Old May 19th, 2009, 07:41 AM   #1
Rawr
Blue Blue Blue
Rawr's Avatar
Motorcycle(s): 2008 Candy Plasma Blue Ninja 250R
Rear Axle Nut
anyone know the size of the socket needed to remove the rear axel nut?
Rawr is offline   Reply With Quote
Old May 19th, 2009, 09:05 AM   #2
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
From KKIM's DIY on chain adjustment:
Then using a 24mm socket and a breaker bar on the nut and a 17mm wrench on the other end...
Old May 19th, 2009, 09:15 AM   #3
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
Or if you still have the toolkit, it'll have the proper size wrench and an extension bar for it.
Nemy is offline   Reply With Quote
Old May 19th, 2009, 04:16 PM   #4
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
so, whatcha doin that you need to remove the nut? I'm curious...
Old May 20th, 2009, 09:49 AM   #5
Rawr
Blue Blue Blue
Rawr's Avatar
rear wheel alignment
Old May 20th, 2009, 10:04 AM   #6
Which method are you planning to use to check the alignment? Here's the DIY thread that has some decent info in it for our bikes.
Old May 20th, 2009, 09:22 PM   #7
Rawr
Blue Blue Blue
Rawr's Avatar
well i was just planning on using the marks that are provided on the swing arms
Old May 20th, 2009, 09:30 PM   #8
read the DIY that Alex linked.
Old May 20th, 2009, 10:51 PM   #9
ShishkaBOMB
The string method is very good, i followed that DIY and it was actually really simple. It might look confusing by just reading it but don't be discouraged.
I wouldn't do it again though, too much time involved especially if you're gonna do it every time you take the rear wheel off. After i aligned with the string i counted the threads and they were the same. So aligning by counting the leftover threads on the adjuster bolt is very sufficient.
ShishkaBOMB is offline   Reply With Quote
Old May 21st, 2009, 07:43 AM   #10
Rawr
Blue Blue Blue
Rawr's Avatar
well the main reason y i was just going to use the marks is cause i know my front wheel is off...i have to wait till i get some bolts that i stripped the heads off of back before i take them off and redo the front wheel...i just wanted to get the back done and i think it should be any trouble since the factory marks are there.
Old May 21st, 2009, 09:29 AM   #11
Those factory marks are useless; they are highly inaccurate. Make sure that the number of threads showing on both of the adjustment bolts at the back of the swingarm, and your alignment is pretty darned close.
Old May 21st, 2009, 10:04 AM   #12
Rawr
Blue Blue Blue
Rawr's Avatar
ah cool ill try that
Old May 21st, 2009, 01:14 PM   #13
do you guys ever read the links that are included with people's replies?
Old May 21st, 2009, 01:33 PM   #14
HKr1
IC2(SW)
HKr1's Avatar
LINKS
Old May 21st, 2009, 01:45 PM   #15
Originally Posted by HKr1 View Post
LINKS
In it, I get my ass handed to me, but more importantly it goes over all the points Alex made about the hash marks on the side of the swingarm adjuster plates being useless and the correct method to insure the rear wheel is correctly aligned.
Old May 21st, 2009, 01:54 PM   #16
Old May 22nd, 2009, 08:40 AM   #17
Rawr
Blue Blue Blue
Rawr's Avatar
yea...according to the thread counts it is fine...so i dont have to worry bout it anymore =p...i can check it properly once i get the front wheel turned back correctly
Front Axle Castle Nut JLinde1339 1986 - 2007 Ninja 250R Tech Talk 8 December 9th, 2011 01:23 PM
Stock Rear Axle Nut Wrench + Extension indr 2008 - 2012 Ninja 250R Tech Talk 8 January 23rd, 2011 02:57 PM
Hitch Pin for rear Axle nut? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 3 July 6th, 2009 08:30 AM
axle nut torque? nate-bama 1986 - 2007 Ninja 250R Tech Talk 10 July 3rd, 2009 08:22 AM
Front Axle Nut Flashmonkey 1986 - 2007 Ninja 250R Tech Talk 6 May 9th, 2009 10:57 PM
