Old March 25th, 2012, 03:39 PM   #1
indr
Did valves, bike won't start
Buttoned up everything together.
I've checked all connections. I've made sure the kill switch is off. I've tried it with kickstand up/down, clutch in/out, in neutral/1st. Nothing. No cranking. No noise. Is the tail light supposed to come on with the key in the "on" position. Cuz it didn't. Neither does the brake light come on upon application of brakes.
Checked the battery and it's fully charged. The only major electrical connection I undid were the white connectors that hook onto the notch in the frame and sit under the tank. I installed new spark plugs. The boots are fully seated.
I'm sure it's something utterly stupid I forgot that'll hit me tonight. But, in the meanwhile, please brainstorm with me.
indr is offline   Reply With Quote
Old March 25th, 2012, 03:53 PM   #2
Check continuity of the circuit starting at proper ground, fuses, etc.
I am sure you will find an "open bridge" somewhere.
Old March 25th, 2012, 03:56 PM   #3
zzrguy
zzrguy's Avatar
Motorcycle(s): 2002 ZZR 250
Exclamation
If you don't hear any noise, its something electrical. You'd at least hear a clicking. Either A you managed to kill your starter motor or its not connected.. or you missed a connection somewhere on your bike
I'm not sure which one you have but there is the green wire near front sprocket behind the cover that needs plugged in.
the two wire bunches under the motor must be connected to the right side.
the ground must be connected its on the right side of the motor
The stater motor must be connected to the relay at the back right side.
Was It any of them? double check the two wire bunches they sometimes come un-done as they are crazy hard to plugin sometimes.
zzrguy is offline   Reply With Quote
Old March 25th, 2012, 04:02 PM   #4
DaBlue1
DaBlue1's Avatar
Have you check the main fuse?
Old March 25th, 2012, 04:57 PM   #5
indr
Okay. Turned out to be a loose battery connection since it works now that it's reconnected.
But, there's a horrible knocking sound when I crank the engine. I tried to turn the engine manually using the little hole on the left side, and there a certain point past which the thing won't turn.
I'm guessing I screwed up the timing when putting back the camshafts/chain in or there is something stuck down there.
What a pain. Since I don't have a sheltered garage and the next non-rainy day looks to be far away, let's guess how much a f*cked up the engine.
Old March 25th, 2012, 05:41 PM   #6
Sorry to read that.
The knock noise may come from a valve hitting the piston.
Hope nothing is bent or broken.
Best
Old March 26th, 2012, 03:39 AM   #7
zzrguy
zzrguy's Avatar
Sounds like you might have bent a valve if you can't turn it all the way over. Hope that's not the case it's like 50 bucks per valve luckly the bike only has 8..
How did you do the timing? Did you do tdc piston 2 and then line up 33 links on the chain with the markers on the cam sprockets?
Where do you live? If you have bent the valves I have a motor with 15000 km with perfect valves I'd sell half price. If yours are bent that is and you have a 88-07 ninja
Old March 26th, 2012, 07:39 AM   #8
indr
I'm in BC and the bike is a 2010. I'm planning on pull the covers and undoing and redoing all the steps. Hopefully it's something something small like the timing.
When putting back the camshafts and chain, before pulling I had the engine at 2T, so I installed them back the same way. Maybe missed a teeth or something.
Old March 26th, 2012, 08:08 AM   #9
zzrguy
zzrguy's Avatar
Make sure when you check you have all the chain slack at the back and it's tight in the front (exhaust) side
Help!!!!!!!! - bike won't start auntymunga 2008 - 2012 Ninja 250R Tech Talk 5 August 18th, 2014 06:54 AM
Bike won't start sLick415 2008 - 2012 Ninja 250R Tech Talk 7 February 4th, 2013 11:38 PM
Bike won't start Z300 2008 - 2012 Ninja 250R Tech Talk 21 August 26th, 2012 09:05 PM
Bike won't start joyinc 2008 - 2012 Ninja 250R Tech Talk 21 May 31st, 2010 09:10 AM
