March 27th, 2012, 02:22 PM | #1 |
Join Date: Jul 2011 Motorcycle(s): 2010 250r ninja Posts: 115
best jetkit?
I am goin to be doing a Full system exhaust (sportisi) and wondering what is the best jetkit. I've hear of "factory pro" which alot i see use and "sportisi (with titanium needles)" kits.. are there more and what do you recommend using or they general all the same?
Thanks |
March 27th, 2012, 02:37 PM | #3 |
from the looks of it, those are individual items.. not kits. Im new to this jetting thing so bare with me. lol
tho appreciate the reply |
March 27th, 2012, 03:10 PM | #4 |
heres something most people dont realize. a jet kit is expensive because they are selling it to people who dont know better.
buy individual main jets and pilot jets, adjust your needles with spacers. you will save 80$. you dont need titanium needles with 17 clip positions
March 27th, 2012, 03:24 PM | #5 |
Washers, pilots, and mains. that's it
The needle profile has some effect on its performance, but washers get the job done just fine for saving $$ |
March 28th, 2012, 01:13 PM | #6 |
Join Date: Jun 2011 Motorcycle(s): 2011 Kawasaki Ninja 250R (sold), 2007 SV650s (deer wrecked), 2010 Suzuki SV650S Posts: 334
Aftermarket pilot jets make a difference???
March 28th, 2012, 01:44 PM | #7 |
if they're bigger they'll flow more fuel.
If you've got your mix screws out 3.5 turns or so, you'll want to consider replacing pilot jets with larger ones. |
March 28th, 2012, 01:52 PM | #8 | |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
THE GOOD LIFE |
March 28th, 2012, 02:34 PM | #9 |
i really am not a carb expert at all, especially on the 250 carbs but on my fzr carbs the "mix screw" controls how much air goes into the pilot mix. the pilot jet controls how much gas goes into the pilot mix. so if you dont have much power down low even if your fuel mix is correct by adjusting the air screws, increasing the pilot jet and retuning the air screws will get more power down low. however i dont know if mikuni and keihin carbs are the same like that.
Jetkit advice | Ausoi | 2008 - 2012 Ninja 250R Tech Talk | 21 | April 14th, 2013 03:57 PM |
Which Jetkit is best? | Boomstick | 2008 - 2012 Ninja 250R Tech Talk | 8 | September 1st, 2011 01:20 PM |
Need help for a jetkit!!! | Blackninja250 | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 6th, 2009 07:30 AM |
Exhaust/JetKit ? | dancrosoft | 2008 - 2012 Ninja 250R Tech Talk | 65 | February 19th, 2009 08:38 PM |
FP Jetkit and K&N in the house | Cochese | 2008 - 2012 Ninja 250R Farkles | 8 | December 30th, 2008 09:57 PM |
