Old August 8th, 2014, 09:32 PM   #1
jschorr
jschorr's Avatar
Motorcycle(s): 1995 ninja 250r
odd surging
so i noticed something today on the highway. it is an surging, it doesnt have to do with rpm but with speed, it happens around 60, 65 when i am just cruising. meaning if i get on it it doesnt happen but if a put it in 6th and just roll along ( around 7-8 rpm) i can feel it pulse.
i will start knocking down the list here in the next few days, but so far i have lube chain, grease bearings, and clean airbox filter..
anything i missed?
jschorr is offline   Reply With Quote
Old August 9th, 2014, 06:28 AM   #2
I would say it's most likely a carb adjustment issue.
Definitely check your air filter, but most commonly surging is a sign of a lean mixture.
Have you had the carbs off at any time? Have you made any adjustments to the idle mixture screws?
If the carbs haven't been synced recently, that would also be something to do.
Old gas or gas with moisture in it can give you odd running issues also.
Old August 9th, 2014, 07:05 AM   #3
rubber side down
rubber side down's Avatar
Motorcycle(s): 01 gixxer 1k, 02 gixxer 600, 02 ninja 250, a slew of dirt bikes
Sounds lean. Put a shim under the needles in the carbs. You can get a 6 pack of them at menards for 50 cents. The 3mm washers they have are the same washers I received from jetsrus.com
rubber side down is offline   Reply With Quote
Old August 9th, 2014, 09:10 AM   #4
jschorr
jschorr's Avatar
So I am hearing carbs and lean running.
Carbs are shimmed with 2 washers with the idle mixture screws about 2 3/4 turns out. Running a bit rich at idle.
But if it was carbs wouldn't it be doing it every time I ran at 7/8 rpm? Not just at a set speed?
I will try different gas next time I fill it. I use the same place every time.
Old August 9th, 2014, 09:01 PM   #5
I'd look at the plugs to see how they are burning overall.
I'd lean the idle mixture by turning the screws in if you think it's rich.
If it's still doing it and you don't have any answers, I would add some choke the next time it does it to see if it gets better or worse.
Old August 9th, 2014, 09:36 PM   #6
jschorr
jschorr's Avatar
Well it is good news bad news time!!!! Good news is I found the pulsing and don't have to rip my carbs down.
Bad news is I found the pulsing when I lost a rear brake caliper bolt on the way home. Maybe I forgot to lock tight the top one?
I lived so I guess all wells that ends well.
Old August 11th, 2014, 08:55 AM   #7
So it was a loose rear caliper that was causing it?
Old August 11th, 2014, 09:14 AM   #8
Ninjinsky
Ninjinsky's Avatar
As I recall someone else had the same thing a month or so back. Perhaps we should incorporate a brake bolt check into our monthly maintenance checks.
Old August 11th, 2014, 05:53 PM   #9
jschorr
jschorr's Avatar
as far as i can tell yes, it was the speed of the brake disc causing the caliber to move and bind slightly.
i cannibalized a fix in till thurs when i get new bolts, it is at 89% good to go right now so no pleasure cruising just work and back.
my bikes checks have become much more extensive since i found that. i look at everything every day now.
i think what happened is i got paint in the threads when i painted the swing arm and that made the lock tight not hold. i am upping to green locktight for the new bolts just in case.
[nytimes.com] - E-Bike Sales Are Surging in Europe Ninjette Newsbot Motorcycling News 0 August 19th, 2014 02:10 AM
Surging mid RPMs agentbad 1986 - 2007 Ninja 250R Tech Talk 13 August 18th, 2014 07:27 PM
Fuel tap question and bike surging agentbad 1986 - 2007 Ninja 250R Tech Talk 23 February 24th, 2014 10:26 AM
Surging above 8000rpm wyckedflesh 2008 - 2012 Ninja 250R Tech Talk 3 February 3rd, 2011 09:59 PM
Up and down surging/hesitation at low RPMs elicash80 1986 - 2007 Ninja 250R Tech Talk 2 August 29th, 2010 04:04 PM
