Old January 16th, 2015, 03:14 AM   #1
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
I hope it works ...
In Germany the riders talk about a special fork oil which makes the ride very smooth and so I'm gone test it now (ordered today).
By using HKS GGV the so-called telescopic fork breakaway torque is completely eliminated.
Smallest bumps and the like are not transmitted from the unsprung portion of the front fork on the bike..
The result is silky, smooth ride and safest ground. A noticeable relief! In conjunction with an HKS Super lubricated chain results in a "smoothest driving" !!!
A breakaway torque does not exist anymore!
Application fork-slip improver
Instructions for HKS GGV (FSI)
100 ml trickle plastic bottle
External use:
On the sealing of each fork leg lip rub 3-4 drops HKS GGV with your finger.
Repeat all 1000 - 1500 km (600 - 1000 miles).
Internal use:
Per 100 cc of fork oil put 2 cc HKS GGV into the fork oil.
Link: http://www.hks-czech.de/hks-ggv.html
Old January 16th, 2015, 08:04 AM   #2
Let us know what you think, but the "breakaway torque" is from friction created by the fork seals ("stiction"). The wipers on the seals would eventually remove most of the oil you put directly on them.
The fork oil is used to dampen the fork action, and I wouldn't expect the oil to change the friction from the fork seals.
A very thin fork oil would allow the fork to move quicker/easier on sharp or small bumps, giving the feeling of smoother fork action, but could become a problem as speeds and loads increase.
Old June 12th, 2015, 01:21 AM   #3
Somchai
Freedom for Germany
Now after riding 800 km (500 miles) with the HKS GGV in the fork oil I'm sure I can say: Yes it's doing what it's made for - eliminate the fork breakaway torque.
My forks are very smooth and I feel it doesn't have that point of breakaway anymore when pushing them down.
And today after riding a real catastrophic road I can say my suspension setup is absolute great
By the way from what I read (I don't have a chance to test or compare) the breakaway torque of an usd-fork should be much higher than from the normal fork.
More pics I hope 4x4mike Pictures 4 October 19th, 2013 11:49 PM
Best Obituary One Could Hope For Alex Off-Topic 10 June 9th, 2013 11:30 PM
Losing Hope Malicious Logic General Motorcycling Discussion 9 April 8th, 2012 06:47 PM
Really hope this is normal SpeedDemon 2008 - 2012 Ninja 250R Tech Talk 10 September 2nd, 2011 06:20 PM
Florida gained hope, then lost hope, all within 24 hours. Mr.E General Motorcycling Discussion 0 August 29th, 2011 02:12 PM
