September 21st, 2017, 11:10 AM | #1 |
[motorcycle.com] - 2018 Yamaha XSR700 Sport Heritage Revealed for U.S.
After being available since 2016 in Europe, the Yamaha XSR700 is finally making its way to the U.S. and Canada. This new XSR uses the platform of the well-loved FZ-07 to create a retro-vibed roadster that slots into Yamaha’s Sport Heritage line. Key elements that transform the FZ into XSR are the new aluminum fuel tank, vintage-inspired headlight and tail lamp, and a new subframe to support the new vintage-style seat. Classy aluminum components provide bracketry for the front fender and radiator cover. Yamaha says the XSR makes for a good platform for customization thanks to removable tank panels and the removable steel subframe. Yamaha says the XS650 from the 1970s inspired its designers to draw up the XSR700. Remaining unchanged is the FZ-07’s 689cc inline-Twin with 270-degree crank and all the other mechanical bits, including its LCD instrumentation. The XSR includes ABS in its $8,499 MSRP. That’s a $1,000 premium over the ABS-equipped 2017 FZ-07. It’s scheduled to hit dealers in October and will be available in Matte Gray/Aluminum or the Raspberry Metallic seen here. 2018 Yamaha XSR700 SpecificationsMSRP$5,549Engine TypeLiquid-cooled DOHC inline twin cylinder; 8 valvesDisplacement689ccBore & Stroke80.0mm x 68.6mmCompression Ratio11.5:1Fuel DeliveryFuel InjectionIgnitionTCI: Transistor Controlled IgnitionTransmissionConstant mesh 6-speedFinal DriveChainFront Suspension41mm telescopic fork; 5.1-in travelRear SuspensionSingle shock, adjustable preload; 5.1-in travelFront Brake TypeDual hydraulic disc, 282mm; ABSRear Brake TypeHydraulic disc, 245mm; ABSFront Tire120/70ZR17 Pirelli Phantom SportcompRear Tire180/55ZR17 Pirelli Phantom SportcompWheelbase55.3 in.Length81.7 in.Width32.3 in.Height44.5 in.Rake/Trail25.0°/3.5 in.Ground Clearance5.5 in.Seat Height32.1 in.Fuel Capacity3.7 gal.Wet Weight410 lb. (claimed)Warranty12 months limited factory warrantyColorMatte Gray/Aluminum; Raspberry Metallic2018 Yamaha XSR700 Sport Heritage Revealed for U.S. appeared first on Motorcycle.com. Click here for full story...
[motorcycle.com] - 2018 Yamaha Star Venture Revealed | Ninjette Newsbot | Motorcycling News | 0 | June 5th, 2017 05:00 PM |
[visordown.com] - Yamaha XSR700 price revealed in Spain | Ninjette Newsbot | Motorcycling News | 0 | September 11th, 2015 10:11 AM |
[motorcycle.com] - 2016 Yamaha XSR700 Revealed + Video | Ninjette Newsbot | Motorcycling News | 0 | July 22nd, 2015 12:00 PM |
[motorcycle.com] - 2016 Yamaha XSR700 Revealed | Ninjette Newsbot | Motorcycling News | 0 | July 22nd, 2015 10:00 AM |
[visordown.com] - Yamaha XSR700 revealed | Ninjette Newsbot | Motorcycling News | 0 | July 22nd, 2015 05:20 AM |
