Old September 20th, 2015, 03:36 PM   #1
bruce71198
bruce71198's Avatar
transmission
Does anybody know the purpose of the feature on these transmissions that does not allow you to shift from neutral to 2nd gear at a stand still?
Old September 20th, 2015, 04:24 PM   #2
To find neutral easily, not overshooting from first into second.
Old September 20th, 2015, 06:20 PM   #3
you can disable it if you want with some glue.
Old September 20th, 2015, 07:09 PM   #4
bruce71198
bruce71198's Avatar
Glue? I just removed the 3 ball bearings that prevented the synchro from sliding if the rear wheel wasn't moving.
Old September 21st, 2015, 03:59 AM   #5
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Is it causing a problem?
Worlds fastest 250 ninja
Old September 21st, 2015, 04:01 AM   #6
xXecuterXx2
ChocolateMilk Addict
xXecuterXx2's Avatar
Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock"
^^ Yeah is it? Ive found the positive neutral finder (name of the mechanism) is quite helpful
Burn Rubber, not your Soul.
xXecuterXx2 is offline   Reply With Quote
Old September 21st, 2015, 07:29 AM   #7
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Ditto. But it confused me for a minute when I first experienced it.
Old September 21st, 2015, 08:15 AM   #8
bruce71198
bruce71198's Avatar
Well I never paid much attention to it until I put my last engine together and took the bike for a spin around the parking lot. I can only shift between 1st, neutral and 2nd. Not that the positive neutral finder is my problem, I was just wondering about its purpose when this is the only motorcycle that I have worked on that has it. I pulled the engine and removed the lower half to access the trans and shift mechanism and all works well on the bench. Put it back together and won't shift past 2nd. Removed the detent spring and plunger and it will shift then all be it with no detent.
Old September 21st, 2015, 08:19 AM   #9
noobs have a hard time finding neutral because they hulkfoot it with their numb feet. the bike is made to be beginner friendly
Old September 21st, 2015, 09:43 AM   #10
Right - but it's not unique to the ninjette; the neutral-finder gadget is included in most Kawi transmissions, even those that aren't aimed at newbies (ZX-10R, ZX-14, etc.)
Old September 21st, 2015, 10:40 AM   #11
Racer x
Racer x's Avatar
It's a pain without it. Old race Did not have it. I think the old 50 cc aprilia RS 50 did not have anything like that. You really had to hunt for nutral. And you could find it easy when riding.
I remember going from first to second then back to first a lot look g for neutral. Can't remember what that was on.
Old September 21st, 2015, 10:53 AM   #12
zx10r is a newby girl bike. duh
Old September 22nd, 2015, 03:27 PM   #13
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
I had a similar issue....dumb question: is the shift pedal and linkage rod properly adjust? If it's not adjusted properly, the linkage collar on the shifter shaft will contact the front sprocket cover, not allowing the appropriate range of travel to internally shift the gears.
When I replaced my front sprocket to a 15T, I didn't pay attention to this. Jumped on bike and ripped done the street, only to find that I couldn't shift to 3rd. Went back and readjusted, good.
Old September 22nd, 2015, 03:52 PM   #14
bruce71198
bruce71198's Avatar
Well, after needlessly tearing down the trans to investigate the source of this issue, only to reassemble it and have the same problem, I took the shifter detent with the stiff "blue" spring and put it in this engine, problem solved. Talk about the long way there!
Last futzed with by bruce71198; September 22nd, 2015 at 03:52 PM. Reason: spellcheck
Old October 9th, 2015, 10:04 AM   #15
mgentz
Board Member
where did you get the "stiff" spring?
Old October 9th, 2015, 02:22 PM   #16
bruce71198
bruce71198's Avatar
Factory Pro
Transmission issues APEmike 2013 - 2017 Ninja 300 Tech Talk 20 April 27th, 2016 06:45 PM
Transmission question Desmoluci 1986 - 2007 Ninja 250R Tech Talk 7 July 14th, 2014 05:03 PM
blown transmission #2 alex.s General Motorcycling Discussion 40 September 12th, 2012 02:08 PM
blown transmission? alex.s 2008 - 2012 Ninja 250R Tech Talk 71 May 4th, 2012 03:33 PM
Clunky Transmission. Am I alone? walera 2008 - 2012 Ninja 250R Tech Talk 27 October 20th, 2011 10:33 PM
