May 25th, 2009, 10:09 PM | #1 |
Join Date: Mar 2009 Motorcycle(s): 2009 Kawi Ninja 250R Posts: 114
Just a friendly reminder about your shifter
So i've read on the forums that this has happened to other riders before.
On the way home today, I had no clue why I kept having trouble with my upshifts and it would often fall back into the N between gears. Right when I got onto my driveway, my shifter fell off! I pushed the bike into the garage and took the pic. Luckily for me it fell off at home and the bolt was on my driveway. Things could have gotten much worse... The bike is only a few months old and just cracked the 1k miles mark. Remember: Make sure all your critical bolts are tight! |
May 25th, 2009, 10:13 PM | #2 |
Year-round rider
Join Date: Feb 2009 Motorcycle(s): 2008 Ebony 250R Posts: 37
Yikes, glad it didn't fall off while you were on the road!!! I'll be checking mine out for sure tomorrow.
"Do not be too timid and squeamish about your actions. All life is an experience." - Ralph Waldo Emerson My Albums |
May 25th, 2009, 10:32 PM | #3 |
be sure to use some locktite.
May 25th, 2009, 10:58 PM | #4 |
Join Date: May 2009 Motorcycle(s): Ninja 250r & scooter125cc Posts: 60
how this happened?
May 25th, 2009, 11:01 PM | #5 |
Join Date: Oct 2008 Motorcycle(s): 08 250 R Posts: A lot.
Good reminder to check things out! It is amazing that the factory overtightend and GLUES the bar ends with the RED loctite, but shifters keep falling off.
In our best interest to check things. Thanks for the reminder.
"Don't let adverse facts stand in the way of a good decision" Colin Powell |
May 25th, 2009, 11:39 PM | #6 |
Join Date: May 2009 Motorcycle(s): 2005 ninja 250 Posts: 23
wow crazy, thanks for the reminder!
May 26th, 2009, 01:16 AM | #7 |
Newb..... on a steeek! :D
Join Date: Feb 2009 Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow Posts: A lot.
Had the same thing happen to me a couple weeks ago heading towards Seaworld. I was getting to the light to turn on to the Seaworld road and started downshifting when all of a sudden there was nothing there. I looked down to see the shifter and bolt (thankfully) just hanging there. I couldn't fix it there so I waited for the light, turned onto the road to Seaworld and used the next turn lane not being used to put it back on using the tools in the tool bag. Now I make sure to check it before riding. I was also glad that the ninjette could still go from a dead stop in 3rd gear which is what I was in when it fell off.
May 26th, 2009, 06:33 AM | #8 |
Join Date: May 2009 Motorcycle(s): 09 Ninja 250R Posts: 18
Thanks for the heads up, i will be sure to check it before i go out and ride today.
Also if tightening all the bolts for the shifter doesn't resolve the problem of your bike falling back into the previous gear when up-shifting. What else can be done? Lube or adjust the clutch cable? Any help would be appreciated! |
May 26th, 2009, 06:39 AM | #9 |
Same thing happened to me going down the road. I stoped at a parking lot with one bolt about to fall out and the other laying on the foot peg. I'm glad I always cary the tool kit that came with the bike.
May 26th, 2009, 06:40 AM | #10 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Thanks for letting us know what to look for.
Addicted to anything that has an engine and rolls. |
May 26th, 2009, 06:50 AM | #11 |
Join Date: Mar 2009 Motorcycle(s): '09 Ninja 250 Black Posts: A lot.
The bolt on my new kickstand was loose and never thought of checking it before reassembling the pin that was attached to the broken screw i had and fell off in my boss's driveway before going for another ride. My safety switch pin was beginning to point downwards and the killswitch would of been turned on. I hate to think of what would of happened if this happened when riding. We put locktite and made sure it was in all the way. I think we should do pretrip on our bike everytime we go riding just like i do when i have to drive the big rigs. I now have a tube of locktite with my tool kit.
May 26th, 2009, 11:02 AM | #12 |
adjust your shift lever height.
May 26th, 2009, 01:04 PM | #13 |
How do i go about doing that? I searched and found a nice post about it with a diagram (the one where it says to make the shifter as parallel as possible to the adjuster ) however im having trouble figuring out exactly how to adjust it.
May 26th, 2009, 02:46 PM | #14 |
there are two nuts on the shift linkage arm. loosen the nuts (careful... one of them is reversed threaded) and just turn the rod. you will see the shifter go up or down. adjust it to where you want and then retighten the lock nuts. you nay have to do this a couple of times after test riding the bike to see if the shifter is in the proper position.
some pics in here that might help... http://www.ninjette.org/forums/showthread.php?t=15136 |
May 26th, 2009, 04:00 PM | #15 | |
Motorcyclists are friendly | Kscreations08 | General Motorcycling Discussion | 8 | May 12th, 2014 07:28 PM |
Just a friendly reminder... DON'T TAILGATE!!! | tjkamper | Ride Reports | 19 | March 22nd, 2013 11:41 AM |
Friendly reminder how not to ride | TheMojoRider | Videos | 9 | August 27th, 2011 12:37 PM |
Reminder | islanderman7 | General Motorcycling Discussion | 2 | May 18th, 2009 10:58 AM |
