May 14th, 2010, 12:34 PM | #1 |
Join Date: Dec 2008 Motorcycle(s): '09 ninja 250 (blue) Posts: 295
Getting smooth on the throttle
Moved:
CC & Kelly: I did both the wd-40 and pushing on the seat. I also purchased some graphite and put in the lock mechanism as well. It worked!! Thanks for your input guys. Another question though: I have very little seat time thus far and I noticed on my ride today that I am VERY jerky on the throttle (esp during shifting) which caused a lot of front-end diving. How can I alleviate that? Practice, I guess, huh? I need to become smoother. Another question: It seems that my foot was constatntly searching for the rear brake, as if it wasn't high enough to my foot. Can I adjust it? Thanks again.
A woman is like a teabag; you never know how strong she is until she's in hot water! |
May 14th, 2010, 01:49 PM | #2 |
I'd say with practice your throttle control will become more precise and you'll get to "learn" the bike and how it responds when you twist the throttle. You can help this, though, by making sure your throttle freeplay is set correctly. The exact specs for how much freeplay is in your owner's manual. When adjusted correctly, it will aide in the the clutch/throttle interplay that happens when you shift gears. Obviously, setting the clutch freeplay is important, too, so the controls always react the same so you will know when the clutch releases/engages and the throttle starts to open the carbs.
yes, the rear brake pedal height is adjustable. |
May 15th, 2010, 12:51 PM | #3 |
MOTM - Mar '13, Jun '14
Smoothness with the throttle is just like in a car (with a manual trany). Try shifting each gear at the same RPM. Instead of just riding in top gear go in an area where you will be shifting (up and down) continuously. Some people never get it, some are a natural (thank you, thank you , thank you), some learn it after much practice.
When I was a kid my dad used to tell me drive, or ride, like you are a chauffer and you want the ride to be as smooth as possibly for the passenger. Relaxing makes it a lot easier.
May 15th, 2010, 12:54 PM | #4 |
I will visit a parking lot and practice that CC.
I would probably understand better if I had ever driven a manual. I like the chaueffer simile; makes it easier to understand.
May 17th, 2010, 01:35 AM | #5 |
Join Date: Apr 2010 Motorcycle(s): Yellow n black 2002 ninja ex250 Posts: 11
I allways shift around 6000 or 7000 rpm. I used to have a similar problem with shifting
but since I started only shifting around the same Rpm no matter what gear I have noticed it's totally smooth now. Good luck n keep practicing. I've only been street riding for like 2 weeks so I know all to well how much there is to learn cheers from Boston Posted via Mobile Device |
May 17th, 2010, 05:36 AM | #6 |
Will take that into consideration; thanks Tom.
Full throttle kills bike, throttle lag response. | Diegone | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 30th, 2014 03:25 AM |
Describe a smooth shift | OCMagnum | Riding Skills | 12 | June 15th, 2013 06:37 AM |
The rules to being fast and smooth on track | Motofool | Riding Skills | 12 | May 16th, 2013 04:03 PM |
My ninja is running really smooth | Coolbpf | General Motorcycling Discussion | 6 | September 9th, 2012 04:04 PM |
Cello and Smooth Criminal? | kyrider | Off-Topic | 9 | August 9th, 2011 03:25 PM |
