April 23rd, 2013, 03:08 PM | #81 |
Join Date: Apr 2013 Motorcycle(s): Ninja 250 2010 Posts: 38
Thank you so much, we will update soon!
"You know it's a bad day when you jump out of bed and miss the floor." |
April 23rd, 2013, 03:49 PM | #82 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
The exhaust would not turn red from clutch plates. Chances are the sealant clogged the oil filter and screen causing the engine to starve of oil. The extreme heat caused by oil starvation would cause the exhausts etc. to turn red.I would try to hassle this guy who ripped you off and see what will come of it
April 23rd, 2013, 04:13 PM | #83 |
April 23rd, 2013, 04:14 PM | #84 |
April 23rd, 2013, 04:21 PM | #85 | |
We are almost done, all we need to do is put the clutch cable on right. When pressing the clutch in there is no tension, can anyone help us with this? Posted pic of how we put it back on.
Also we are planning to sue him if he does not give the money back. Basic buisness law, if a minor buys an item from any one on craigslist then the minor can ask fro a full refund back or whatever he has owed on it if from a dealer. When purchasing anything you are making a "contract". I am 17. Quote:
April 23rd, 2013, 04:23 PM | #86 |
Dang. Remind me not to sell to a minor. I bought my bike at 17, but my parents were with me and signed all the forms with me to give legal consent etc etc.
April 23rd, 2013, 05:32 PM | #87 |
Is it becuase there is no oil? I read something on other bikes about the rod that we posted a picture of earlier and how it need to be adjusted but i dont see how it needs to be adjusted since it only fits in one way... If you try turning it, it wont go in all the way. So i think that is eliminated. any one have any ideas? Would really apreciate it.
April 23rd, 2013, 05:53 PM | #88 |
I believe there should be resistance when pulling in the clutch even without oil. But I've never abused a clutch to the point of needing to be replaced so this is just an educated guess.
April 23rd, 2013, 06:02 PM | #89 |
You put it in wrong. See this thread http://www.ninjette.org/forums/showp...0&postcount=12
April 23rd, 2013, 06:06 PM | #90 |
I think you may have installed it wrong too
April 24th, 2013, 05:56 AM | #91 |
What Blue said.
http://www.ninjette.org/forums/showp...61&postcount=3 That shaft has not engaged the clutch plunge at the cover and it is not pulling it and forcing the clutch's springs.
April 24th, 2013, 07:47 AM | #92 |
InfoWhore
Join Date: Oct 2012 Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC Posts: 628
Wow Alex.s is post really helps! Thanks!
I will try this tomorrow.
Everyone, go buy a dirtbike hurry |
April 25th, 2013, 06:00 PM | #93 |
The clutch rod locked in place and seems to be in position and it can't go anymore forward and it's all the way in. Is there a special trick to putting it in?
I read the directions and it seem to be pretty basic, just put it in until it falls and locks? Help please.
April 25th, 2013, 06:17 PM | #94 |
Here is what the rod looks like.
April 25th, 2013, 06:18 PM | #95 |
April 25th, 2013, 07:40 PM | #96 |
I don't understand what your confusion is, sorry
To test it: Relocate the cover and the mechanism. Do not add oil. Using a crescent wrench or something as a lever, force the arm clockwise. You should feel some degrees of angular movement acting against the force of the springs. If you don't feel that, something is still not working properly between the mechanism and the clutch.
April 25th, 2013, 08:02 PM | #97 |
Join Date: Apr 2012 Motorcycle(s): 1976 CB550 Cafe, 2011 Ninja 250, 1999 Honda CR125 Posts: 264
I might have missed it, but have you really dug into this thing before dealing with the clutch basket/plates? I'm thinking that sealant could have pretty well cleaned house. As much as you probably don't want to, I would strip that thing completely down before I ran it again. If you get the manual (I believe you can do that right here on the forum) it will walk you through the entire thing. Be confident and organized, and you'll be disappointed by how easy it is.
