June 22nd, 2014, 10:43 PM | #1 |
Join Date: Jul 2013 Motorcycle(s): 1990 GPX250, 1998 Suzuki DRZ400E Posts: 26
Won't run over 1k rpm
Hi,
I'm having a bit of an issue. My 1990 gpx250 is being quite temperamental. Over the last two days it has started to not want to run, it will start and either die straight away or will run at 1-1.5k rpm even with wide open throttle. And then if you come back in an hour some times i will start straight up and other times it will continue with the use. The bike hasn't idled since owning it but it has run fine for the last month (I've owned it a month). What could be a possible problem? Could it be the clutch switch? The bike used to refuse to kick over when the clutch was pulled in in neutral but now it doesn't mind. Last futzed with by bowerbird100; June 23rd, 2014 at 01:48 AM. |
June 23rd, 2014, 06:50 AM | #2 |
Doesn't sound like it would be a switch problem to me.
Have you looked at the plugs? They may tell you something. Is the air filter good and the intake snorkel clear? Something could be blocking the intake. I would also drain the tank completely and refill with fresh gas and a fuel system cleaner (just the proper amount - not too much). Drain the float bowls first and look at what comes out - does it look like fresh clean gas? Is the tank free of rust? If not, you may need to clean the filters/screens. Chances are if that doesn't do it you'll need to remove the carbs and clean them carefully. Do some research into what needs to be done first, or you'll need to pull them and do it all over again. |
June 23rd, 2014, 05:02 PM | #3 | |
Well I spent several hours with the help of my father to stip down the bike enought to be able to move the airbox and release the carbs The float bowls were drained until they ran clear fuel, when they first started to drain they both looked a rusty colour. The fuel coming out of the tank is clear And it had a filter in the fuel line to the carbs. It still didnt run properly if at all. We pulled the airbox back till it was off the carbs and then ran the bike, it was great ran well. I sprayed the very gunky mesh in the airbox with carb cleaner till it was clean and washed the foam component of the filter in filter cleaner Ran alright. Put Everything back together and its back to its same old antics of not running Is it the filters? Or the airbox? Would pod filters fix it? Are pod fitlers available? |
June 23rd, 2014, 05:36 PM | #4 |
clogged main jets. pull the carbs again and do a more thorough cleaning. ie take off the bottom bowls, and poke wire through the main jets
June 23rd, 2014, 05:45 PM | #5 | |
I'll drain the tank as well. Just a few questions. I also have another ex250 that was allegedly running alright when it was still in pieces, it is now a parts bike. Is there any variation with the carbs over the difference models of ex250's? I have the carb off the other bike so can I clean and use it instead, it looks cleaner. Can you recommend a source that I will be able to follow to clean the carbs? Will I need to sync the carbs? |
June 23rd, 2014, 05:51 PM | #6 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
yes it makes no sense
process of elimination needed First take out the air filter and check there isn't anything blocking the intake rubbers, you should be able to get your hand in far enough to poke your finger in the rubbers and tell. Then try with the airbox connected but the filter out and the snorkel off Then snorkel in and still no filter If that runs okay get new filter foam $10 a square foot off ebay I wouldn't recommend pods right now because you will need to rejet the carbs which is major league This is probably it v What may have happened is that someone cut any old piece of foam to fit in the filter but most general foam passes much less air than filter foam so with it in you are running very rich. That's my best guess |
June 23rd, 2014, 06:00 PM | #7 |
there are variations. i couldn't tell you exactly what they are. mostly the throttle linkage and choke
step 1: locate carbs step 2: take the carbs out and remember where everything came from and what hoses you took off step 3: take off the bowls step 4: remove the main jet and spray it with carb cleaner and poke it out here's an example from another type of jet: step 5: put it all back together step 6: have a beer
June 23rd, 2014, 06:09 PM | #8 |
^^^ This is good but please first try the filter foam as I mentioned in my post above. If that is all it is then the carb strip will be wasted effort.
June 23rd, 2014, 06:49 PM | #9 |
June 23rd, 2014, 06:52 PM | #10 |
June 23rd, 2014, 07:07 PM | #11 |
If you got odd looking gas out of the floatbowls I would completely drain the tank (remove it and dump it upside down while shaking it vigorously into a pan so you can see what comes out) and refill with fresh gas before tearing into it too far. I would also add 1 oz per gal of Techron Concentrate fuel system cleaner to the fresh gas. Use 87 octane without ethanol if you can get it, or the lowest grade that's available without ethanol - sometimes that is Premium.
