May 16th, 2016, 08:09 PM | #1 |
3d printing things for the 250?
Anyone ever try and making something for their motorcycle to be printed on a 3d printer? I have access to one, and i was thinking that i could make some headlight brackets to fit the 250 so i can install a round headlight conversion.
What other accessories or parts would make decent projects? Thingiverse has some great models. Seems the sv650 is really popular. But making a bracket should be fairly easy. Just need the diameter of the fork tubes. |
May 16th, 2016, 10:12 PM | #2 |
Join Date: Dec 2015 Motorcycle(s): Yamaha Virago XV1100 87, Yamaha Virago XV750 93 Posts: 1
how about the blinker bases
the ones in the front sure would be easy to sell...
May 16th, 2016, 11:11 PM | #3 |
Join Date: Feb 2012 Motorcycle(s): 2012 Ninja 250R Posts: 362
I have thought about this for some time. How about 3-D printing a device to replace the passenger seat on a new-gen for mounting hard luggage? The sides would be flat and parallel to each other. The top would be flat and level. The bottom would be printed with a shape identical to the seat, complete with the mounting tab slot, the four support legs, and a place to bolt the seat lock peg.
This would serve as a platform for mounting a rack or topcase bracket, and hard sidecase carriers. Mounting hard luggage on a new-gen Ninja 250 has been nearly impossible, requiring fabrication beyond the scope of most of us. This may be a simple way to solve the problem. Like the weight of a passenger sitting upon the seat, the weight of the luggage would sit on top of the frame as it should. All the hard sidecase projects I've seen on this site utilize brackets hanging from the tiny bolts under the tail, which I would not trust. My diagrams are pretty crude, way out of scale, but I think you'll get the idea. Last futzed with by Kevin1956; May 17th, 2016 at 12:48 AM. |
May 17th, 2016, 05:31 AM | #4 |
Fighting Texas Aggie '05
3D print a race fairing stay.
May 17th, 2016, 06:24 AM | #5 |
Good ideas, but if you are doing any sort of structural thing metal is what you need. Plastic will eventually break i think. It would also need to be fairly small. I think the 3rd printer i have printes 5" cubed so you are limited in that way.
May 17th, 2016, 06:27 AM | #6 |
here is an example of a printable object
http://www.thingiverse.com/thing:521562 |
May 17th, 2016, 06:27 AM | #7 |
i can adjust that to fit a ninja 250, and make the design a little different.
May 17th, 2016, 06:30 AM | #8 |
Vintage Screwball
MOTM - Mar '16
Pre gens have 36mm forks.
08+ have 37 mm forks.
Goin' fast on slow bikes! |
May 17th, 2016, 08:28 AM | #9 |
I'm crazy,your excuse is?
Do a gauge pod for stock gauges to go into for that cafe look. Also some fork clamps for aftermarket turn signals and rear turns as well.
May 17th, 2016, 04:49 PM | #10 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
A 3D printed airbox that can be taken out easily, accepts the OEM filter, and still provides the benefits of having a proper plenum. Project is on hold until I can get access to a decent print area.
May 18th, 2016, 09:38 AM | #11 |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
A quick look at the Thingverse page,
1. Throttle Lock/cruise control 2. Wrist rest 3. Kickstand plate 4. Windshield Spoiler for more wind deflection. 5. Action Camera mount 6. Chain Lube Helper 7. An automatic Chain Luber (might have to make parts and use some thing else and the oil receptacle.) Didn't see one there but it would be cool to make. 8. EZ Pass holder 9. Knee Sliders 10. sun visor for GPS/phone |
May 19th, 2016, 10:08 AM | #12 |
٩(͡๏̯͡๏)۶
Join Date: Nov 2014 Motorcycle(s): 09 Ninja 250 held together by duct tape and zip ties Posts: 122
Cup holder
3d printing moto parts | alex.s | Off-Topic | 38 | November 12th, 2014 07:49 AM |
Shapeways 3d printing | eddiekay | General Motorcycling Discussion | 8 | July 17th, 2014 08:33 PM |
water transfer printing, pretty cool | subxero | Videos | 4 | April 15th, 2014 02:22 AM |
3D printing | Joshorilla | Off-Topic | 176 | February 27th, 2014 02:22 PM |
Printing new gauge faces? | CZroe | 2008 - 2012 Ninja 250R Farkles | 7 | May 10th, 2012 12:55 PM |
