March 5th, 2012, 09:12 PM | #1 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
Pregen rear spring shock alternatives
Hi, I love my little Ninja but I find it uses a lot of travel in the rear suspension even though I'm no heaveyweight by any means(150 lbs). I was curious about others opinions about different rear springs and rear shocks. I've read that the Ninja 500 shock works on our 250s, does the spring fit also? What are some of the other shocks that fit our bikes and improve the hindling and ride. Please share.
Thank you, GA |
March 5th, 2012, 09:52 PM | #2 |
get a lightly used shock from a new-gen 250R. It raises the tail by about an inch, is a little stiffer with less pogo-ing, and has adjustable pre-load. Mine ran me like $50, and it was completely worth it.
also, any shock that you can find that works for a new-gen, will work for a pregen, and will raise the tail about an inch. the argument against the ex500 shock is that you have to crank the preload all the way up because it's actually a softer spring than the ex250 shock. It's also shorter. This means it is stiff, and negatively effects turn in. I love my J-series rear shock |
March 5th, 2012, 10:55 PM | #3 |
Thanks Chris, that sounds like what I'm looking for.
March 5th, 2012, 11:12 PM | #4 |
Newb..... on a steeek! :D
Join Date: Feb 2009 Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow Posts: A lot.
Best source of information on this subject found here.....
I was using a used 2008 new-gen shock on my 1994 for almost 2 years before I traded her in. I also got progressive springs for the forks and it made it a whole new bike that handled great.
March 6th, 2012, 12:31 AM | #5 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
i got a zx600 air shock and i love it i got it for 14 plus shipping on ebay. really good for 2 up and for daily use. Def help with ur project needs but its a bit on the haevy side.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
March 6th, 2012, 09:32 AM | #6 |
Great feedback, thanks guys.
March 7th, 2012, 05:10 AM | #7 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
That's what I'm running, too!
"What a sweetheart."- ninja_sleeper to me |
March 7th, 2012, 07:05 AM | #8 |
how u running urs?
im on 14psi and soft setting
March 7th, 2012, 01:23 PM | #9 |
Milkshake Drinker
I have no idea.... I adjusted it a few years ago when I installed it and haven't messed with it since.
Posted via Mobile Device |
March 7th, 2012, 01:31 PM | #10 |
Milkshake Drinker
Wait...you use air instead of nitrogen in the shock?
March 7th, 2012, 02:16 PM | #11 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
March 7th, 2012, 11:06 PM | #12 |
Milkshake Drinker
Yes, I've got a pretty good background in chemistry.
Certainly enough to call BS when someone sloshes a quart of water and soap around on my rim to mount a tire and then tells me to only use "dry nitrogen" to inflate it. But in a motorcycle shock that came from the factory with nitrogen and has a lot more seals and dampers and stuff? I don't know that much about shocks. More experienced track riders have told me the water in air can be bad. You're the first person who's suggested using air, so I was a little surprised. I'm not saying pure nitrogen will change the handling significantly, just that it might be better for the shock in the long-term. On the other hand, I bought it used on ebay, so the previous owner might have filled it up with his farts for all I know.
May 22nd, 2012, 10:54 PM | #13 |
Join Date: Jul 2011 Motorcycle(s): 2019 Ninja 400, 2009 KLX250-SF, 2014 Zero S Posts: 269
zx600 shock review
okay guys, tell me more. I'm thinking about the zx600 shock but I'm worried it will end up being too stiff. I want to have enough compliance for rough roads sometimes, but better than stock. I weigh 185 lbs and I feel I sag the OEM shock more than half it's travel. Do you ever think this shock is too stiff? How adjustable is it?
May 23rd, 2012, 05:17 AM | #14 |
I went with a newgen shock. Bolt in replacement.
May 23rd, 2012, 09:01 AM | #15 |
Go for the new-gen shock. The 600 will most likely be too stiff.
May 23rd, 2012, 10:57 AM | #16 |
The ZX-600 shock is known to be pretty stiff when installed on an EX-250, so it's a good choice for the really big boys and those who do a lot of two-up riding (the Kawasaki Concours bike uses essentially the same shock with a bit more adjustability added in, which should tell you something about how stiff it would feel on a light bike with a light rider).
