Talk 15 November 20th, 2014 10:12 AM
Powdercoated Rims forevertwowheels Pictures 23 September 25th, 2011 08:41 PM
Rims... LittleNinja Items Wanted 0 March 27th, 2010 03:04 PM
Looking for Rims and Tires HA-Y-N NINJA Items Wanted 3 May 5th, 2009 05:45 PM
Rims tjkamper 1986 - 2007 Ninja 250R Farkles 1 April 24th, 2009 02:43 PM
