May 6th, 2009, 12:22 PM | #1 |
2008 Ninja 250R ~ mild streetfighter project
I'm thinking about selling this little commuter now as something has come up. Its located in Chino, CA 91710. It has a clean title that will be given to the new owner shortly after the sale. A bill of sale will be provided. It has around 7,000 miles on it currently and all maintenance is up to date. Registration is also current. It could use a better way to mount the gauge cluster or to have a custom gauge put on instead. Other than that, its a sweet little bike. Asking $2,900 obo. Make me an offer, it wont hurt.
-Stock air box has been completely removed and replaced with a K&N air filter -Carbs have been re-jetted -Full exhaust system, 12" muffler, Area P's D.E.I. quiet insert -Ebay pegs replaced the stock ones -Stock coolant reservoir has been removed, replaced, and relocated to under the seat where the stock air box was -Shogun slider kit installed includes bar end sliders and swingarm slider spools -Single rear view mirror clamps to left handlebar & folds down and out of the way when not in use -4" dual headlight kit clamps to the forks and includes a windscreen and turn signals that mount to the side brackets -DMP S-Spec rear stand will come with it along with extra oil filters Last futzed with by 1hardryder4life; June 26th, 2009 at 12:36 PM. |
May 6th, 2009, 12:26 PM | #2 |
Wow that looks totaly awesome. You definetely have a one of a kind there.
May 6th, 2009, 01:30 PM | #3 |
Ms. Personality
If you could do something with the tabs on the tank you'd really have something there. Machine guns maybe? I kid, but seriously I think it looks pretty awesome. I'd buy one.
May 6th, 2009, 02:03 PM | #4 |
Yeah the tabs would have to be taken off via grinding the welds down and removing the bracket. However, Kawi did a great job at welding those suckers on there so it would be quite involved. Definitely would take some heavy grinding, welding, filling, sanding, repainting, etc. Perhaps I will keep my eye open for a used or damaged fuel tank and put it to work some day.
May 6th, 2009, 02:10 PM | #5 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r (Fastest Color) Posts: 914
That is def. a one of a kind bike and looks really good. Any estimate on how much weight you saved? Hows it ride at highway speeds not without those fairings on?
May 6th, 2009, 02:15 PM | #6 |
Join Date: Apr 2009 Motorcycle(s): 08 black 250r (sold); '09 black zx6r Posts: 903
wow... very nice...
don't you have to clean the engine more often now since you don't have the fairing? |
May 6th, 2009, 02:28 PM | #7 | |
Its possible that the engine and other bits might be more likely to get dirty without any fairings but I doubt its any big difference. Just imagine all the other "naked" bikes out there to get an idea...Harleys, dualsports, supermotos, standards. Its easy to spot clean anyway since there are no fairings to remove. It just a matter of grabbing a rag every once in a while and cleaning any dirt spots up. |
May 6th, 2009, 02:36 PM | #8 |
Track Junkie
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike Posts: 602
i bet you could shorten or buy shorter pucks for your slider kit. the only reason they're that long is to clear the body work. it'd clean it up a bit.
good looking bike though. where'd you get the lights?
Las Escobas -- Track Bikes Save Lives JonBroom.com |
May 6th, 2009, 02:45 PM | #9 |
Yeah they do seem to stick out pretty far. I havent thought of shortening them or looking for shorter ones though. Thats a good idea! Thanks man! The headlight kit is from Aztec8.
May 6th, 2009, 03:05 PM | #10 |
Join Date: Dec 2008 Motorcycle(s): 2009 SE Ninja 250R Posts: 796
looks sweet! The headlights and front end always make or break a streetfighter and yours looks amazing!
May 6th, 2009, 03:29 PM | #11 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Too bad you didn't have the sliders before hand. Might have saved the plastics.
May 6th, 2009, 03:58 PM | #12 |
naw the sliders wouldnt have helped save the plastics. I wish it was that simple though. I could have easly saved some rashed plastics. However, this wasnt a "slide" type of fall. It was an impact to the front right side of the bike that shattered the right cowling, popped the headlight out of its nest, and bent the upper cowling stay a little bit.
