Old July 23rd, 2016, 03:24 PM   #1
Iamnick10
Motorcycle(s): 02 ninja 250, 93 gsxr 750
Handlebars misaligned and I have no center stand
Due to my recent wreck, handlebars are misaligned, doesn't look like the forks are bent but it's off center. I have read that you prop up the front, take off the wheel, loosen the cinch bolts and the top big bolt and it should go back to center then tighten everything back. This is my plan of action once I figure out how to get it up in the air. I don't have a center stand due to full muzzy exhaust. I have a car engine lift, would that help? Also, if my realignment plan sounds wrong, let me know, I've never attempted anything like this
Iamnick10 is offline   Reply With Quote
Old July 23rd, 2016, 03:31 PM   #2
Lazarus
Lazarus's Avatar
Motorcycle(s): 2008 Ninja 250
I used stand alone jacks on the front and rear until I got my stands. The bike is far less stable on them as compared to the stands but it should work. Only catch is you have to have someone help you place the front or rear on the jacks
I wouldn't use a cherry picker to lift the bike but I'm sure someone has tried it. It only weighs approx. 330lbs.Not sure how you would rig it up though.
Lazarus is offline   Reply With Quote
Old July 23rd, 2016, 04:42 PM   #3
jrshooter
Motorcycle(s): ninja 300
i lift mine from the garage rafters and a come along.
Old July 23rd, 2016, 05:35 PM   #4
rubber side down
rubber side down's Avatar
Motorcycle(s): 01 gixxer 1k, 02 gixxer 600, 02 ninja 250, a slew of dirt bikes
i have a muzzy on mine as well. I have stands to lift it. But when I replaced the shock I used my center stand. You just need to be a little creative. I used a 1/2" or 7/16 sae bolt, don't remember which size it was, but it was just a bit smaller than the metric one that goes in there and slides into place to put the center stand on and the bike up to do the work you would like.
Or you could pull your bike up next to a tree, stop sign, post, building, anything with some strength and bang the front wheel against it to get things lined back up. I did that after a crash and stuff was all out of whack.
Then after a month of banging them back and forth trying to get it to track straight again, I replaced the steering head bearings with roller bearings. That upgrade was better than the muzzy ever could be.
rubber side down is offline   Reply With Quote
Old July 23rd, 2016, 07:36 PM   #5
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
^^^ This. Or a folding ladder to make an A frame and a strap with a ratchet works great too
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old July 23rd, 2016, 08:54 PM   #6
Iamnick10
You guys are geniuses. I like the ladder idea, I have a stepladder I might try this with. I don't know about the banging it back into place although it may come to that
Center stand didn't come with the bike, I guess the previous owner got rid of it when they did the exhaust. Amy idea on what jet sizes I should use with the muzzy? It runs like poo low end.
Old July 23rd, 2016, 10:02 PM   #7
juliusmichaelhonrada
Motorcycle(s): GPX250-RII
me i laid down the bike in the floor with a rubber mat then start dissembling here while she is sleeping
p.s removed the fuel tank first and the footpeg on that side where u wanna lay her down
juliusmichaelhonrada is offline   Reply With Quote
Old July 24th, 2016, 12:18 AM   #8
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
We are Geniuses, not Wizards!
Old July 24th, 2016, 07:58 AM   #9
?........I don't know about the banging it back into place although it may come to that.........
How to:
http://faq.ninja250.org/wiki/I_need_...nd_front_wheel
Old July 24th, 2016, 09:47 AM   #10
verboten1
verboten1's Avatar
MOTM - June '15
Yup, ride up to a tree, and turn hard into it. Fixed.
Just fixed the KLR like that 2 weekends ago.
Ride more, worry less.
Old July 24th, 2016, 10:45 AM   #11
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Should stop first or just slow down?
Old July 24th, 2016, 07:07 PM   #12
verboten1
verboten1's Avatar
MOTM - June '15
I guess it depends on how good you are. A novice might want to stop first I suppose.
Old July 25th, 2016, 08:25 AM   #13
spent_too_much
spent_too_much's Avatar
This method worked for me.
https://www.youtube.com/watch?v=vSunBRB6-r8
Old July 25th, 2016, 08:40 PM   #14
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
No need to lift the bike to align the forks. The handlebar risers keep the fork tubes from sliding up through the triple tree, so just loosen bolts, grip the wheel between your legs, and twist the bars. If the tree is bent then it may require force to hold the bars straight to the wheel while the bolts are tightened. If no amount of force will hold the bars straight then the tree is bent and should be replaced.
Look at the risers to make sure they're not bent, there should be no gap where they bolt to the top of the tree.
Center stand? SuperG$ 2008 - 2012 Ninja 250R Tech Talk 3 April 25th, 2016 06:45 PM
Replacing Center stand with kick stand? UFOmoplata 1986 - 2007 Ninja 250R Tech Talk 9 January 13th, 2016 06:26 AM
what kind of center stand should I get tdog7812 General Motorcycling Discussion 6 May 15th, 2013 11:52 AM
Center Stand Spring AlexL 1986 - 2007 Ninja 250R Tech Talk 5 September 25th, 2012 08:13 AM
center kick stand mr.niftie 2008 - 2012 Ninja 250R Tech Talk 7 July 15th, 2009 06:18 AM