Have you looked at the plugs? |
June 24th, 2014, 04:03 PM | #12 | |
I have not looked at the plugs mainly because I don't know how to The bike get 95 octane (RON) Which is the aus octane measure system. 91 is almost always with 10% ethanol Then 95 Then 98 |
June 24th, 2014, 05:41 PM | #13 | ||
How to Read Your Spark Plug |
June 24th, 2014, 05:48 PM | #14 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
This shows various spark plug conditions: http://www.dansmc.com
This computer won't let me link directly to the site, so you may have to look around to find the spark plug pics. |
June 24th, 2014, 09:08 PM | #15 | |
No idea of what size the main jets are because Ive had the bike 4-5 weeks, was running fine except for refusing to idle until one day it wouldn't run over 1k and then an hour alter it was fine, I went for an hour ride and the next day it did it again except it hasn't run right again since except when the airbox was disconnected from the carbs. I will look over it again when I get home and may be able to get some pics. |
June 24th, 2014, 09:09 PM | #16 | |
At school at the moment
June 25th, 2014, 06:23 PM | #17 |
That's either a sign your filter has too much oil on it or your crankcase is spewing oil into the airbox via the crankcase breather tube. Too much oil on the filter will disrupt airflowand cause the engine to breath poorly. This may also explain the gunk on the mesh.
I'd have a look at the carb boots and airbox cap to make sure they are clean and unobstructed. There's no reason why the bike should not be able to run with the airbox on and the filter removed. |
June 26th, 2014, 12:22 AM | #18 |
well i cleaned the jets out using peice of brass wire and 60psi of air.
all of them excpet the left pilot jet. it woudlnt come out it was unscrewed off the thread but refuesed to come out. only 3 milimeters and it would have been free but nope, not happening so i soaked it with carb cleaner while the carb was upright several times and then blew the air through another hole that exited the pilot jet so i hope that is enough. i may put the carb back in tonight if dads feel like it after work or i may have to wait till tomorrow. ill keep you posted on how it goes. i will also keep an eye on the bottom of the air box now that i have cleaned it and see if any more black oily residue appears |
June 26th, 2014, 01:45 AM | #19 |
Join Date: Jan 2014 Motorcycle(s): GPX250, ZZR250, CT90 Posts: 57
Where in N.S.W are you? I'm in Taree.
Check your oil level to make sure it is not over full. It can become over full from the carbs flooding, leaking fuel into the sump & diluting the oil. They usually don't run right with fuel in the sump. Carbs could be flooding intermittently. Could also be intermittent electrical fault, dropping spark on a cylinder. You really do need to get those plugs out for inspection. |
June 26th, 2014, 05:04 AM | #20 |
I think all i want to do is die at the moment.
the oil level is weird looking through the sight glass. we just spent two hours trying to get the airbox back on the carbs. the bike worked without the airbox and ran fine i need sleep for school tommorow and i am in menangle so taree is a bloody long way going to sleep and try again tomorrow :'( |
June 26th, 2014, 08:20 AM | #21 | |
I have made a tool by bending the last cm of an electricians screwdriver at 90 degrees to run round the rubber a bit like those power machines in tire depots that ease them onto the rim. Get the inside half over then use this around the outside section Looks a bit like this Image cedit pelicanparts.com Ideally you could get the Kawasaki designer round at gunpoint and not release him until he has done it, but that is probably illegal, even in Menangle Last futzed with by Ninjinsky; June 28th, 2014 at 02:37 AM. |
June 27th, 2014, 07:00 PM | #22 | |
I too have often wanted to get the designers to work on the products they have made. In the heat of the moment have also wanted to threaten violence against them, or get a bill passed which mandates engineers to perform every job in the repair manual, before the model is released for sale. |
Bike won't run above 5K rpm | edward2014 | 1986 - 2007 Ninja 250R Tech Talk | 12 | October 30th, 2014 08:51 AM |
Tach/RPM won't light up | NinjaNoob23 | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 6th, 2014 06:53 AM |
Help! Won't run. | xaple | 2008 - 2012 Ninja 250R Tech Talk | 37 | August 9th, 2013 02:57 PM |
Won't run | Bblock | 2008 - 2012 Ninja 250R Tech Talk | 9 | August 6th, 2013 12:17 PM |
Won't "run right", won't idle, choke only, etc?? - SOLUTION HERE | Jiggyfly | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 16th, 2012 09:50 AM |
