July 6th, 2022, 09:41 AM | #1 |
[webbikeworld.com] - 2022 BMW R 1250 GS [Specs, Features, Photos]
Click here for full story...
The 2022 BMW R 1250 GS: A Taste Of Adventure. Contents The BMW R 1250 GS has been an iconic European bike for four decades and keeps inspiring with new features. It has maximum visibility thanks to a new LED adaptive headlight. With the help of supplementary features like seat heating and the seven riding modes, you can confidently handle any driving circumstance. The boxer engine enables you to experience remarkable performance and increased smoothness at low rotational speeds. Greater control in any riding circumstance is made possible by the variable BMW ShiftCam variable camshaft control, which enables more potent torque development over the whole engine speed range. There are many choices within the BMW Adventure lineup, a standard GS is more tuned towards on-pavement riding with the ability for light offroad, and the Adventure is aimed at more serious off-road challenges. For the 2022 model year, BMW offers a wide range of configurations including the 40th Anniversary Editions. 4 Color choices for the 2022 BMW R 1250 GS: Light White, Style Rally Package, Style Triple Black, and the 40 Years GS Edition. The 2022 BMW R 1250 GS starts at $17,995 USD / $21,795 CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW R 1250 GS in one place. Model Overview </p> General Info
Main Specs
Competitors
2022 BMW R 1250 GS Specifications ENGINE Engine 1254cc, Air/liquid-cooled four stroke flat twin engine, double overhead camshaft, one balance shaft and variable engine timing system BMW ShiftCam. Engine Power 100 kW (136 HP) at 7,750 rpm Bore x Stroke 102.5 mm x 76 mm Compression Ratio 12.5 : 1 Fuel delivery Electronic intake manifold injection Starter Electric Max Torque 143 Nm at 6,250 rpm DRIVETRAIN Clutch Wet clutch with an anti-hopping function, hydraulic activation Transmission Constant mesh 6-speed gearbox with helical gear teeth Drive Shaft drive CHASSIS Suspension Front BMW Motorrad Telelever; stanchion diameter 37 mm, central spring strut Suspension Rear Cast aluminium single-sided swing arm with BMW Motorrad Paralever; WAD strut (travel-related damping), spring pre-load hydraulically adjustable (continuously variable) at handwheel, rebound damping adjustable at handwheel Brakes Front Dual disc brake, floating brake discs, diameter 305 mm, 4-piston radial calipers Brakes Rear Single disc brake, diameter 276 mm, double-piston floating caliper Tires Front 120/70 R 19 Tires Rear 170/60 R 17 Fuel Tank Capacity 20 l Color ELECTRICAL Alternator Three-phase generator with 510 Watt nominal power Battery 12 V / 11.8 Ah, maintenance-free Headlight Tail Light LED Tail Light DIMENSIONS Length 2,207 mm Width 952.5 mm Height 1,430 mm Wheelbase 1,514 mm Castor 100.6 mm Seat Height 850 mm / 870 mm (OE lowered suspension 800 mm / 820 mm) Unladen weight, road ready, fully fueled 249 kg WARRANTY Warranty Extension 2022 BMW R 1250 GS Features The right mode for every adventure Tarmacked roads, wet roads or unpaved gravel roads: The seven riding modes of the R 1250 GS ensure optimum grip and superior handling at all times. When the vehicle is stationary, you can pre-select up to four riding modes individually in the menu, which you can then select quickly and conveniently during the journey using the riding mode button. The new dynamic engine brake control provides more stability and easy control of the bike in the Pro riding modes; it prevents the rear wheel from slipping or jerking. And in the new standard ECO Mode, you get the maximum range from every tank of fuel. See and be seen The perfect illumination for every curve: The adaptive headlights switch on automatically when the vehicle is tilted, providing optimum illumination of bends depending on gradient and payload – a significant plus in terms of safety and comfort. The multifunctional rear LED flashing turn indicators ensure an eye-catching appearance and even greater visibility. 2022 BMW R 1250 GS Photos 2022 BMW R 1250 GS Videos 2022 BMW R 1250 GS Style Triple Black – Best Adventure _ Full Review Did I Make The Right Choice? | BMW R1250GS TE Triple Black Links BMW Official Websites Social Media Links The post 2022 BMW R 1250 GS [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 BMW R18 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 09:25 AM |
[webbikeworld.com] - 2022 BMW R 1250 GS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 09:06 AM |
[webbikeworld.com] - 2022 BMW R 1250 RS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 08:32 AM |
[webbikeworld.com] - 2022 BMW S1000RR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 08:13 AM |
[webbikeworld.com] - 2022 Harley Davidson Pan America 1250 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 13th, 2022 06:33 AM |