I use the Hagon rear shock. Very good product, and very adjustable to accomodate any rider's weight. It's a touring/spirited street riding shock, not a remote reservior racing type shock. |
May 25th, 2012, 09:27 AM | #17 |
Milkshake Drinker
I'm 165 and i think the ZX600 is comfortable. It's also easily adjustable for compression and rebound damping.
May 30th, 2012, 09:11 PM | #18 |
Separate rebound and compression adjustments? I thought the only adjustment was the air pressure? Is this the shock you have:
http://faq.ninja250.org/wiki/File:ZX600_shock.jpg |
May 30th, 2012, 09:13 PM | #19 | |
June 1st, 2012, 08:23 AM | #20 | |
Milkshake Drinker
Notice the remote reservoir I have on mine by the passenger peg... Crap, I wonder what shock I have??
June 1st, 2012, 11:15 AM | #21 |
can you get a closer pic? idk what shock you have. is it the fat style like the 600zx?
June 1st, 2012, 05:58 PM | #22 |
Join Date: Aug 2010 Motorcycle(s): 1981 Honda Cx500 Custom, 2002 Ninja 250 Posts: 289
The pregen 500 was a direct swap. Made a big difference on handling for me. I am comfortable. I don't ride two up. I am 275lbs plus gear.
"Rudeness is a weak persons attempt at strength." |
June 1st, 2012, 07:25 PM | #23 |
Join Date: Mar 2012 Motorcycle(s): <2008 250R> Past Bikes:06 GSXR600 89 CBR1000 78 Hawk 400 86 Ninja 600R 86 & 87 FZ600 81 GPZ550 71 CB360T Posts: 228
'08 rear shock
I have an shock off my '08 5000mile bike. I just did a GSXR shock conversion. I have not put any effort into selling the shock. If you're interested, let me know.
Have you ever read the King James Bible? To say speed kills is akin to saying guns kill, neither of which is true. |
June 3rd, 2012, 10:25 AM | #24 |
Join Date: May 2012 Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150 Posts: 146
PM sent.
Jim Moore Jax, FL |
June 4th, 2012, 04:10 PM | #25 |
Sorry for the delay. PM replied to.
June 6th, 2012, 04:02 AM | #26 |
Fighterer in Training
Join Date: Jul 2011 Motorcycle(s): 2001 Ninja 250R Posts: 316
I just ordered a GSXR shock myself. Did it affect your ride height any? Seems they are about the same length (new gen shock and GSXR). Also, you only need to make mods to the shock for it to fit, and not the frame. Is that correct?
June 7th, 2012, 02:45 AM | #27 |
I mod'd the knuckle only and then spaced out the dogbones. Here are some links to consider:
http://faq.ninja250.org/wiki/GSXR600_shock http://www.ninjette.org/forums/showthread.php?t=59486 Also, I included to some pics of my own conversion. Are you doing this on a pregen? It lowered the back slightly. I compensated by lowering the front 7mm.
June 7th, 2012, 05:27 AM | #28 |
Very cool. Thanks for the info! I saw that 250 wiki, good stuff there. Did you have to replace the top of the shock? I thought it said that they ordered a new eye for the top of the shock...
Edit: Yup, on a pregen. Last futzed with by JLinde1339; June 7th, 2012 at 07:39 AM. |
June 7th, 2012, 01:19 PM | #29 |
OK, I have a new-gen rear shock on the way for my 98. On my CBR I had to put jackstands under the rearsets to hold the frame up. Looking at the Ninja, I think if I put my bike on the centerstand I can simply unbolt the old one and bolt up the new one. Is that right? Would taking the wheel off make it easier?
I weigh about 160 without gear. How many clicks of preload should I use? Thanks,
Jim Moore Jax, FL |
June 7th, 2012, 02:36 PM | #30 |
Yes you do! I have a tracking number too. PM you shortly.
I would suspend the rear wheel over the seat (using rope or a tie-down) once you have the frame supported.
