April 7th, 2013, 03:36 PM | #41 |
InfoWhore
Join Date: Oct 2012 Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC Posts: 628
All your going to be doing is "cleaning the the edges" the rest will be tring to get it loose with a few tools that ill be bringing.
Everyone, go buy a dirtbike hurry |
April 7th, 2013, 04:52 PM | #42 |
Join Date: Apr 2013 Motorcycle(s): Ninja 250 2010 Posts: 38
Successsss
Using the back piece of the hammer we got it out.
Using the metal piece that wasn't covering the engine case. EFF YEA! With the help of @skilletmo |
April 7th, 2013, 05:16 PM | #43 |
So i just removed the plates and they are all pitch black and the steel plates have some brown burn marks too on the edges. There is no gasket like i expected either... So now that they are black and looked so abused, do you think we should go ahead and buy the plates and gasket that i linked above in the other posts? @Motofool @DaBlue1
-skilletmo |
April 7th, 2013, 05:31 PM | #44 |
InfoWhore
Here are the pics
April 7th, 2013, 06:36 PM | #45 | |
Normally, skidding discs don't produce noise but heat into the oil while pulling the bike. I would measure every element with a caliper. If you don't have one, then go ahead and order the discs and the springs.
April 7th, 2013, 06:55 PM | #46 | |
dirty boy
MOTM - Apr '14
^ this Any signs of excessive wear on the basket? While you have it apart might as well pull basket and check out the bearings |
April 7th, 2013, 08:30 PM | #47 | |
InfoWhore
I dont have a caliper but im sure my uncle has one in his shop (He owns a mechanic shop) but i feel like that can be the only problem(the clutch set).... the noise was clearly coming exactly from there when i put my ear to it. The prev owner said it was ( but then again he is a dumbass who put sealant so...). Also whenever its in neutral it makes that loud ass noise, then it goes into 1st gear making a little noise then 2nd-6th it makes no noise. I feel like the only thing it can be is the clutch set. If i get this set that the man assured me that nothing is wrong and has only 2000 miles on it, then i feel like it would replace everything including the plates, case, and springs. Then the only thing i would have to replace IF it is the problem is the bearing and rod thing. So, this being said, should i just tell him to buy it already?!?! I mean if its not the plates then what could it be? I think we have to just take the dive and buy it, its only 40$...
April 7th, 2013, 09:02 PM | #48 | |
That is a weird noise the one you describe. Did you turn it by hand while in neutral?
April 7th, 2013, 09:21 PM | #49 | |
InfoWhore
No i didnt, i can if that would make a difference tomorrow? I googled "noise" or "screeching noise" coming from clutch and some people have that issue but all say different reasons. Idk, ill tell him to order it and hopefully it will work with new oil and a filter. Also i will go tomorrow to his house and put it on and spin it in neutral.
April 7th, 2013, 09:26 PM | #50 |
InfoWhore
Its kind of like this noise but a little louder and coming from the exact place, a video of a v-storm...
April 8th, 2013, 05:52 AM | #51 |
Now I see how it sounds,...........but still believe that something is eating something inside.
If I am such a pain is because I don't want you guys to go through the whole process just to end up with new parts and oil and having the same noise. The clutch is a very simple mechanism: it either works (has enough friction to transfer the torque from the crankshaft to the tranny) or it doesn't (the discs slip). In summary, it is a sandwich pressed together by springs: there is nothing in that package to produce such a noise. Once the clutch's lever is released, that sandwich becomes a solid brick and part of the crankshaft and little gear. However, some parts may wear out and become noisy when working, such like the gears, the damping device, the bearings and the pulling mechanism. It is also possible that the noise comes from the transmission or the cam chain. Pull the spark plugs out, so you can turn the engine (counterclockwise only) fast enough to hear any abnormal noise without the discs and springs installed. Just a few ideas to consider
April 8th, 2013, 07:24 AM | #52 | |
I agree with what Motofool says. Looking at one of your post, you said..."Whenever I start his bike it makes a screeching noise in neutral, whenever I put it in first and pull the clutch is it stops, then I release the clutch and slowly put throttle. It makes the noise again and then i start going and the noise stops." You never really said how it shifted or rode. Was the clutch lever hard to pull? Is there any evidence of metal in the oil screen? The tranny has constantly meshed gears and is spinning even while in neutral. It is very possible that one or more gears is damaged (teeth chipped or worn or not moving like it should) or something as simple as the clutch push rod or bearing. This is thought. To see if the noise is in the gears or not, is to put the bike on a rear stand and turn the rear wheel while in neutral to see if the squeal is present in absence of the clutch. However you may not get it going fast enough to replicate the sound. Did yours squeal like the one in this video? |
April 8th, 2013, 08:52 AM | #53 | |
Hopefully the new clutch plates fixes the pipes. If not.. Just something else to do then. |
April 8th, 2013, 08:52 AM | #54 |
It's like a clicking sound..
April 8th, 2013, 10:47 AM | #55 | |
April 9th, 2013, 03:05 PM | #56 |
InfoWhore
As of right now we are waiting for parts, i will update when we receive them. I am going to check his oil screen tonight and see if there are metal chunks inside.
