August 31st, 2014, 03:17 PM | #1 |
Join Date: Aug 2014 Motorcycle(s): 2005 Ninja 250 Posts: 1
Need Help Wiring In New Led Tailight
I have 2005 Ninja 250 and giving it a sort of street fighter kind of look. I figured wiring in the new tail light would be easy, unfortunately i was wrong so i need some help on where i connect the wires.
On the tail light the wiring colors are: Red-Brake White-Left Turn Signal Yellow-White Turn Signal Black-Negative Green-Running Im not 100% sure this is correct for the bike wires: Black w/yellow tracer-Ground Blue-Brake Green-Left Turn Signal Grey-Right Turn Red-Tail Light |
August 31st, 2014, 03:49 PM | #2 |
Certified looney toon
MOTM Jul '13, Jul '14
I pulled this wiring schematic from the Ninja250 forum and it looks like you have the right labels.
http://faq.ninja250.org/images/a/a4/...matic_-_R4.pdf More info is there since our wiring page seems to have lost its image. http://faq.ninja250.org/wiki/Wiring_...s_%26_diagrams
Wiring LED Strip question | spc2125 | 2008 - 2012 Ninja 250R Tech Talk | 12 | June 19th, 2013 08:42 PM |
Anyone have an LED tailight? | 2fidyswag | 2008 - 2012 Ninja 250R Farkles | 22 | June 5th, 2013 04:45 PM |
LED- underglow wiring help | smackenz | 2008 - 2012 Ninja 250R Farkles | 2 | February 15th, 2012 06:30 PM |
Led wiring help. >.< | Mr.E | 2008 - 2012 Ninja 250R Tech Talk | 63 | February 4th, 2012 03:02 AM |
LED's and wiring | JLinde1339 | 1986 - 2007 Ninja 250R Tech Talk | 7 | October 11th, 2011 09:45 PM |
