Go Back   ninjette.org > General > Off-Topic
Old December 10th, 2011, 02:22 AM   #1
cuong-nutz
cuong-nutz's Avatar
Electrical gurus
I was thinking (yes dangerous to do) during my long drive to my mother's how is it that no matter the orientation of the plug of an appliance or electronics to socket it still works normal? I'm mostly referring to ones that just use the two prong plug. Can someone explain?
HalfFast Racing Team
Old December 10th, 2011, 06:21 AM   #2
Skippii
Milkshake Drinker
Skippii's Avatar
Easy. Alternating Current alternates (obviously) so it goes back and forth--there is no direction.
"What a sweetheart."- ninja_sleeper to me
Old December 10th, 2011, 07:22 AM   #3
Skippii
Milkshake Drinker
Skippii's Avatar
Furthermore, most electronic things usually run off DC, and have a bridge rectifier which converts AC to DC. The rectifier has two identical AC inputs, one DC + output, and one DC - output. So anything that does require correct polarity will get it, regardless of input.
Old December 10th, 2011, 08:47 AM   #4
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
To help simplify what skippii said for those don't speak electronics:
The electricity that comes out of your wall is called Alternating Current (or AC). The 3 parts of the plug are hot, ground, and neutral. With AC the power does not have a positive or negative (like you see on batteries) and flows in both directions.
Then you have what they call Direct Current (or DC). This is where you find the positive and negative. In DC, the power flows from positive to negative and all devices that run on it are very sensitive to this. In DC if you hook up the power backwards it will do harm to the circuit.
In most electronic devices you plug in to the wall, they either operate on AC or DC. Those that operate on AC can plug into the wall in either direction and it won't matter, these are usually simple things like motors or lights. Those that have the plugs that can only go in one way usually are more complex and operate on DC. What they do is take the AC coming out of the wall and convert it internally to DC in order to operate. I hope this helps.
sombo is offline   Reply With Quote
Old December 10th, 2011, 06:57 PM   #5
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Polarized plugs are standard now on any device with a switch. The reason it's polarized is to make sure the switch is on the hot leg. Otherwise all the components of the device would still be hot even if the switch was off. Generally not an issue unless you're doing something stupid like working inside a device that's still plugged it. But it's there to protect you.
So if you were to file down a polarized plug and plug it in backwards, the device would still work like normal. But when you turned it off, the components would still be hot.
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
Old December 10th, 2011, 07:11 PM   #6
sombo
sombo's Avatar
Not always. Like I said, most of the stuff that is polarized has a converter in it. Most stuff that doesn't have a convertor and runs on AC doesn't worry about polarization.
Old December 11th, 2011, 03:26 PM   #7
CynicalC
CynicalC's Avatar
Yes always. Whether it has a converter in it is besides the point. Plugs are polarized so that the hot leg is switched and not the neutral. Obviously the device will work either way due to the nature of AC. But if the neutral leg is switched, the device is still hot and looking for ground. Whereas if the hot leg is switched, the device is neutral aka grounded.
Old December 11th, 2011, 03:38 PM   #8
Apex
Livin' the Minimoto Life
Apex's Avatar
This is true. 11 years of OSHA approved semi-conductor electrical safety classes will tell you the same. Polarization does matter.
To help them get around needing a ground, they must increase the insulation to an approved level and polarize the plugs to prevent electrocution. That is how they are deemed to be safe.
Old December 11th, 2011, 05:49 PM   #9
Sailariel
Sailariel's Avatar
Mark, Having lived on a boat for 14 years, I got quite adept at DC wiring. When we bought our house in 04, my wife asked me to wire in an electrical outlet for her. Guess what--DC and AC are quite different. I connected two wires and got knocked clear across the room--literally blew me out of my shoes. Lesson Learned: That is exactly why God put electricians on earth
Ninjette, Sold. New Bike: 2010 Honda NT-700V/VA, 73 Honda 550, 74 Honda 550
Old December 11th, 2011, 06:48 PM   #10
Skippii
Milkshake Drinker
Skippii's Avatar
To clarify something, when we say that AC has a hot and a neutral, we mean that neutral is 0 volts, and the hot lead changes from 169.7 volts, then down to -169.7 volts, then back up, 60 times per second. (169.7 is 120V times the square root of two). 169.7 volts of AC is equal in power to 120 volts of DC current through the same load.
Sometimes, with AC, though, BOTH leads are hot, even though they still use the same outlets as the Hot/neutral type. All kinds of electronic stuff will work just the same on this. This is called Balanced AC current. It is not very common, but it is used in places like recording studios where "clean" power is critical. In a circuit where both wires are hot, they are shifted 180 degrees out of phase with each other and each's peak voltage is reduced by half. This means that when one is at 0v, so is the other one, but when one peaks at 85v, the other one is at -85v.
The end result is that everything works exactly as it would with 120V standard AC...but you don't want to touch either wire even if it is switched off.
Old December 11th, 2011, 11:33 PM   #11
cuong-nutz
cuong-nutz's Avatar
Thanks for the refresher everyone! I totally forgot about AC/DC and the band Like they say, you lose what you don't use often.
Old December 12th, 2011, 06:09 AM   #12
HKr1
IC2(SW)
HKr1's Avatar
Thats the way it is on the ships. No neutral, both leads have 60v to get your 120v.
Old December 12th, 2011, 02:57 PM   #13
Skippii
Milkshake Drinker
Skippii's Avatar
I didn't know that about ships. Is that just because their power is inverted from batteries?
Old December 17th, 2011, 04:49 PM   #14
HKr1
IC2(SW)
HKr1's Avatar
No earth ground. Generators are steam driven, or back up diesel. Really gets you trouble shooting a piece of gear. Fuse panel would be A, B & C... So if you lost a phase fuse, two pieces(or more) of gear would be running strange in series.
Old December 18th, 2011, 06:42 AM   #15
Apex
Apex's Avatar
I don't miss working on a ship...
Question for all the tire/suspension gurus out there felo 2008 - 2012 Ninja 250R Tech Talk 4 February 19th, 2014 11:52 PM
[motorcyclistonline] - New Permatex® Liquid Electrical Tape Keeps Electrical Connect Ninjette Newsbot Motorcycling News 0 February 26th, 2011 01:20 AM
Calling all movie gurus... dubojr1 Off-Topic 23 February 6th, 2011 07:47 AM
Question for the bicycle gurus JokerSeven Off-Topic 32 June 25th, 2010 07:03 PM
HELPPPPPPPP! Ninja Gurus, I need your help! dkstariob 2008 - 2012 Ninja 250R Tech Talk 30 October 13th, 2009 01:17 AM