June 7th, 2012, 02:41 PM | #31 |
I missed that. I did have to mod the top of the shock. I drilled it out to fit the 12mm stock hardware.
June 8th, 2012, 05:21 PM | #32 |
June 8th, 2012, 06:59 PM | #33 |
Right. Stock GSXR is 10mm, stock 250 is 12mm. I used an Irwin brand 15/32 drill bit (about $7.50) and it worked perfectly! A drill press would have been ideal, however, I just went real slow with a hand drill and made sure I started out good and kept the bit lubricated as I was drilling to keep it cool.
June 11th, 2012, 01:43 PM | #34 | |
Milkshake Drinker
http://www.ebay.com/itm/1997-KAWASAK...sories&vxp=mtr
June 15th, 2012, 01:50 PM | #35 |
Thanks again. That shock makes a big difference. Simple install, too.
Jim Moore Jax, FL |
June 15th, 2012, 03:43 PM | #36 |
Happy it all worked out!
July 3rd, 2012, 11:06 AM | #37 |
Ok, I got my shock, GSXR 600/750. Apparently it mounts to the gixx vertically on top, as there is a bracket in the eye with a threaded bolt on top. I've been trying to get that bracket off with pb blaster, to no avail. Prolly gonna drill the bolt out tomorrow, leaving just the eye. But the bracket rotates as I try to loosen the nut, leading me to think that the eye is rubber, and not metal. Can anyone confirm that? Would make drilling the actual eye out much easier, since I could do that myself with a dremmel, rather than trying top get should of a friend to hit it with a drill press...
February 28th, 2016, 04:35 PM | #38 |
Join Date: Feb 2016 Motorcycle(s): 2003 ninja 250 Posts: 2
Helllo all, totally newbess here. I have a ninja 250 from 2003. Everything is stock and after riding a dude around on the back of my bike last summer. The rear shock is super shot. I don't need or want a race quality shock, nor can i afford one. I just need the ride to not feel like on riding a goddamn horse anymore. I see some of you mentioned you can grab a shock off a newer model ninja and install it on an older model. I am specifically curious about what years this "backwards compatibility" exists within or what other inexpensive shocks/year/make/models work. Finding a shock is totally new to me so when i purchase one on ebay or what not i want to be sure i get one that will actually work on my bike.
Thank you all! <3 |
February 28th, 2016, 05:44 PM | #39 |
Any rear shock from a NewGen 2008&up will work on any PreGen 88~07.
NewGen has a stiffer spring better suited for rider about 200 lbs, and it also offers a preload adjustment to set sag. http://faq.ninja250.org/wiki/Install...k_on_a_Classic It's the best bang for the buck, check eBay for a used one. Also remember that suspension must match, so if you can get fork springs from a NewGen Ninjette, which are stiffer .65kg Vs .44kg. Then it's a matter of cutting them down to get the rate you need, then just use spacers to set the sag, also changing the fork oil effects dampening, @InvisiBill can explain it better than me. http://faq.ninja250.org/wiki/Rear_suspension_upgrades On my Ninjette SERENITY, I cut/spacer a pair of EX500 springs to a weight of .85kg, with 15wt fork oil, and installed a ZX600 shock, also with 15wt oil. I weigh about 220lbs with gear.
February 29th, 2016, 06:48 AM | #40 | |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Removing Rear Shock Spring? | TBC | 1986 - 2007 Ninja 250R Tech Talk | 22 | December 29th, 2014 03:11 PM |
Pregen rear shock | Josh_kcco | Motorcycle-related | 0 | March 7th, 2014 11:23 PM |
Best rear shock for the pregen | Josh_kcco | 1986 - 2007 Ninja 250R Tech Talk | 17 | March 6th, 2014 08:13 PM |
What Rear Shock/Spring will work - EX300? | accident-prone | 2013 - 2017 Ninja 300 General Discussion | 90 | March 26th, 2013 06:38 PM |
Newgen rear shock in Pregen. | 02337 | 1986 - 2007 Ninja 250R Tech Talk | 35 | October 31st, 2012 11:25 AM |
