Old March 28th, 2012, 02:18 PM   #1
kano6280
Motorcycle(s): 09 ninja 250r
Never using choke
Hey guys, before i got a dynojet kit installed on my 09 ninja i always had to use the choke. Now on start up every morning it doesnt need choke at all. If i do use the choke it will die every time. I got the kit installed in January so it was still pretty cold outside. Is this normal with a jet kit installed? I talked to a mechanic about it and he said that every bike is different and if doesnt require choke then i got a good bike. For some reason that just sounds weird.
Mods on my bike: Danmoto slip-on, dyno jet jet kit, and pipercross air filter. Thanks.
kano6280 is offline   Reply With Quote
Old March 28th, 2012, 02:32 PM   #2
exarch
Motorcycle(s): 2011 250r
Ive never had to use the choke, even in the cold. But then again my bike has a factory pro jet kit, so my input is probably useless...
Posted via Mobile Device
exarch is offline   Reply With Quote
Old March 28th, 2012, 02:56 PM   #3
kano6280
thats good to hear. atleast i know im not the only one so im guessing that its perfectly fine.
Old March 28th, 2012, 03:06 PM   #4
DaBlue1
DaBlue1's Avatar
Originally Posted by kano6280 View Post
...before i got a dynojet kit installed on my 09 ninja i always had to use the choke. Now on start up every morning it doesnt need choke at all. If i do use the choke it will die every time. I got the kit installed in January so it was still pretty cold outside. Is this normal with a jet kit installed? I talked to a mechanic about it and he said that every bike is different and if doesnt require choke then i got a good bike. For some reason that just sounds weird.
Altitude, Humidity, and Air Temperature are factors that will change the performance of the engine. Air density increases as air gets colder. This means that there are more oxygen molecules in the same space when the air is cold. When the temperature drops (is colder), the engine will run leaner and more fuel will have to be added to compensate (the choke/enrichner). When the air temperature gets warmer, the engine will run richer and less fuel will be needed (no choke). An engine that is jetted at 32 degrees faren. may run differentl when the temperature reaches 90 degrees faren. Idle speed may also need to be re-adjusted on some bikes as well.
So your situation is normal and not so weird.
Old March 28th, 2012, 05:47 PM   #5
Kurosaki
Akai Suisei - 赤い彗星
Kurosaki's Avatar
Motorcycle(s): 08 Kurosaki 250, 09 Honda 600RawrRawr
I only choke if we agree on a safeword before hand. Otherwise, things can get a little intense.
Kurosaki is offline   Reply With Quote
Old March 28th, 2012, 06:29 PM   #6
Old March 28th, 2012, 07:00 PM   #7
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
The choke just adds more gas. If your bike doesn't need more gas and you put on full choke it could definitely sputter and die.
MikeBudd is offline   Reply With Quote
Old March 28th, 2012, 07:19 PM   #8
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
My bike acts the same way, When it was stock I had to start with the choke half way even on hot days, just had a Full Area-P, Dyno-jet kit, Kleen Air sys. removed, snorkel removed,K&N Filter, I had a shop install the jet kit and dyno the bike. Got it back a couple of weeks ago and haven't had to use the chock yet.
kevheads is offline   Reply With Quote
Old March 28th, 2012, 08:14 PM   #9
every bike is different, it depends on tons of factors including climate, altitude, time of day, if you need to get somewhere on time or not, etc. if you dont need to choke the bitch, cool. if you do, cool. as long as it runs well when warmed up you can pretty much ignore it.
Old March 28th, 2012, 08:19 PM   #10
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
When I bought my bike, the idle speed was too low. So, it would just die, after running for about ten seconds. I increased the idle, and now the choke actually works. Before I didn't even notice a difference in the performance of the bike when I used the choke before adjusting it. Each bike is different, and if they're not set-up properly (like mine), then you sometimes have to adjust a few things here and there.
Old March 28th, 2012, 08:20 PM   #11
nick, you're welcome
Old March 28th, 2012, 08:23 PM   #12
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Also, wheel wasn't aligned properly, and the suspension wasn't bolted on completely. At any given time, by rear suspension could have just fallen off !!! LMAO
Old March 29th, 2012, 12:28 AM   #13
you sound so pro, do you race mx, nick? :P
Old March 29th, 2012, 05:26 AM   #14
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I wish! Right now I just go around a muddy yard...it's hard because the wheel sinks into the ground. If I put to much throttle the wheel just spins, and I start falling over. I sound like a pro...that makes me happy
Old March 29th, 2012, 09:20 AM   #15
Nick, let me introduce you to sarcasm.
Oh, you've already been introduced? Oh that's right, alex introduced you two. Funny, you acted like you didn't recognize each other...
huh.
Old March 29th, 2012, 09:28 AM   #16
chode is just jealous i haven't made fun of his beliefs lately.
...wait a second now im confusing chode and justin. oh well, they're both insignificant side-characters. they probably don't even effect the plot.
Old March 29th, 2012, 09:33 AM   #17
just like you and kevin.
Old March 29th, 2012, 10:09 AM   #18
mrcrunch
Motorcycle(s): 2007 250r
If you don't need to choke your bike on a cold-start, i'd worry (a little bit) that it is running too rich when it warms up. Check your plugs to see if it is fine for the longer rides?
mrcrunch is offline   Reply With Quote
Old March 29th, 2012, 10:56 AM   #19
plugs are really only a good indicator of the main jets.
Old March 29th, 2012, 12:03 PM   #20
mrcrunch
So when i leave my choke on by accident for my 45 minute commute, i shouldn't lose any sleep over it? cool.
Old March 29th, 2012, 03:00 PM   #21
Well, I would make sure to check the choke as you leave the neighborhood
but no, it won't make a huge impact unless you leave it on all the time.
Old March 29th, 2012, 03:08 PM   #22
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
I may be wrong but I'm pretty sure our choke reduces air, not adds gas. I know it's semantics.
Old March 29th, 2012, 03:26 PM   #23
On most carb'd engines, a choke reduces the air, choking the engine.
The "choke" on the 250 is a starting enrichener. Pulling the lever opens some plungers and adds more fuel to the mix. Same amount of air.
But we still call it the choke
To choke or not to choke? Greyfox 2008 - 2012 Ninja 250R Tech Talk 14 May 9th, 2012 08:03 PM
choke? reabo 2008 - 2012 Ninja 250R Tech Talk 4 February 2nd, 2012 05:24 AM
the choke james250ninja 2008 - 2012 Ninja 250R Tech Talk 4 November 6th, 2011 05:38 PM
So how does choke work? ericeng91 2008 - 2012 Ninja 250R Tech Talk 10 April 15th, 2011 06:50 AM
