April 26th, 2011, 11:32 PM | #1 |
Join Date: Apr 2011 Motorcycle(s): 2000 Ninja 250, Totally black. Gsxr 600 Red. Posts: 179
Instrument Panel - Rattle
My gauges seem to be rattling a wholeeee lot (pregen btw) Out of curiosity, what exactly do they attach to, and how? Is it possible to tighten whatever that is? Sorry, I haven't had my ninjette long, and haven't taken the time to take the thing into pieces yet!
April 26th, 2011, 11:39 PM | #2 |
/moved to pre-gen tech
April 26th, 2011, 11:42 PM | #3 |
April 26th, 2011, 11:46 PM | #4 |
No idea, but I'm sure someone will be along shortly. Might be useful to look at a parts diagram for the bike. Here's a link on bikebandit that has the full microfiche:
http://www.bikebandit.com/houseofmot...f14-us/o/m4009
April 27th, 2011, 12:07 AM | #5 | |
April 27th, 2011, 06:31 AM | #6 |
Eternal Noob
Join Date: Feb 2011 Motorcycle(s): "Blanka" 07' Ninja 250 Posts: 247
Kinda curious about this one myself tbh. My bike (around that area) starts to rattle really loud at about 8-10k RPM too. It's like a high pitched metal rattle, but I always check for loose stuff, and can never find anything. Thanks in advance to anyone who might know where to look.
April 27th, 2011, 06:40 AM | #7 |
1st culprit is often the clutch lever.
April 27th, 2011, 06:42 AM | #8 |
Eternal Noob
thanks Alex. I'll check there, but I recently changed my levers, and I tightened everything (what I though was) really good. I'll def double check.
April 27th, 2011, 06:44 AM | #9 |
no I mean my instrument cluster itself is loose, I can grab it and wiggle it, any ideas?
April 27th, 2011, 12:35 PM | #10 |
There are three bolts that go through rubber bushings, they hold the cluster to the upper fairing stay. The only way to access them is to pull the upper fairing.
April 28th, 2011, 05:24 PM | #11 |
I second both the clutch lever and taking off the fairing. once You get off the fairing, it'll be blaringly obvious how it's attached. just a few bolts
May 16th, 2011, 03:13 PM | #12 | |
Join Date: May 2011 Motorcycle(s): EX250, Triumph TR6c, Norton Commando, XS650, XS100, VStar 900 Posts: 39
It is also likely that the fairing stay itself has broken where it mounts to the frame. There are two little arms at the bottom that like to crack and break. Those will require welding to the stay or a replacement of the stay. If it is the plastic towers on the back of the instrument cluster, I use a 5 minute epoxy to repair them... First application of the epoxy is right to the crack/break. after that cures... the second application of epoxy is a thick surrounding of the cracked/repaired area. -=PO |
LED instrument panel | akcalhoun | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 15th, 2012 07:27 AM |
Lost instrument panel illumination | van Gogh | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 14th, 2011 07:18 PM |
Rattle... | bigrodge8 | 2008 - 2012 Ninja 250R Tech Talk | 13 | May 7th, 2010 11:06 PM |
