Old July 27th, 2015, 02:02 AM   #1
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
FZR250R Speed testing
Work done:
New piston rings
New base and head gaskets
New cam chain
Things to change:
Correct size/profile rear tyre (130-70-17, has a 140 on it)
55 tooth rear sprocket (currently 57)
Linkin is offline   Reply With Quote
Old July 27th, 2015, 05:21 AM   #2
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
so how fast does it go?
Old July 27th, 2015, 07:10 AM   #3
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Seems to run on the cold side.
I think you need a new lens on your speedometer. This one is very cloudy.
Are the roads always that congested?
Old July 27th, 2015, 03:08 PM   #4
Linkin
Down Under
Linkin's Avatar
$1.60
It has a new thermostat and new coolant also , plus wind chill is pretty cold when its less than 10 deg c outside
Old July 28th, 2015, 06:53 AM   #5
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Originally Posted by Linkin View Post
$1.60
I am assuming that is in KM, so about 100 mph
Old July 28th, 2015, 03:14 PM   #6
Linkin
Down Under
Linkin's Avatar
Correct, I have to change the rear sprocket and both tyres to standard and try again
Old July 28th, 2015, 05:52 PM   #7
sharky nrk
sharky nrk's Avatar
Little bike sounds amazing
Old July 30th, 2015, 04:03 PM   #8
Linkin
Down Under
Linkin's Avatar
In about 2 weeks time I'll be taking it do the drags to see what sort of time it can do on the 1/4 mile. Most estimates are about 15.0-14.5
Going to see if I can beat that
Old August 12th, 2015, 01:43 PM   #9
quarterliter
Motorcycle(s): 2004 Ninja 250
I guess I would have expected it to be faster than that. A healthy ninja 250 will do 100.
Old August 12th, 2015, 03:31 PM   #10
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
14.2 is my best time . 1/4 mile. Someone went 14.0 and I don't think anyone has ever gone 13.99.
Most are 14/15
Be safe
Worlds fastest 250 ninja
Old August 12th, 2015, 06:29 PM   #11
Linkin
Down Under
Linkin's Avatar
Well as it turns out they are only doing 1/8 mile drags, about 200 meters.
As for only reaching 160KM/h. The bike has the wrong model CDI for the engine that is in it, has a 57 tooth rear sprocket, 140 section rear tyre, and the engine is over 20 years old, though with new rings and gaskets.
Once I replace the CDI with the correct unit, put on a 55 tooth rear sprocket, and a 130 section rear tyre, I'll have another go.
You can see this video where the rider gets it to 190KM/h plus, but it's an earlier non-restricted engine.
Old September 16th, 2015, 05:59 AM   #12
Ducati999
Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD)
Cool little bike. I dont know the laws down there, what about the motor is restricted? Is there code in the CDI or smaller carbs or what do they do to reduce output of a 250cc motorcycle?
Ducati999 is offline   Reply With Quote
Old September 16th, 2015, 04:25 PM   #13
Linkin
Down Under
Linkin's Avatar
The 93 and 94 engines have different cams and the redline start position got moved from 18,500RPM to 16,500RPM. But as a result they have more torque.
Old September 16th, 2015, 05:54 PM   #14
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
That "sounded" really fast!.. lol
Yamaha FZR250R 3LN6 Restoration Linkin The Ex-Ninjetters Lair 43 July 7th, 2018 02:05 AM
FZR250R 3LN3 Restoration Linkin The Ex-Ninjetters Lair 74 July 17th, 2015 03:43 AM
Yamaha FZR250R 3LN3 Linkin Videos 5 January 23rd, 2015 07:56 PM
[roadracingworld.com] - Testing Before Testing For Pata Honda World Superbike Riders Ninjette Newsbot Motorcycling News 0 January 14th, 2015 11:10 AM
[kropotkin thinks...] - Bridgestone Testing 2010 Tires Because Of 2009 Testing Restri Ninjette Newsbot Motorcycling News 0 March 4th, 2009 10:50 AM
