June 24th, 2022, 01:52 PM | #1 |
[webbikeworld.com] - 2022 Zero SR/S [Specs, Features, Photos]
Click here for full story...
The 2022 Zero SR/S Is One of the Most Capable Electric Sports Tourers Out There Contents The 2022 Zero SR/S offers everything you’d expect from a sports EV motorcycle — a potent powertrain, cutting-edge design, and impeccable functionality. The sports tourer is the flagship offering in the 2022 Zero Motorcycle lineup and received several significant updates this year. For starters, Zero Motorcycles made some notable updates to its Cypher operating system. The Cypher III+ Operating System now offers downloadable, real-time updates from a new Cypher Store. Customers can now tweak charging speeds and access better performance via the Zero app. The updated Zero SR/S also offers onboard navigation. The American company has also made notable updates to the battery system on the 2022 Zero SR/S. The improved ZF batteries can be upgraded to offer 20 percent more capacity and come in a new die-cast aluminum design that enables better thermal management and weatherproofing. The battery is available in two versions — a ZF14.4+ with the Standard model and ZF15.6+ with the Premium model. With the optional Power Tank add-on, battery capacity can be increased to 20.9kWh. The Standard also takes longer to charge, with a 0-100% charge time of 4.5 hours. On the other hand, the Premium will achieve a full charge in a claimed 2.7 hours. In the top-spec (including the Power Tank), the Zero SR/S is capable of a claimed 227-mile range in the city and 113 miles on the highway (at 70mph). The Z-Force 75-10 motor produces impressive figures with a peak power output of 110hp and maximum torque of 140 ft-lb, enough to propel the bike to a top speed of 124mph. The 2022 Zero SR/S starts at $20,595 USD / $26,595 CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Zero SR/S in one place. Motorcycle Overview General Info
Main Specs
Competitors
2022 Zero SR/S Specifications Engine Peak torque140 ft-lb (190 Nm) Peak power110 hp (82 kW) @ 5,600 Top speed (max)124 mph (200 km/h) TypeZ-Force 75-10 enhanced thermal efficiency, passively air-cooled, interior permanent magnet AC motor ControllerHigh efficiency and power dense, 900 Amp, 3-phase AC controller with regenerative deceleration LubricationDrivetrain TransmissionClutchless direct driveClutchFinal Drive90T / 20T, Poly Chain® HTD® Carbon beltChassis Suspension FrontShowa 43 mm Big Piston Separate Function forks, with adjustable spring preload, compression and rebound damping Suspension RearShowa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound dampingBrakes FrontBosch Advanced MSC, dual J-Juan radial 4-piston calipers with radial master cylinder, 320 x 5 mm discs Brakes RearBosch Advanced MSC, J-Juan single piston floating caliper, 240 x 4.5 mm disc Tires FrontPirelli Diablo Rosso III 120/70-17Tires RearPirelli Diablo Rosso III 180/55-17Fuel Tank CapacityN/AColorPower system Power packZ-Force® Li-Ion intelligent integrated Charger type3 kW integrated, Cypher upgradeable up to 6.6kW Charge time (standard)4.5 hours (100% charged) / 4.0 hours (95% charged)Dimensions Wheelbase57.1 in (1,450 mm) Overall WidthTrail3.7 in (94 mm) Rake24.5° Seat Height31.0 in (787 mm)Curb Weight518 lb (235 kg) Warranty Warranty2 years Extension 2022 Zero SR/S Features EFFORTLESS POWER The SR/F delivers 140 ft-lbs of torque and 110 horsepower with the simple twist of a throttle thanks to the class-leading performance and efficiency of Zero’s new ZF75-10 motor and Zero’s new ZF14.4+ (standard) and 15.6+ (premium) kWh lithium-ion battery. Additional range and battery capacity can be attained with a Cypher Store upgrade to unlock up to 17.3 kWh. EFFORTLESS CONTROL The SR/F is equipped with Zero’s latest Cypher III+ operating system with a suite of downloadable performance upgrades. Bosch’s Motorcycle Stability Control (MSC), is equal parts brawn and brains. Effortless power is paired with intuitive control, creating the new standard for premium performance—an adaptable motorcycle and powertrain combination that navigates diverse road terrain and conditions, effortlessly. EFFORTLESS CONNECTION The SR/F is the world’s first fully “smart” motorcycle. A customizable dash and Zero’s next-generation app already come with a host of amazing free features that communicate critical information anytime, anywhere. Thanks to the revolutionary operating system, Cypher III+, the app also unlocks a world of on-demand upgrades through a virtual marketplace, as well. Incredibly light. Unbelievably strong. The steel-trellis frame, custom swingarm and advanced Showa suspension deliver an athletic and intuitive riding experience. The powertrain is perfectly distributed, resulting in a weight-optimized/mass-centralized design, while a dual radial front brake system makes shedding speed as exhilarating as building it. 2022 Zero SR/S Photos 2022 Zero SR/S Videos 2022 Zero SR/S Official Promo: 2022 Zero SR/S Walkaround by Mark’s Motorsports Links </p>Zero Motorcycles Websites Social Media Links The post 2022 Zero SR/S [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Zero SR/F [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2022 01:40 PM |
[webbikeworld.com] - 2022 Zero FX [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 04:36 AM |
[webbikeworld.com] - 2022 Zero DS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 04:13 AM |
[webbikeworld.com] - 2022 Zero S [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 03:47 AM |
[webbikeworld.com] - 2022 Zero SR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 03:27 AM |