Last futzed with by 1hardryder4life; June 24th, 2009 at 04:25 PM. |
May 6th, 2009, 04:11 PM | #13 |
looks completely different - nice touches
May 6th, 2009, 04:23 PM | #14 |
Join Date: Feb 2009 Motorcycle(s): 2008 Ninja 250R Posts: 290
Whoa! That looks sweet!
http://www.southparkstudios.com/clips/224099 |
May 6th, 2009, 04:34 PM | #15 |
Ms. Personality
I'm curious about your wire routing. It looks very clean.
May 6th, 2009, 04:47 PM | #16 |
Its actually very simple. The only wires that really needed any "re-routing" were the front turn signals because they obviously mount a lot more forward now since they are on the headlight brackets. But those wires were easily tucked up underneath the fuel tank. They then emerge at the front of the tank and run along side the other cables (throttle, choke, clutch) near the head of the frame, to meet the signals themselves.
May 6th, 2009, 04:54 PM | #17 |
Live 2 Ride Forced 2 Work
Join Date: Mar 2009 Motorcycle(s): 2008 RED 250r Posts: 386
Did you make that radiator cover?
May 6th, 2009, 07:13 PM | #18 |
Generic User Title
Join Date: Dec 2008 Motorcycle(s): Green 2008 Kawasaki Ninja 250R, Slate 2009 Triumph StreetTriple R Posts: 110
That thing is sex on wheels man! Definitely going to get some looks with that thing! LOL
2008 Ninja 250R Kawi Green - Bikelitez Fiberglass Undertail w/LED Turn Signals, Carbon Fiber Tank Protector 2009 Triumph StreetTriple R Matte Graphite - Arrow Titanium Exhaust, Belly Pan |
May 7th, 2009, 05:25 AM | #19 | |
May 7th, 2009, 08:14 AM | #20 |
Thanks for all the kind words, guys! This is a good forum.
Yeah I "made it" haha. I couldnt find anything available online aside from a company wanting like $125 for a stupid radiator guard or having to pull something from Japan. All I did was get some metal screening from Lowes that had holes small enough to prevent any rocks getting thru. Then cut it to the right size and put it up. |
June 5th, 2009, 11:31 AM | #21 |
self wrencher
hey TBoz,
WHat peg is this? |
June 5th, 2009, 12:10 PM | #22 |
June 5th, 2009, 12:55 PM | #23 |
self wrencher
Thanks bro...may order some to replace mine. I like the look of it. Cheap too
How is the fitment? Any sagging issue or anything like that? Thanks. |
June 5th, 2009, 01:01 PM | #24 |
Fitment and quality are great. No sagging yet. The stock springs are a little tough to compress enough to get the pin thru but its do-able. Also, the pegs thread onto the base and they can easily come loose while riding. use some thread lock or wrap the threads in a bit of teflon tape so they dont screw loose.
June 5th, 2009, 07:51 PM | #25 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250r Posts: 379
So i didnt see it in the thread... What headlight/windscreen setup did you pickup? Ebay link any chance?
June 24th, 2009, 03:54 PM | #26 |
July 8th, 2009, 08:17 AM | #28 | |
Asking $2500 firm at this point.
No problem.... Last futzed with by 1hardryder4life; July 27th, 2009 at 08:28 AM. |
October 31st, 2009, 01:22 AM | #29 |
how bout this one ?
October 31st, 2009, 02:14 AM | #30 |
That single-sided swingarm is so awesome. I've seen this bike pop up a few times before the streetfighter modifications unless more than one person has thrown the same swingarm on a red bike. What I want to know is what bike did the swingarm come from and how did they retrofit it?
I guess the hugger was meant for the bike the swingarm was meant for. I also wonder where the replacement fairings came from... |
2012 Ninja 250r SE - Winter Project...Streetfighter Version. | SuperAmp13 | 2008 - 2012 Ninja 250R Farkles | 6 | April 3rd, 2014 04:34 PM |
My Streetfighter Project | mickheaven | 2008 - 2012 Ninja 250R Farkles | 45 | October 29th, 2013 05:20 AM |
The Tail Trunk Project is completed for the 2008+ Ninja 250R | emdsd | Cargo Space | 8 | November 27th, 2011 09:45 AM |
The Ninja Streetfighter Project (pics) in progress. | 00v_Lucky | 2008 - 2012 Ninja 250R Farkles | 47 | May 18th, 2011 06:29 AM |
2008 Ninja 250R , mild streetfighter custom (SoCal) | 1hardryder4life | Motorcycle-related | 1 | July 24th, 2009 08:44 PM |