Other than that, I'd suggest contacting the PO and seeing if he will work with you to make things right. Maybe he honestly didn't know that there was more of a problem. If he's an honest dude, he should work with you to make this right. If not, chalk this one up as a big time learning experience. |
April 26th, 2013, 09:32 AM | #98 |
Ill make a video when I get home and showing you the step by step on what we did to the clutch cable.
If nothing works. Ill strip everything and start all over again.
April 26th, 2013, 12:15 PM | #99 | |
I'm honestly just about to take this to the shop and just have them fix it an pay the bill. Sigh.
April 26th, 2013, 03:22 PM | #100 | |
April 26th, 2013, 03:29 PM | #101 |
I dont think you can sue when someone calls you about a faulty borderline fraudulent sale. Try to find another engine I guess.......
April 27th, 2013, 04:26 AM | #102 | |
Disconnect the cable from the bottom lever and do what I explained above. This is a lemon case, but I don't know how any lemon law applies to used bikes in your area. Hope @Alex, @Jiggles or someone else has some legal advice to share. The seller knew the bike was trash, IMHO.
April 27th, 2013, 06:32 AM | #103 |
Just looking at the video, the lever is still not in correctly. It should be hard to push up on it (towards the cable) with your fingers. Also the clutch lever and adjusting nut is nowhere close to being correct either. Look at the attached photo to see how much further down the lever is supposed to be, compared to where yours is.
April 27th, 2013, 06:51 AM | #104 |
Join Date: Mar 2011 Motorcycle(s): 2007 ninja 250r Posts: 374
Nothing you can do as far as the seller in texas as well as most states private party sales are as is sales. One thing you can do next time is take the bike to a shop before you buy it and pay for an inspection they usually charge 1hr labor to do that.
April 27th, 2013, 12:05 PM | #105 |
So it seems we got rid of the sound and we fixed the clutch and everything.. Now there is another problem. Hahah. The bike seems to be stuck in neutral. Shift to first gear the bike still doesn't move. Sigh.
We decided to not sue the guy because it would cost more to actually sue and get a lawyer and all.. Instead. Just learn from this and sell it on Craigslist. Not going to get my full 1750 back.. But at least Ill get something back.
April 27th, 2013, 12:50 PM | #106 |
Sell it and rip someone else off..........
April 27th, 2013, 01:26 PM | #107 |
As long as they fully disclose the issues with the bike and sell it 'as is' to a buyer who is fully aware of what they're buying for a fair price for what they're buying, it won't be a rip off to the buyer. It would be a rip-off if it's not fully disclosed.
If I was looking for a bike, I'd buy it. All it needs is a new engine and it's good to go. Buy that for 800 and an engine for 500, and it's good to go. |
April 27th, 2013, 07:05 PM | #108 | |
April 27th, 2013, 09:22 PM | #109 | |
The engine was shifting earlier,....and nothing has been touched in that department........... http://www.ninjette.org/forums/showp...8&postcount=52 Try this: http://www.ninjette.org/forums/showthread.php?t=129338
April 28th, 2013, 06:09 PM | #110 |
Lemon law doesn't apply to used bikes in any state that I know of, and it's borderline whether it applies to motorcycles at all in many.
Helping out a LEO friend PLEASE pass this along! | garth285 | Off-Topic | 5 | October 28th, 2014 05:13 AM |
Clutch :: Friction Plate & Metal Plate Install and Wear Questions | abhijitz | 2008 - 2012 Ninja 250R Tech Talk | 12 | June 21st, 2013 10:45 AM |
helping a friend start her 250, quick battery question. | cerberusrex25 | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 30th, 2012 07:38 PM |
Helping a friend out: water in exhaust! | EthioKnight | 2008 - 2012 Ninja 250R Tech Talk | 33 | July 23rd, 2012 06:15 PM |
Helping a friend with a part out! Lots of stuff 08+ all for sale!! | Kevin2109 | Motorcycle-related | 108 | April 5th, 2012 01:24 PM |
