July 1st, 2015, 12:16 AM | #1 |
Join Date: Mar 2015 Motorcycle(s): Ninja 250 2006 Posts: 17
Sleeper
I thought I'd share my bike
Ex500 engine Zx600d rear rim Zx600e rear rotor machined to a smaller diameter(the width is thicker than the zx600d's) Zx600d 530 rear sprocket narrowed to fit a 520 chain Old school aftermarket aluminum mufflers Put the rear turn signal bulbs and sockets in the tail light Higher wattage hi/low headlight bulb 2002 r6 front end that I got through eBay from another forum member. Didn't know he was a forum member when I bought them. Painted the front wheel and forks stock black. Shinko slicks. 120/60r17 150/60r17 Notched woodruff key to advance timing. Mikuni needles and uni filters K&N crank case breather Autocock trickery to make it a plain old petcock. Messed with the tank vent so it doesn't hold the stock 1/4psi of pressure. Woodcraft clipons. Ex500 stock adjustable levers. And I know I'm forgetting a bunch of stuff but you get the idea Coming in the mail is a 04-05 gsxr600 shock. The interwebs says that it's a bit too long and spring too soft. Ex500 longer dog bones will lower the rear back down and the Ex500 cantilever will lower the linkage ratio to stiffen the rear. It's fast enough to get in trouble on and handles well. The idea is to keep it looking like a stock bike and I am trying to get the stock front fender and belly pan to fit but they are far down on the priority list. I hope you all dig it as much as I do |
July 1st, 2015, 12:22 AM | #2 |
Pictures
July 1st, 2015, 08:22 AM | #3 |
"scandal!"
Hah! Neat!
July 1st, 2015, 08:25 AM | #4 |
Nice!
July 1st, 2015, 09:33 AM | #5 |
Fighting Texas Aggie '05
I like it!!!!!
July 1st, 2015, 12:29 PM | #6 |
Ninjette Lurker
Join Date: Jun 2014 Motorcycle(s): 2003 Ninja EX250 (Cafe, Naked, Wreckurrected) Posts: 72
that's real cool mate.
It looks great, and I bet is a hoot to ride. how was getting the 500 motor in the 250 frame? |
July 1st, 2015, 06:42 PM | #7 |
Freedom for Germany
July 2nd, 2015, 02:20 AM | #9 |
Glad everyone likes it.
The 500 was a pain. A little more than three weeks to accomplish. If I had to do it again I would of reinforced the frame and then notched the frame near the carbs to push the engine an inch rearward. The 250 frame is an inch and a half shorter from the swing arm to the neck than the 500 frame so I ended up with hardly any room to squeeze in a radiator fan. Other than that it was as much of a pain as you'd expect, Suki. |
July 6th, 2015, 11:22 AM | #10 |
Ninjette Lurker
haha, that sounds like a good bit of work. But you have a sick ride. do you use slicks on the road? is that legal even?
July 6th, 2015, 10:45 PM | #11 |
Questionably. The rear slick says dot and does not say not for highway use, the front is just the opposite. I think it's a screw up by shinko, no way should the rear be dot. It's not a big deal though, a fix it ticket is $10-15 here and and isn't a impoundable offense.
July 6th, 2015, 10:54 PM | #12 |
Knee drag peace sign from this weekend. I got the gsxr shock on the day after and wish I could of evaluated it at the track.
July 13th, 2015, 07:12 AM | #13 |
I would love to take that thing to the track just to see people do the slack jaw as people try and figure out what is up lol
