July 6th, 2022, 09:51 AM | #1 |
[webbikeworld.com] - 2022 BMW S 1000 XR [Specs, Features, Photos]
Click here for full story...
The 2022 BMW S 1000 XR: Touring? Sporty? Yes! Contents The design sheet for the S 1000 XR always has me thinking it came from a mad genius. Borrow the engine from the RR and the riding position of the GS bikes. Make it look like a tourer but not too much like one. An aggressive front fairing should solve that. Now stir it all together and you have a European-made delight. BMW has thrown the book of goodness at the S 1000 XR. Starting with the Dynamic ESA electronic suspension, BMW Motorrad Race ABS, revised aerodynamics, and fairing with an adjustable windshield. Riding Modes Pro (incl. HSC Pro, MSR, ABS Pro & DTC) is standard, and stepping up to the premium package will add heated grips, cruise control, Dynamic ESA Pro, Gear Shift Assist Pro, a center stand and a list that keeps going. The options list on this BMW is almost as long as the entire 2022 BMW model lineup, from M performance parts to multiple styles of panniers, this is the bike you order exactly as you want it. 3 Color choices for the 2022 BMW S 1000 XR: Racing Red 2, M Package, Style Triple Black The 2022 BMW S 1000 XR starts at $17,945 USD / $19,995 CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW S 1000 XR in one place. Model Overview </p>General Info
Main Specs
Competitors
2022 BMW S 1000 XR Specifications ENGINE Engine999cc, Water/oil-cooled 4-cylinder 4-stroke in-line engine, four valves per cylinder, two overhead camshaftsEngine Power165 hp at 11,000 rpmBore x Stroke80 mm x 49.7 mmCompression Ratio12.5 : 1Fuel deliveryElectronic intake pipe injectionStarterElectricMax Torque84 lb-ft at 9,250 rpmDRIVETRAIN ClutchMultiplate clutch in oil bath, slipper clutch, self-reinforcingTransmissionSix-speed synchromesh gearbox with spur gearsDriveChain drive, 17/45CHASSIS Suspension FrontUpside-down telescopic fork, diameter 45 mm, electronic self-adjusting rebound/compression damping (Dynamic ESA)Suspension RearAluminium double-sided swing-arm, central spring strut, electronic preload adjuster,* electronic self-adjusting rebound/compression damping (Dynamic ESA)Brakes FrontTwin disc brakes, diameter 320 mm, floating discs, radial four-piston fixed calipersBrakes RearSingle disc brake, diameter 265 mm, twin-piston floating caliperTires Front120/70 ZR 17Tires Rear190/55 ZR 17Fuel Tank Capacity5.2 gal (20 L)ColorLight White/M Motorsport, Racing Red 2, Triple BlackELECTRICAL Alternator493 WBattery12 V / 9 AhHeadlightTail LightLED Tail LightDIMENSIONS Overall Length91.8″ (2,333 mm)Overall Width36.1″ (917 mm)Overall Height55.5″ (1,411 mm)Wheelbase59.9″ (1,522 mm)Castor4.5″ (116 mm)Seat Height33″ (31.1″ with optional lowered suspension)Unladen weight, road ready, fully fueled498 lbs (226 kg) WARRANTY WarrantyExtension 2022 BMW S 1000 XR Features A curve that makes you addicted: our torque. The engine of the S 1000 XR is based on the high-performance engine of the RR and was optimized according to the XR for uncompromising long-distance performance: among other things, special camshaft profiles and designated manifolds deliver impressive torque from the middle and the widest usable speed range in its class. The longer gearbox in the upper gears ensures smooth running which you can feel and hear. More dynamic thanks to the lower weight. Dynamism is also a question of mass. Even fully equipped, the S 1000 XR weighs a full 22 lbs less than its predecessors. In the lightest configuration, this bike is ready to ride at just 498 lbs. You wont miss a single ounce, but you will feel each individual one on every yard. In the form of better acceleration, higher agility, shorter braking distances, and easier maneuvering. Engine and performance. Typical to the XR, the engine is uncompromising on long distances and designed to be sporty. Dynamic ESA Pro. A new race-inspired valve technology and a shim package: for unprecedented suspension adjustment range between long distances and the racetrack. Striking front design with Pro headlight. Aggressive at all times of day: the fierce, sport front design with LED light. Accessory range like Carbon engine guard. Whether it’s high-quality milled parts or carbon fibre equipment such as the engine guard: Our M Performance parts from the factory or as accessories are developed for true enthusiasts. Optimized weight. The low weight delivers better acceleration and higher agility. In other words: more riding enjoyment and a sporty head start. The TFT display with BMW Motorrad Connectivity. The 6.5 TFT display replaces the instrument panel. BMW Motorrad Connectivity connects smartphone, bike, and helmet via Bluetooth. For navigation, favorite song, and conversations. Case system and top case. The integrated magnesium case holder is lightweight, completely uncoupled, and self-centring. 2022 BMW S 1000 XR Photos 2022 BMW S 1000 XR Videos 2022 BMW S 1000 XR | A Comfort Touring Bike Why We Love The 2022 BMW S 1000 XR Links BMW Official Websites Social Media Links The post 2022 BMW S 1000 XR [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 BMW R 1250 GS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 09:41 AM |
[webbikeworld.com] - 2022 BMW R18 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 09:25 AM |
[webbikeworld.com] - 2022 BMW R 1250 GS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 09:06 AM |
[webbikeworld.com] - 2022 BMW R 1250 RS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 08:32 AM |
[webbikeworld.com] - 2022 BMW S1000RR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 08:13 AM |
