August 17th, 2010, 10:59 AM | #1 |
Ride Rain or Shine
Join Date: Jul 2009 Motorcycle(s): '09 Ninja 250 Posts: 23
What Size Bulb Is This!?!?
...and if that is impossible to figure out from a picture alone, does anyone know how I could go about finding out what size it is?
The bulb on the right is a stock front turn signal. The bulb on the left is what my bike is currently using, however, because the person I bought it from installed aftermarket turn signals. At the time when I purchased the bike I didn't think it important what brand they were, which I immensely regret now considering the guy at the Kawi store couldn't tell me what kind of bulb it was without knowing the aftermarket signal brand. Here is a picture of the turn signals themselves (the clear part would normally face forward, of course. I just turned it to the side so you can see it clearly): Help! I'm tired of being scared everytime I make a right turn!
The Optimist says the cup is half full The Pessimist says the cup is half empty The Engineer says the cup is twice the size it needs to be. |
August 17th, 2010, 11:05 AM | #2 |
Join Date: May 2010 Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black Posts: 455
I would say it's nearly impossible to tell from that photo itself. Is there any writing on the base of the bulb? They usually have a bulb number imprinted on it.
'10 Ninja 250R SE Red/Blk Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents |
August 17th, 2010, 11:11 AM | #3 |
the search function is your friend...
http://www.ninjette.org/forums/showt...highlight=bulb
August 17th, 2010, 11:12 AM | #4 | |
Ride Rain or Shine
The only thing written on the bulb itself is "12v8w" The bulb slips into a little metal casing, and locks into it (the casing has the wire housing on the bottom of it). Would knowing the size (diameter) of the casing be of any help?
August 17th, 2010, 11:14 AM | #5 |
If Kim's link doesn't answer your questions, take the bulb to your local auto parts store and look for a 12volt/ 8 watt bulb with a similar base configuration.
August 17th, 2010, 11:20 AM | #6 | |
Ride Rain or Shine
August 17th, 2010, 11:23 AM | #7 |
g'luck. IIRC, that signal bulb is sort of an odd duck to find a suitable replacement. If you do find one, let us know.
August 17th, 2010, 11:42 AM | #8 |
Ride Rain or Shine
Does anyone know if the pre-gen turn signals are the same as the 08+? I wouldn't mind going over to the local Cycle-Salvage and wiring a new metal casing if it would fit the stock bulb I already have!
tail light/turn signal bulb size | ieathonda | 1986 - 2007 Ninja 250R Farkles | 20 | March 27th, 2015 06:48 AM |
Light bulb and Gauge bulb options | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 11 | August 21st, 2014 10:06 AM |
Does dead taillight bulb affect the license plate bulb? | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 3rd, 2013 06:05 AM |
WTB: Replacement bulb. Upgraded to HID? Sell me your old bulb! | CZroe | Items Wanted | 7 | October 25th, 2009 03:58 PM |
WTT: Size S Synergy Heated Gloves for Size M like kind | headshrink | Items Wanted | 0 | March 26th, 2009 01:45 PM |
