May 11th, 2014, 10:58 AM | #1 |
Wannabe Reborn
Mismatched Tire sizes...
Previous owner had replaced front tire with a 120 due to damage. Stock 130 is in rear. Center of tire is completely bald. Aside com the baldness, what will the 120/130 combo do? Also, if I replace rear with a 140o or 150, should I be concerned about different brand tires, tire life? Thanks~
May 11th, 2014, 11:09 AM | #2 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 718
Changing the tire size will affect things like your straight line stability and tip-in (same thing, I guess), but there's nothing inherently wrong with running different tire sizes than stock.
May 11th, 2014, 11:20 AM | #3 |
the wider front tire on the same size rim will pinch it a bit making your font higher which isnt what you want for good handling. maybe pinching a big tire on the rear would even it out. hey and then they would both be kinda V profile huh! lol
May 11th, 2014, 12:28 PM | #4 |
Wannabe Reborn
Understandable. I was wondering if anyone has run this combination before. I know that 120 in front has been common, but with a 130 in rear, I haven't seen anyone make mention of that combo. Bike has some squirl ones to it in corners, but I believe that is more so the lack of tread in middle of rear than tire combo. Thanks for the input.
Tire sizes/tire brand??? | Tadydrift | 2008 - 2012 Ninja 250R Tech Talk | 10 | January 5th, 2015 05:24 AM |
Tire Sizes | Kokosun | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 8th, 2013 08:47 AM |
Tire sizes | fredhsu | General Motorcycling Discussion | 12 | August 9th, 2012 07:37 PM |
Help with confusion over tire sizes | PitBull | General Motorcycling Discussion | 14 | April 4th, 2011 12:17 PM |
Noob ... Tire sizes | johnjohn | 1986 - 2007 Ninja 250R Tech Talk | 12 | July 19th, 2010 03:02 PM |
