May 25th, 2017, 01:41 PM | #1 |
2004 250R
Picked up a 2004 250R w/ 2400 miles over easter, this is my first street motorcycle and has been an adventure through and through.
The bike was left setting for 10+ years with basic fuel in the tank. I've cleaned the carbs, done the airbox modification, fuel filter, replaced spark plugs ( couple of times) and replaced tires, most of my work so far has been focused on the carburetors and running / idle issues. I've come to the conclusion the bike needs to have the valves adjusted. Its typically pretty tricky to get running. 1st try it will kick over and start for however long I can keep it idling. After the first try though it will crank and crank until some starting fluid is applied. I am not a complete mechanical novice, but am intimidated by this job. Also now fully understand why newer bikes may be a better choice for newer riders. Also, the idea of taking it down for a couple more days has me chomping at the bit to ride it ... Curious if any members are in the Cleveland Ohio area who have some experience with this? |
May 25th, 2017, 01:58 PM | #2 |
cadd cadd cadd
MOTM - May '15
Mohlmag! Glad you found us...
May 29th, 2017, 04:01 PM | #3 |
sammich maker
MOTM - Apr '15
Welcome... From the other side of Ohio
May 29th, 2017, 09:27 PM | #4 |
No in Tucson, AZ. Sorry
Also I bought my first bike that sat for only 6 months or so (is what I was told) and I got it to fire right up after a basic tune up. Can't wait to start riding mine. |
May 29th, 2017, 10:40 PM | #5 |
MOTM - July '15
June 2nd, 2017, 07:15 PM | #6 |
Hello and welcome!
June 3rd, 2017, 09:27 AM | #7 |
Welcome!
June 3rd, 2017, 10:28 AM | #8 |
Although checking the valve clearances is a good idea, your symptom may be pointing to clogged pilot circuits in the carbs. The fact that starting fluid gets it going adds credibility to that theory.
A typical valve symptom is wanting to idle at 3,000 rpm or slow down and stall, but I was always able to start mine when the valves weren't quite closing. |
June 5th, 2017, 06:14 AM | #9 |
MOTM - May '17
welcome
What is it worth ? 2004 250R ? | 22R88 | General Motorcycling Discussion | 12 | May 15th, 2016 12:50 PM |
2004 Ninja 250R electrical problem. | kosencamry | 1986 - 2007 Ninja 250R Tech Talk | 8 | April 4th, 2010 09:41 PM |
