Old August 2nd, 2012, 04:45 PM   #1
Jay72
Jay72's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250r
Seafoam help please
Hey guys I can't seem to find anywhere as to how much seafoam to put in a full tank of gas, could any of you please suggest the proper amount to put in a full tank on a 2011. Thanks so much
Jay72 is offline   Reply With Quote
Old August 2nd, 2012, 04:48 PM   #2
toua70
toua70's Avatar
Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission)
It should say it on the can. Just do the math If I remember correctly, a can of seafoam cleans a gas tank that is around 10 gallons or so? maybe a little more/less. So, when I need to fill up, I would put half of it in the tank before I fill it up with gas (carry seafoam in my bagpack) and then used the rest the next time I need to fill up gas. Hope this helps
toua70 is offline   Reply With Quote
Old August 2nd, 2012, 04:51 PM   #3
xSean13
xSean13's Avatar
It says on the can... midst the plethora of nonsensical information on it.
Old August 2nd, 2012, 04:55 PM   #4
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Should I post my DIY for seafoam?
AFM #676
Supersports are for n00bs
Old August 2nd, 2012, 05:11 PM   #5
thurt88
thurt88's Avatar
Motorcycle(s): 2014 Honda CRF250L, 2010 ninja 250r
imho,
Don't use Seafoam.
Use some form of fuel stabilizer.
thurt88 is offline   Reply With Quote
Old August 2nd, 2012, 05:17 PM   #6
xSean13
xSean13's Avatar
Pee in your tank.
Everyone knows that peeing in your tank is the coolest.
Old August 2nd, 2012, 06:54 PM   #7
Hey guys I can't seem to find anywhere as to how much seafoam to put in a full tank of gas......
"Add 1 oz. Sea Foam to each gallon of fuel"
http://www.seafoamsales.com/how-to-u...treatment.html
For a full tank that contains 18.0 L (4.8 US gal), use 140 c.c. (4.8 oz.) of Sea Foam.
Old August 2nd, 2012, 10:18 PM   #8
smokinsingle
L8APEX
smokinsingle's Avatar
Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org!
I doesn't matter how much you put in....Seafoam won't fix your carb problems If there is any
www.joemillersmoderngarage.com www.starr-cycle.com
***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
smokinsingle is offline   Reply With Quote
Old August 3rd, 2012, 12:32 AM   #9
Jay72
Jay72's Avatar
Thanks for the replies, and no crab trouble at all just was thinking that i could use some to keep thing clean in the crabs.
Old August 3rd, 2012, 12:43 AM   #10
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Are you going to boil the crabs?
Or do you need some special shampoo for them?
AFM #676
Old August 3rd, 2012, 02:31 AM   #11
Jay72
Jay72's Avatar
Just trying to stay ahead of the game, but if you have a shampoo suggestion fire away, i always thought you guys from Call were a bit different.
On a serious note i am pretty sure i read on here that it is good to run some through every now and then, so tell me if i am wrong.
Old August 3rd, 2012, 06:28 AM   #12
Yes, you can use it freely as a preventive thing, especially right before you plan not using the bike for some days or weeks.
I use it every three fill ups' or so.
Old August 3rd, 2012, 12:19 PM   #13
mkulchar
mkulchar's Avatar
Motorcycle(s): 2010 250r ninja
He is correct dont use seafoam that stuff is garbage
Originally Posted by thurt88 View Post
imho,
Don't use Seafoam.
mkulchar is offline   Reply With Quote
Old August 3rd, 2012, 12:48 PM   #14
lgk
i never had any trouble with seafoam, but i think the star tron stuff is better for small displacement engines.
Old August 3rd, 2012, 12:50 PM   #15
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Next time follow the DIY. Seafoam is a panacea
AFM #676
Old August 3rd, 2012, 09:37 PM   #16
Boom King
So, where's the reverse?
Boom King's Avatar
I guess if you use these sort of things, everyone has their personal favourite fuel additive for cleaning carbs and the fuel system. I'd personally go with a product that is PEA (polyether amine) based. Since it is not solvent based like some other products, it is compatible with all fuel system materials. Its effectiveness at removing deposits has been well documented in a scientific paper by the SAE where benefits were seen not only just after the first tank of fuel but for the next 4300 KMs on average.
It's also an additive that has been approved by multiple car manufacturers to clean faulty fuel system sensors. Of course, this wouldn't apply to our Ninjas but goes to show you that it's safe enough to use on sensors in expensive vehicles such as the Corvette.
Some of the common products that contain a good amount of PEA are Techron Concentrate Plus and Gumout Regane Complete Fuel System Cleaner.
Edit: The only 3 Gumout products that contain PEA are Regane Complete Fuel System Cleaner, Regane High Mileage Fuel System Cleaner and All in One Complete fuel system cleaner. All the other Gumout products do not contain PEA.
Last futzed with by Boom King; August 3rd, 2012 at 10:26 PM. Reason: Updated links
Seafoam is worth trying chadh92 1986 - 2007 Ninja 250R Tech Talk 8 April 4th, 2013 06:53 AM
seafoam.. Stingray1000 1986 - 2007 Ninja 250R Tech Talk 16 June 18th, 2012 07:28 PM
How to use Seafoam? drdriftking007 1986 - 2007 Ninja 250R Tech Talk 22 April 17th, 2012 12:36 PM
seafoam? ReDnEcK 1986 - 2007 Ninja 250R Tech Talk 3 September 1st, 2010 09:00 AM
Seafoam is magical. P1NDLESK1N General Motorcycling Discussion 41 July 8th, 2009 11:29 AM
