March 31st, 2012, 03:46 AM | #1 |
Join Date: Sep 2010 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 139
Quick question regarding fork seal job
Hi all, haven't posted here in a while (I don't feel as though I have much I can contribute...it's mostly all been covered ) but I have a quick question in regards to my fork seal job.
I am going to be replacing the fork and dust seals with a kit from eBay (All Balls Racing .... anyone heard of it / used it ??), I have been reading the service manual and all the posts related to fork seal jobs on this forum. The manual says you should replace a and z and everything in between (which I personally see as slightly un-neccesary), some say you should just replace the snap rings and the fork and dust seals...others say bushings also (saw RacerX say it's a good idea to replace the upper bushing....) My question is, what is necessary if everything is in good condition ? |
March 31st, 2012, 06:55 AM | #2 |
Join Date: Dec 2011 Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L Posts: 142
It is never a "bad" thing to replace the bushings or sliders or clips.
that being said it is not always necessary to do them. The thing is people often do seals very infrequently, usually don't do them until all the fork oil is gone and they are a big problem. When this happens yes, you should most likely replace the bushings. You can see how much slop in the lower to upper part of the fork. if they clunk forward and backward then you MUST replace the bushings else the seal will still leak.
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles |
March 31st, 2012, 07:38 AM | #3 |
If you've got your forks apart check the teflon coating on the bushings. If it's not worn down or chipped off anywhere you shouldn't have an issue re-using them.
March 31st, 2012, 05:39 PM | #4 |
Excellent, I completely understand - thanks for making it clear
This forum is probably the best I have ever used, big thanks again guys !! |
Leak on right fork seal | AmyF | 1986 - 2007 Ninja 250R Tech Talk | 17 | July 11th, 2014 09:29 AM |
Fork Seal is Stuck | eddyble | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 21st, 2013 04:14 AM |
OEM Brand New Fork Oil Seal, Dust Seal (08-12) | capriccio | Motorcycle-related | 3 | June 9th, 2013 05:11 AM |
Fork Seal Leaking | broken neck | 2008 - 2012 Ninja 250R Tech Talk | 16 | June 2nd, 2013 11:40 AM |
Leaking fork seal? | EthioKnight | 2008 - 2012 Ninja 250R Tech Talk | 12 | March 6th, 2012 09:20 PM |
