Old November 28th, 2010, 09:59 AM   #1
Sailariel
Sailariel's Avatar
Turn Signal Buzzer
I have found that at times, I forget to cancel my turn signals. Obviously, that can create a potentially dangerous situation since the motorist near you will assume you are going left or right when you are really going straight.
Has anyone on this forum installed a buzzer which would sound when a turn signal is engaged? It would seem like a fairly easy mod--finding a buzzer at Radio Shack, etc.
I don't think it would be illegal--certainly it would be practical. I already know the answer as to why the original manufacturer does not put one in. Cost.
Another question--Why don't we have Hazard Lights (that's when all four turn signals flash all at once) I have only seen such a switch on one bike--an older Honda VFR. My new Honda NT-700, which is a sport touring bike does not have such a switch.
Ninjette, Sold. New Bike: 2010 Honda NT-700V/VA, 73 Honda 550, 74 Honda 550
Old November 28th, 2010, 10:04 AM   #2
JMcDonald
Motorcycle(s): 2008 250R
Good question about the hazard lights, but Id imagine cost wasn't as much of an issue as that it would be annoying as hell :P . Imagine sitting at a longer light, listening to your bike buzz for several minutes while you wait :P .
It seems like most people just develop a habit to periodically hit the cancel button. I have more recently started canceling the switch just as I am starting my lean, if not before.
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped.
JMcDonald is offline   Reply With Quote
Old November 28th, 2010, 10:20 AM   #3
KURT
Resident Old Guy
KURT's Avatar
Motorcycle(s): sold
My '07 650R has 4-way flashers... kind of annoying that the newer 250 was designed without them. Cost considerations, I'm sure.
As far as a turnsignal buzzer... I could use it (might save my life, as a matter of fact.)... If only it would start buzzing after maybe 20 to 30 seconds of delay. Easy to wire, if we had vintage flasher relays, but I'm sure the new bikes are sloid state, etc.
KURT is offline   Reply With Quote
Old November 28th, 2010, 11:51 AM   #4
WindMeUp
Small Bike Abuser
WindMeUp's Avatar
Motorcycle(s): 2010 Ninja 250R SE, GSX650FK8, DL650K5, CH80K2, AN400K7, SH150i
A few bikes back I tried using Radio Shack76dB Piezo Buzzers, wired to the turn signals, they where not loud enough, once you got out of the driveway the where useless, forget it if you use earplugs, any buzzer that would work would also drive others around you crazy.
I have had better luck putting led's in my line of sight, like the ones on my GS500F:
If you are "Too Cool" to be seen on a scooter...you're a Poser
WindMeUp is offline   Reply With Quote
Old November 28th, 2010, 02:15 PM   #5
DR1300R
DR1300R's Avatar
Motorcycle(s): 2000 Hayabusa 2009 Ninja 250R
That's slick..
DR1300R is offline   Reply With Quote
Old November 28th, 2010, 05:51 PM   #6
Sailariel
Sailariel's Avatar
Stevo, What a great solution! I knew, like everybody else on this forum knows, that when one asks a question, the answer invariably is there almost instantly. What an outstanding group we have here!
Old November 28th, 2010, 06:42 PM   #7
JMcDonald
That is a great idea!
Old November 28th, 2010, 07:20 PM   #8
WindMeUp
Small Bike Abuser
WindMeUp's Avatar
Thanks!
Here, you might as well know where I bought the Led's then, they come pre-wired so all you have to do is hook them up.
http://www.oznium.com/prewired-leds
Old November 29th, 2010, 08:07 PM   #9
ithaca00
ithaca00's Avatar
Motorcycle(s): 2007 EX250 (street), 1994 EX250 (Race), 2008 250R (Race), 2000 250 (project), 1991 EL250 (a cruiser!)
Another option is self cancelling signals. I can't remember where I saw them off hand but it's available as a module for all bikes.
ithaca00 is offline   Reply With Quote
Old November 29th, 2010, 09:19 PM   #10
bob706
bob706's Avatar
https://www.kisantech.com/application2.php
kinda pricey but some cool stuff
Old December 1st, 2010, 05:41 PM   #11
g21-30
g21-30's Avatar
http://www.kawasakimotorcycle.org/fo...ignal-mod.html
Old December 1st, 2010, 08:16 PM   #12
Momaru
Momaru's Avatar
Well, not sure how your new NT is wired up, but I played around with making hazard flashers for my ninjette a while back, with some success. Decided to pass though, as I pretty much never use hazard flashers anyway and it's easy enough to rig up in a pinch if I need 'em.
Posts 6 & 7 of primary interest: http://www.ninjette.org/forums/showthread.php?p=138647
Proud member of the Blue Army
New turn signal BULB? cmbeebe Items Wanted 18 August 22nd, 2021 03:27 PM
turn signal help akcalhoun 2008 - 2012 Ninja 250R Tech Talk 24 February 25th, 2013 06:09 PM
will this turn signal work skateboarder1210 2008 - 2012 Ninja 250R Farkles 12 June 29th, 2011 08:52 PM
Turn signal went out, looking for a new turn signal austinm911 2008 - 2012 Ninja 250R Farkles 3 January 23rd, 2011 08:58 PM
