March 22nd, 2012, 11:55 AM | #1 |
Join Date: Mar 2012 Motorcycle(s): 2012 ninja 250 Candy Lime Green Posts: 12
Neutral Light
Hi, Just picked up my brand new 2012 yesterday. On the ride home, when
I tried to shift from neutral, at a stop, into first gear, 50% of the time, the neutral light would go out, but I would still be in neutral. I would have to try to put it in first gear again, then it would go in. Is this normal? |
March 22nd, 2012, 01:20 PM | #2 |
No, it's not normal. Either the shift lever needs to be adjusted, or there is something wonky with the neutral sensor.
/moved to new-gen tech
March 22nd, 2012, 02:40 PM | #3 |
Join Date: Dec 2011 Motorcycle(s): 2013 636 - ABS Posts: 173
It happened to me all the time when I first got my bike. It stopped after I did the first service. During those first few hundred miles I got tired of people honking at me and being thoroughly embarrassed at every other red light so I left the bike in first with the clutch pulled. It was a pain in the a** to get it to go into first from neutral. Id usually double check every 15 seconds or so by testing the friction zone to ensure that I was still in gear, but thats just me.
I believe the issue is caused by the gears not lining up all the way or something, but i'm no mechanic. When this happens roll the bike back/forward a little and try again. Try to make sure that you are downshifting into first while decelerating so that you are actually in first by the time you stop. Also, avoid slamming down on the clutch lever as it should take very little effort to change gears. I took her to an empty parking lot and just practiced taking off from a start. Give it a few weeks of commuting or just riding daily and you'll be pretty darn good at it. Now Im usually in neutral at red lights after a car stops up behind me and have no issues getting the bike into first. |
March 22nd, 2012, 07:49 PM | #4 |
I know. That's what happens. I put it in neutral at a stop light, then the light turns green, I put it in first, the neutral light goes out, I turn the throttle and all that happens is the engine revs, and I don't go anywhere and cars start honking.
Did they adjust something at your first service? It works fine now? |
March 22nd, 2012, 07:55 PM | #5 |
It sounds like you're not putting it all the way into first. From neutral, clutch lever is out. Pull clutch lever all the way in, push shifter down firmly and you'll hear a clunk. Let out the clutch slowly and you should be on your way. If you're doing that, and that's not happening, the shift lever needs to be adjusted.
March 22nd, 2012, 08:02 PM | #6 |
I do that. Sometimes it slides into first with a light touch, no sound or click,
sometimes I bang on it with my boot out of frustration and it still doesn't go in gear. It always goes in the second time I try it, and the neutral light always goes out whether it is in gear or not. |
March 22nd, 2012, 08:06 PM | #7 |
No banging. It will bend the shift forks, and nothing gets better after that. Are you shifting it in and out of first without letting the clutch out when it is in neutral?
March 22nd, 2012, 08:14 PM | #8 | |
March 22nd, 2012, 08:16 PM | #9 |
I'll stop the banging.
All I do is, when I'm in neutral, with the neutral light on, I pull in the clutch, tap the shift lever down with my toe, the neutral light goes out, so I think it's in gear, I let the clutch out and nothing happens. The engine starts to rev and I don't go anywhere. So I pull in the clutch, tap the shift lever again and it goes into gear. |
Neutral Light/Safety switch not working help. | RuthlessZ | 1986 - 2007 Ninja 250R Tech Talk | 14 | February 13th, 2015 11:31 AM |
1st Gear or Neutral when at a red light? | ajcadoo | General Motorcycling Discussion | 27 | April 21st, 2012 09:32 PM |
Brake light on while in neutral? | andrewsfm | 2008 - 2012 Ninja 250R Tech Talk | 13 | July 31st, 2011 07:45 PM |
Stuck in Neutral | ninjabadger | General Motorcycling Discussion | 11 | December 5th, 2009 11:00 PM |
False neutral | SteveL | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 26th, 2009 09:14 AM |
