October 21st, 2013, 08:35 PM | #1 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
Yoshi Slip on Stinks
That title might be misleading. I just installed a Yoshi TRS slip on and love how the can sounds. But it's producing this really strong odor. I wish I could explain the smell, but I can't. Is it normal if newly installed slip ons produce a strong odor?
October 21st, 2013, 08:46 PM | #2 |
So, where's the reverse?
When's the last time you had a shower?
Did you rejet? Something got on your pipes or muffler and is burning? Bad packing? |
October 21st, 2013, 08:51 PM | #3 |
Your face
No I didn't rejet. I was under the impression that rejetting wouldn't be necessary with a slip on. And what do you mean by bad packing? I kinda just slipped the muffler on the header lol
October 21st, 2013, 09:08 PM | #4 |
It depends on the slip on but I thought Yoshi recommended a rejet? Could be wrong. If it's not too lean, you might get by fine. Shimming the needles would still be a good idea.
Sometimes the smell is normal for a new muffler when you run it for the first couple of times. Oils are burning off and the packing heating up for the first time. If it's persistent, then you've got a real problem. |
October 21st, 2013, 09:18 PM | #5 |
Your face
I was looking thru Googles and someone on another forum mentioned new muffs have a "break in" time when it tends to have strong odors. I was hoping some Ninjetters could confirm it. Or if it's something totally different
October 22nd, 2013, 10:02 AM | #6 |
Join Date: Jun 2013 Motorcycle(s): 2010 Kawasaki Ninja 250R (Passion Red, Ca Model) Posts: 107
When I repacked my AreaP can, it gave off a weird smell, but I used masking tape to keep the packing in place. The smell went away after a couple of rides. Same thing happened with my roommates WR250, after installing his TwoBrothers slip on. It also gave off a weird smell for a couple of rides then it went away. I think it might have something to do with heating up the packing for the first time.
I would be rich by now if I had a dollar for every person that has told me "You need to upgrade, You need a bigger bike, You need more power..." |
October 22nd, 2013, 11:13 AM | #7 |
Join Date: Jun 2010 Motorcycle(s): 2008 Kawasaki Ninja 250R-J, 2005 Honda Superhawk VTR1000 Posts: 95
Not uncommon for the odor initially. The grease and such as well as the metal heating-up will give off a weird smell for the first 100 miles or so. It'll pass. Be patient.
October 22nd, 2013, 01:44 PM | #8 |
Join Date: Apr 2013 Motorcycle(s): 2010 250r SE (without stupid tribal decals) Posts: 110
When I first installed my 2bros it gave off some white smoke and a stink to go with it.
"It sounds like a lawnmower." "Shut up no it doesn't." |
October 22nd, 2013, 02:03 PM | #9 |
Your face
Awesome. Thanks for the replies friends. I won't worry about my stinky pipes.....for now
October 23rd, 2013, 02:12 AM | #10 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
i have a newish <200Kms Yoshi slipon installed.
i shimmed the carbs and put 3 washers to be safe at 660m above sea level. Use the bike to go from work and back 20km round trip. 1st big cruise will be with around 80 other riders this weekend, see how it goes |
October 25th, 2013, 10:53 AM | #11 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
Mine gave off a horrendous smell at first
Yoshi TRC slip on | IconChris | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 17th, 2013 06:02 PM |
yoshi slip on | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 19th, 2011 07:44 AM |
Should I shim for a Yoshi slip on? | wtfh4xx | 2008 - 2012 Ninja 250R Tech Talk | 27 | June 6th, 2011 06:15 PM |
WTB: Yoshi CF Slip-On | red | Items Wanted | 1 | April 21st, 2011 07:14 AM |
Headers for YOSHI Slip on. | shporsche | Items Wanted | 5 | June 1st, 2009 07:37 PM |
