July 5th, 2022, 09:51 AM | #1 |
[webbikeworld.com] - 2022 Ducati Superleggera V4 [Specs, Features, Photos]
Click here for full story...
The 2022 Ducati Superleggera V4: Carbon Everywhere With More Tech Than Silicon Valley Contents The epitome of engineering excellence, cutting-edge technology, and aerodynamic design. The 2022 Superleggera V4 represents the only motorcycle in the world approved for road use with a carbon fiber frame, swinging arm, and rims with an unbeatable power/weight ratio of 1.54 hp/kg. The 2022 Ducati Superleggera V4 remains unchanged for the 2022 Ducati lineup, but what is there to change? For starters, this is the world’s only homologated bike with a carbon chassis. Those biplane wings create more downforce than Ducati’s MotoGP bike, while its quoted power with the Racing Kit installed is 234 hp. It’s one of the most advanced Ducati Motorcycles ever made, featuring cutting-edge technology, a sleek design aesthetic, and a fearsome power-to-weight ratio. The Italian Manufacturer also gave the Ducati Superleggera V4 more tech than Silicon Valley. From advanced cornering ABS to multi-level traction control. Listed below for your pleasure:
Produced in a limited edition of only 500 numbered units and accompanied by a certificate of authenticity, the new Superleggera V4 is the most exclusive Ducati ever produced. The 2022 Ducati Superleggera V4 starts at MSRP: $100,000 USD / $120,000 CAD On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Ducati Superleggera V4 in one place. Model Overview </p>General Info
Main Specs
Competitors
2022 Ducati Superleggera V4 Specifications ENGINE Engine998cc,* Desmosedici Stradale 90° V4, lightened, counter-rotating crankshaft, 4 Desmodromic timing, 4 valves per cylinder, liquid-cooledPower224 hpBore x Stroke81 x 48.4 mmCompression Ratio14.0:1Fuel InjectionElectronic fuel injection system. Twin injectors per cylinder. Full ride-by-wire elliptical throttle bodies with aerodynamic valves. Variable length intake systemStarterElectricExhaust4-2-1-2 system, with 2 catalytic converters and 2 lambda probesTorque116 Nm (85.6 lb-ft) @ 11,750 rpm – 119 Nm (87.7 lb-ft) @ 11.750 rpm with full racing exhaustDRIVETRAIN ClutchHydraulically controlled slipper dry clutchTransmission6 speed with Ducati Quick Shift (DQS) up/down EVO 2Final DriveRegina ORAW2 chain ; Front sprocket 15; Rear sprocket in Ergal 42CHASSIS Suspension FrontFully adjustable 43 mm Öhlins NPX25/30 pressurized fork with TiN treatment, billet fork bottoms, lightweight springs, fully adjustable.Suspension RearFully adjustable Ohlins TTX36 unit with GP valve and titanium spring. Carbon fiber single-sided swingarm.Brakes Front2 x 330 mm semi-floating discs, radially mounted Brembo Monobloc Stylema® R 4-piston callipers with Cornering ABS EVOBrakes Rear245 mm disc, 2-piston calliper with Cornering ABS EVOTires FrontPirelli Diablo Supercorsa SP 120/70 ZR17Tires RearPirelli Diablo Supercorsa SP 200/60 ZR17Fuel Tank Capacity16 l – 4.23 gallon (US)ColorRed SLV4ELECTRICAL IgnitionSpark PlugsHeadlightLEDTail LightLEDDIMENSIONS Max LengthMax WidthMax heightWheelbase1.480 mm (58,3 in)Rake24,5°TrailSeat Height835 mm (32.9 in)Dry Weight159 kg (350 lb) – 152.2 kg (335.5 lb) with racing kitWARRANTY Warranty24 months, Unlimited mileageExtension 2022 Ducati Panigale V4 R Features CONCEPT Superleggera V4 is a project where excellence, engineering and dreams converge in a direction that is as ambitious as it is performative. New Superleggera V4 335.5 lb dry weight for 234 HP (in race configuration) for this incredible product. These numbers are achieved thanks to the full carbon fiber frame and a vast use of titanium and magnesium components. Crafting the Dream Superleggera V4 is crafted with all the passion, precision, and dedication to perfection Ducati has to offer. Shaping lightness into speed emotions with our most sophisticated engine ever, top of the line components and our most technologically advanced electronics. 2022 Ducati Panigale V4 R Photos 2022 Ducati Panigale V4 R Videos Superleggera V4: Performance Links Ducati Motorcycle Official Websites Social Media Links The post 2022 Ducati Superleggera V4 [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Ducati Panigale V4 R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2022 04:43 AM |
[webbikeworld.com] - 2022 Ducati Panigale V4 / V4 S [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 07:41 AM |
[webbikeworld.com] - 2022 Ducati Streetfighter V4 SP [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2022 01:11 AM |
[webbikeworld.com] - 2022 Ducati Streetfighter V2 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2022 12:54 AM |
[webbikeworld.com] - 2022 Ducati DesertX [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 19th, 2022 02:12 PM |