Kenny you will need to get this item, its 5$ shipped. If you want faster shipping so it comes before saturday then it will be a little more. But im in no rush, so you chose. Oil Screen Gasket
April 9th, 2013, 03:49 PM | #57 | |
I just picked the standard shipping. |
April 9th, 2013, 04:09 PM | #58 | |
InfoWhore
Everyone, go buy a dirtbike hurry Last futzed with by skilletmo; April 9th, 2013 at 08:33 PM. |
April 9th, 2013, 06:12 PM | #60 | |
There is bearing between the shaft and the cage, another entering the transmission, another between the puller and the front plate. The gears are the ones transferring rotation from clutch to transmission. There is a sprocket behind the cage for the cam chain.
April 9th, 2013, 08:29 PM | #61 |
InfoWhore
Could that be the problem? Are you talking about the piece with the bearing through it? And it doesn't look like its bent, but ill re-check when i go to his place.
April 9th, 2013, 08:30 PM | #62 | |
InfoWhore
I wish someone had this problem, the one bike he gets, it has a problem that is so frustrating and not obvious like other ones....
April 11th, 2013, 01:59 PM | #64 |
April 11th, 2013, 03:52 PM | #65 |
MOTM - Sep '18, Feb '16
I hate to be the one to say it. But I am 99% sure its over. Is the gray stuff metal?
April 11th, 2013, 04:02 PM | #66 | |
That RTV has been in the way of abundant lubrication. Again, something has been eating something inside that engine.
April 11th, 2013, 04:11 PM | #67 |
dirty boy
MOTM - Apr '14
all that red stuff? is that the same type of liquid gasket crap you scrapped off the outside of the case? Would make sense that all that stuff came off on the inside and clogged the filter/screen causing oil flow issues.
April 11th, 2013, 04:36 PM | #68 |
April 11th, 2013, 04:41 PM | #69 | |
But yes, there is metal in that glump of goooo. |
April 11th, 2013, 04:42 PM | #70 |
I have seen orange spaghetti destroy a number of engines. I would pull it and at least drop the bottom of the case and inspect and clean it.
April 11th, 2013, 04:47 PM | #71 |
April 11th, 2013, 04:51 PM | #72 |
Not necessarily; but it will take deeper surgery, cleaning and inspection, as advised by Eric above.
The metal debris could come from the clutch. The really bad thing would be that the main bearings of the crankshaft were deprived of lubrication and failed, because that repair would be complicated and expensive. Even if those are OK, you will need to make sure that there is no restriction in the narrow conduits for lubrication. Sorry to see all those debris in a new-to-you bike
April 11th, 2013, 04:59 PM | #73 |
Hard to say without looking at the inside. I'm thinking tranny and crank damage looking at the metal on the oil screen. At this point you might as well drop the engine and pull off the heads and lower case cover to see what else is going on there. I would say it would be cheaper to buy a new/used engine, of course you can always rebuild it, but it will probably be more hassle than it's worth.
With the amount of RTV in the crankcase, there's no telling where else it might be in the oil pump and passages. There was probably more metal than that in the oil and it was drained out. The red hot exhaust was a indicator of some extreme friction and lack of lubrication going on in the cylinders. See this thread |
April 11th, 2013, 07:09 PM | #74 |
There are three bad things to this story. First I can't get past the red pipes. Second it the noise. Now metal.
April 11th, 2013, 07:15 PM | #75 | |
The guy basically lied to us and said the bike was running just fine. We thought we could fix it by just, you know replacing the clutch plates. Sigh! If everything gets too expensive Im going to ask for my money back. But Im pretty sure that @skilletmo and I can fix this! |
April 11th, 2013, 07:17 PM | #76 | |
Im pretty sure we can fix it though if you think its just from the clutch. When @skilletmo comes over we will work on it even more and update everyone! |
April 11th, 2013, 08:44 PM | #77 |
InfoWhore
I agree, i think its more then the clutch. Like a termite eating the gears and tranny. We will see what replacing the clutch does, if not i will personally call that douchebag for lying to kennith. An easy win in court if he does not comply.
April 23rd, 2013, 03:00 PM | #78 |
So we are finishing up the bike right now. But quick question is the clutch rod suppose to move up and down in the case before we attach the clutch cable to it or is it normal before we put the cable on
"You know it's a bad day when you jump out of bed and miss the floor." |
April 23rd, 2013, 03:03 PM | #79 |
We need an answer ASAP , please!
April 23rd, 2013, 03:07 PM | #80 |
It drops in and has to rotate into its normal position to catch the end of the clutch rod.
Helping out a LEO friend PLEASE pass this along! | garth285 | Off-Topic | 5 | October 28th, 2014 05:13 AM |
Clutch :: Friction Plate & Metal Plate Install and Wear Questions | abhijitz | 2008 - 2012 Ninja 250R Tech Talk | 12 | June 21st, 2013 10:45 AM |
helping a friend start her 250, quick battery question. | cerberusrex25 | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 30th, 2012 07:38 PM |
Helping a friend out: water in exhaust! | EthioKnight | 2008 - 2012 Ninja 250R Tech Talk | 33 | July 23rd, 2012 06:15 PM |
Helping a friend with a part out! Lots of stuff 08+ all for sale!! | Kevin2109 | Motorcycle-related | 108 | April 5th, 2012 01:24 PM |
